View Full Version : Want to Buy
- Wtb 99-00 ebp fenders
- WTB: ITR Chrome Oil cap
- twin 38mm wastegate springs.
- WTB: Wideband O2 Air/Fuel UEGO Gauge Kit AEM Part Number 30-4100
- WTB k20 shifter box and cables
- WTB: EG Cluster w/ Tachometer
- WTB Civic SI 92-95 Stock
- WTB: Civic Hatchback Mud Flaps Guards
- WTB: 88-91 Hatch corner lights
- wtb: b series cam gears
- WTB Acura Integra NY for 2-3K
- WTB B18B short block and head
- wtb gsr forged rods, 9.1 pistons asap
- wtb honda del sol parts
- WTB: EK Spoon Cluster
- wtb drag wheels welds,spinwerkes etc
- wanted wastegate
- Wtb:b18b1 good head
- Wtb: 94-97 integra parts
- airbag delete tray
- WTB: 93 del sol windshield trim sides and top
- WTB: OEM cat for DC4 Integra (OBDII)
- WTB: Ek9 Thin Side Moldings
- WTB 88-89 D16A1
- WTB: 92-95 CIVIC A/C SYSTEM
- WTB:VX or CX I.Manifold
- WTB: h22 LSD swap(motor & tranny). Hasport mounts and axles
- WTB H22 short block
- B18A1 LS tranmsission WTB
- WTB: Integra Brake Booster (DC chassis)
- Need EK lights
- 92-95 civic (eg) Manual Steering Rack
- wtb: Db8 Integra Sedan itr spoiler
- WTB: Skunk2 Fork Spacers hardware
- WTB: Phantom Grip B-series rockers
- WTB. EK electric window regulators
- 98-01 teg black passenger rear quarter interior panel
- WTB OEM 2000 Integra Muffler
- complete b18c1 or b18c5 shortblock
- WTB : DC integra caliper bracket
- B16/b20/em1 ac bracket WTB
- WTB//GSR OIL PAN.
- EG auto to manual trans mount
- turboxs rfl bov w/greddy adapter
- looking for stock springs 1995 honda civic ex coupe
- WTB: 94+ Integra LS Knuckle O-ring.
- Wtt my Sir2 B16 95 hatch for ek coupe 5 speed
- Integra Type R lip needed
- Intake Manifold Flange
- Wtb oem eg front lip (ex,si,SiR)
- Wtb Eg6 SiR spoiler, SiR mirrors & headlights
- WTB: CRX Fiberglass Body Panel Parts. Leaxan windows or equal
- WTB TRACTION BAR FOR EM1
- WTB: 44mm WG, 50mm BOV
- WTG EG coupe headlights:Taillights
- USDM 99-00 OEM EK Hatch Passenger Tail Light
- WTB: CIVIC PARTS!!!!!!!!!
- em1 hood bra
- WTB: Bseries Vss and clutch fork
- Wtb: main relay for 95 Honda civic ex
- WTB: EK Parts
- wtb: 1 gsr rod cap
- CA WTB 949 RACING 6UL 15X8 WILL PAY SHIPPING WILL PAY TOP DOLLAR
- LF Honda accord 90-93 jdm parts
- WTT: HONDA FIT - HONDA ELEMENT - HONDA CIVIC
- WTB - 1998-2001 ITR brake calipers
- WTB: TEIN Coilover Adjustment Wrenches
- WTB: D16 waterpump, GSR (B18C1) water pump, D16Y8 crank timing gear
- WTB Side Mount bracket/slider for Bride Seat EG/DC FO
- wtb: looking for d16z6 or zc long block..
- WTB Hondata S-300
- WTB: Integra FAT FIVE or Blades
- skunk 2
- WTB: Full Coilovers or Lowering springs with struts for 1990 integra Sedan LS
- WTB em1 taillights
- WTB: Aftermarket 1.3 radiator cap ASAP
- wtb B serie Skunk2 alpha header
- WTB Heat Shield 90-91 Accord EX
- Wtb Hasport ekk2 mounts
- WTB from a b16a2 the tranny mount and front lower motor mount and bracket
- WTB B18C1 Timing covers
- [B]WTB: 88 ef or ITR lca[/B]
- wtb ek cupholder
- WTB: stainless brake lines for 98+ DC2
- WTB Civic Hatch, I have Cash
- WTB: JDM front HOOD
- WTB JDM RSX STEERING WHEEL TYPE R
- Need b series flywheel bolts!!
- wtb gt30 gt35r must need rebuild
- WTT/Bosch 660cc injectors
- WTB: Synchronizing Piston OR Rocker Arm Assembly
- WTB Eg dash harness
- WTB: 90-91 Civic hatch front bumper
- WTB 1994 civic ex interior parts
- OBD1 GSR ECU
- WTB: 2000 civic si ac discharge line and oem side skirts
- d series transmission
- WTB Skunk Pro 1 Camshaft, JUN III Camshaft
- WTB: LS crankshaft
- WTB | Fujitsubo rm01a or power getter - DC2 Integra
- Del sol b16 AC mount
- WTB Built Ls block
- WTB: 96-98 OEM CIVIC MUDFLAPS REAR & FRONT
- 92-95 Civic OEM clock... JDM or USDM
- WTB: Radiator for eg civic
- need ap1 s2000 parts asap
- WTB ** LS 81.5mm SLEEVED block **
- WTB: Zeal Wing EK
- wtb: oem integra type r lip
- WTB Brake booster and Master cylinder 1in
- WTB : d16 main cap bolts
- WTB 3 bar map, hondata s300, and id1000
- WTB: B Series Spark plug cover
- MI WTB K-Swap goodies
- WTB: GSR MC and booster
- WTB: 1 mint Mugen GP
- WTB: 99-00 OEM nose mask
- WTB: 1" Master Cylinder/Booster and 40/40 Prop Valve
- WTB: Traction bars 92-95 Civic
- wtb ground control for koni
- WTB: 99-00 civic hatch tail lights
- WTB: 96-98 civic ex 2 door harness
- WTB | GReddy EVO 2 catback - DC2 Integra
- WTB Rear Integra Type R strut Bar
- wtb: b series vtec valve covers
- Wtb ported and polished b18b1 head
- WTB 96-00 civic front mudflaps asap...........................
- WTB: inexpensive 4x100 wheels/tires
- WTB eg door weather stripping
- WTB: Skunk2 Pro 1 Cams/ Skunk2 Pro Gears
- ACL race MAIN bearings std size B18
- WTB Civic EG 2dr/4dr tail light wire harness
- WTB! Cat-back exhaust for 2000 integra gsr
- Mugen, Rigid, Ms Design, Vision
- WTB: 02 Civic Hood OEM..
- WTB 95 Civic Hatchback Retrofit Headlights
- EF shifter pieces
- WTB Prelude Doors and Hood
- WTB: Id injectors 1000cc n Hondata/Omnipower 4 bar map sensor
- WTB: Logic H2B header
- wtb black, gray, dark blue 6sp tsx. Tn
- ARP LS head studs
- WTB 92-96 Prelude Front Lip
- hasport ef mounts.
- WTB: 92-95 civic power mirrors
- WTB: Rays lugs
- WTB: OBD1 Integra Dash Harness
- WTB: Honda Civic HX STOCK! CASH!
- WTB: Carbon Kevlar Spark Plug Cover--B Series
- WTB: ap1/ap2 head
- ATTENTION SPONSORS: WTB Wilwood BBK for EK hatch!!!
- Wtb Mugen duckbill for ek hatch real or replica!!!
- WTB 88,89 crx front corner lights (oem)
- wtb: 1999-2000 honda civic si headlights must be clean no broken tabs
- Wtb: 99-00 si distributor
- SO Cal: WTB: AP2 S2000
- WTB. PIC Coilovers for EK
- WTB OBD1 vtech harness
- WTB Shell
- Wtb b16a distributor
- wTB: 92-95 Hatchback interior/exterior parts...
- wtb k dog box
- wtb: b18a ls valve cover
- WTB: two tial 38mm gates
- wtb Isky titanium retainers sohc d16a6 one or whole set...
- Obd2b to obd1 distributor jumper harness
- WTB: B-series parts for my build
- WTB:PRELUDE BLADE CENTER CAPS
- WTB: traction bar EG
- WTB: Prelude modifiers
- WTB: Oil Guide Plate S40 Transmission
- WTB 88.89 crx front corner lights
- Wtb cable to hydro
- integra dual bend for civic ek
- I WTB one of these stock 13" honda wheels!
- WTB S2000 AP1 OEM front lip
- WTB decent honda shell
- Wtb , Del sol vtec or crv ac bracket!!!!
- rota subzero 16 or 17 inch or 15 for a good price
- WTB: CRX heater system
- wtb: oem 94+ integra clear sidemarkers
- WTB slim fan for my del sol
- WTB Rear E Brake Bracket (Integra)
- Need 95 Accord V6 Parts!
- WTB: Tow Hook, 98 EK grill, EK radiator with fan...
- WTB : Forged rods and pistons
- Skunk2 lower tie bar n strut bars front and rear
- WTB: 98 LX Non Vtec compatible head
- WTB : EK OEM lug nuts, AC compressor
- WTB: gsr head
- WTB itr/ctr or stage 1 exhaust cam b16
- WTB: gsr oem lsd
- Wtb: ef roofrack
- WTB - ITR cams and ITR intake mani w/ TB, DC2 parts
- WTB: 8th gen Civic Si LSD
- WTB: EK Coupe Driver's Side Power Lock Door Pull/Trim
- WTB: KYB AGX or Koni Yellow specific for GC
- WTB- Mugen M7, CCW Classics, Regamasters
- WTB: B16 or ITR pistons on Ls Rods
- WTB: Civic 06-08 front white bumper
- WTB stock k20a2, or k24a2 long block
- WTB: EK D16Y8 Intake system, knock sensor and more
- PA - WTB OBD2a P72 ECU
- WTB: EG/EK/DC - clean - b or k series
- Ef9 front end
- wtb: springs, cruise module, injectors
- WTB CRX power folding mirror seals.
- Em1 parts!
- WTB: USDM ITR CF interior
- wtb dd things want monies get in here
- WTB:SKUNK2 STAGE2 B18C cams
- WTB wheels help
- WTB: 96-97 GSR obd2a Dizzy
- Want a Ruckus!!!! I have GSR and ITR setup to TRADE
- WTB Greddy Profec B-Spec II Boost Solenoid
- WTB 4 Harness eyebolts
- B Series Hydro Tranny Manual Half Shaft & Speed Sensor
- WA, WTB- LS oil pickup
- wtb OBD2A vtec wiring harness (corning/elmira ny)
- WTB: Honda S600
- WTB: 96-00 HX Cluster
- WTB: ITR AEM 3" Cold Air Intake
- WTb:92-95 civic hatchback black rear seats
- wtb !999-2000 passenger side oem headlight and oem grill
- WTB: A-C-U-R-A EMBLEM
- Integra parts to finish build
- WTB: Ameripol glass top
- wtb dc2 jdm frond wide fenders j's or chargespeed or max racing
- wtb: Front dc integra spindles
- WTB: AEM EUGO WIDEBAND
- WTB d series/b series engine harness
- WTB: 94/95 Accord MT mount
- 96-00 civic 2dr window regulators
- D Series AC Compressor Pulley
- WTB misc/ skunk2/ ferrea/ edelbrock
- WTB: EG D15 HEADERS
- WTB 3rd gear from an LS Hydro Tranny
- wtb: jdm b18c type-r longblock in any condition
- wtb h22 prelude intermediate shaft
- WTB EG HATCHBACK
- WTB: 91 Accord interior pieces
- WTB: ITR/CTR Rear Trailing arms
- LS (p75) Upper PS Bracket
- WTT/B EG Parts
- wtb: built sleeved block
- eg6 tail lights
- Wtb 330cc injectors
- WTB: Mini me swap
- WTB: Spoon B-pipe, T1R B-pipe Integra
- WTB 96-98 civic ex engine harness
