View Full Version : Want to Buy
- WTB - Motor for 2000 Civic - Oregon
- Wtb--- Jdm integra front bumper
- WTB: Authentic Mugen Spoiler Gen II, DC2
- 96 EK civic Sedan
- WTB integra CF hood and trunk
- WTB: B-series Type R Headers
- WTB: EK hasport Mounts (or innovative)
- LOOKING FOR: OBD-2 ENGINE HARNESS INTEGRA GSR
- WTB: PA - 96-00 D series automatic transmission
- WTB: pistons/rods/springs/retainers
- WTB: 99-00 OEM CTR Headlights
- WTB: OEM Integra GSR shift knob
- WTB: JDM Thin Side Moldings For an EG
- WTB: 8th Gen Civic Si Axle back
- WTB: 22in slicks/ wheels for honda/acura
- Is anyone parting out a 90-93 Accord coupe?
- WTB 97-2001 Honda CRV
- WTB del sol coilover sleeves
- WTB: ITR Non SRS Horn Button
- WTB: Integra Lower Radio Pocket
- WTB 5 lug swap
- looking for a h22a4 head
- Looking for an f20b block/ motor
- WTB: 99-00 civic si OEM Air Intake assembly
- WTB: Works Bell quick release hub/boss
- WTB: OBD2B P75
- 240 kph Jdm cluster
- WTB WS2 Muffler
- WTB: LOOKING FOR A TODA B-SERIES FLYWHEEL OR OTHER!!!!!
- WTB: ITR Heatshield and Stock Air box
- Looking for prelude ECU
- WTB EK CTR Replica in the northeast.
- WTB: D16Y7 heat shield|timing belt cover|OEM shifter handle|TAN plugs
- WTB: STOCK 99-00 CIVIC SI EXHAUST
- WTB: eg6 parts
- EM1 Si grill and lip
- ITR cam, Civic Cam
- BBR Competitions 4x100 15x8 +15
- Wtb-eg shell bay area locally
- Looking for 96+ Ls or GSR Trans
- WTB EK PARTS
- WTB: Slim fans/oil cooler setup/cams/springs/retainers
- WTB: OBD2 GSR Gauge Cluster
- WTB:OBD2 Integra Motor wire harness 1996+
- WTB: Passenger side 97+ Integra headlight assembly.
- WTB usdm gsr pistons/rods
- WTB: 23x9x13 slicks, located NORTHEAST
- WTB: JDM Headlight Harness for DC2
- WTB: 2001 CRv SE/LE dash clock
- k20a3 flywheel/clutch/cams/swap headers
- WTB ITR throttle body
- WTB: Wood grain steering wheel momo or nardi
- WTB oem rsx base/type s suspenion parts
- WTB 95 GSR Alternator OBD1
- 96-00 civic hatch
- wtb - stack s200 clubman tachometer
- (VA) WTB: OEM MUD (SPLASH) GUARDS FOR 99-00 CIVIC HB
- WTB: 1992-95 EG/EH Civic A/C System
- WTB : 92-95 OEM Tail Lights
- Wtb center caps for jdm type r wheels dc2
- WTB 18x9 Rota Grid rims
- WTB OBD2a p75
- wtb RSX oem car cover
- spoon oil cap
- [B]wtb:ef sir front lens[/B]
- need crank pulley d15b7
- WTB: B-series V-tec 3-4 Shift Fork
- 2000 GSR light/wiper switch complete
- WTB: ACURA CL 97 98 99 HEATED SEAT SWITCH
- WTB: EDM/JDM EG Clear Corners
- Wtb 91 ef si under dash harness
- WTB: Stock B18A LS header Milwaukee, WI
- 99-00 Front/Rear lip (PU) & 96-00 4dr window regulator
- WTB: integra sedan OPTIONAL TRUNK MAT
- NEES A LS MESH
- WTB Integra Sedan and B-series stuff
- WTB: PY - ITR hood
- WTB: Skunk2 GSR Intake Manifold - or similar
- WTB B20 block
- 96- 98 auto transmission
- WTB Integra struts
- LTB|96-98 Clock
- RC 550cc or 440cc injectors
- Metal Clip that holds the headlight bulb/lamp
- WTB: 13in Slicks
- WTB: B SERIES STUFF
- WTB: jdm front integra reinforcement bar and front bumper support
- Wtb:sohc cable tranny clutch asap!! Please
- WTB: USED or CHEAP NEW WORKS BELL QUICK RELEASE
- Wtb integra 4dr rear door handles
- WTB First Generation CRV Wire Harness
- WTB: 1995 Honda Accord front OEM Axles
- WTB: OBD2 GSR TB
- wtb asap- r12 92+ civic ac lines
- fuel fittings
- WTB:\\92-93 Integra Dash HarnessASAP
- wtb exhaust barrel
- WTB CTR Floor mats
- WTB: D15 D16 sohc engine *must be in strong running condition*
- WTB: OBD1 Automatic P30 ecu
- CRX EF8 JDM Front Bumper
- wtb p29/pm7 pistons
- WTB: 01 Honda Accord Floor mat, Gray
- Jayvee's WTB Thread !
- 99 si em1 subframe setup w/ rack ps pump/b16 t bracket mount rotor k20 cams
- WTB: 02 Honda CR-V AC Compressor
- WTB : PA / Northeast B series hydro 5 speed transmission & clutch kit
- WTB:\\ 92-93 Integra Cluster
- WTB stock p72 rods
- wtb P29/PM7 pistons
- WTB: 1996-1998 Heater Control Module
- VA WTB miracle cross bar for dc2
- WTB RHD EK rack n pinion
- [MD]WTB: d16z6 obd1 sohc vtec manual ecu
- WTB: pair of 24x3.6x15 skinnies
- WTB: VX wideband o2 and wiring
- WTB: Silver ASR Subframe Brace for 92-95 Civic
- Wtb p75 virgin 94-95 integra ls, manual ecu
- WTB: D16y7 FITV
- WTB: b20b ect sensor/switch plug
- WTB: ASR Subframe brace
- WTB: UKDM DC2 tail lights
- 92-95 civic A/C system COMPLETE
- wtb: 96-98 harness
- FT: Rmf narrow rep plm header b series for jdm itr 4-1
- WTB Black EG DASH
- WANT TO BUY ASAP:B series map sensor for boost, AEM WIDEBAND SENSOR, GM BOOST SOLENOI
- WTB: RS*R Ex-Mag Exhaust for CRX
- WTB: Wheel Adapter (4x114.3 to 5x114.3)
- Looking for some meshies
- WTB AC COMPRESSOR FOR 98 CIVIC
- WTB Integra Type R OEM lower control arms
- WTB Built Z6 or Y8 head
- WTB: Hydro B-Series Differential
- wtt k series turbo kit for k24a2 swap
- WTB: 92-95 hatch door panel, man.window, grey
- Intercooler piping off throttle body
- WTB: 92-95 hatch speaker mounts
- WTB: OEM EK9 rear lip, Takata Harness
- 99 -00 Radiator
- Haynes 96-00 Civic Manual Book
- wholesale parts oem for civic
- WTB: Type R rear sway bar.
- wtb h22a eagle rod single
- LS bottom end parts.. AFTERMARKET
- WTB: Front Fender`s for EJ
- WTB: 92-95 Hatchback SiR Cluster
- WTB 06 Civic Si Sedan fog lights
- Tailgate civic 92-95 hatchback
- WTB CF trunk for DB8
- EF civic A/C complete unit!!!
- Wtb adjustable cam gears for a b18b
- wtt: usdm itr cluster for jdm ctr cluster
- WTT: My ek9 CTR steering wheel for Spoon Steering wheel and ek hub
- WTB: f20c f22c longblock or shortblock
- WTB D16Z6/A6 Long/Short Block
- wtb!!! lenso skinnie
- WTB: Turbo + manifold
- WTB: white front/rear bumper HATCH! And blk interior parts.
- WTB: 165/45R16 or 195/40R16
- WTB: 1999 - 2000 black rear civic bumper for a coupe
- looking to buy SIR lip for 1996 - 1998 civic
- WTB: CAMS! n/a b18c1 upgrade
- eg cluster harness
- WTB: JDM B16A odb0 BARE BONES head
- WTB: OEM Exterior B-Pillar Trim 92-95 Civic
- WTB: OEM S2k trunk spoiler(any color)
- WTB: 1998 Integra GSR EVAP Canister
- WTB gsr throttle body and aftermaket intake manifold
- WTB: factory k24a2 RBB-2 valves
- WTB: 90-91 Civic Sedan Rear Seats ASAP !
- wtb:Garrett Turbo. Looking for turbo's needing rebuild. Or just cheap
- WTB 99-00 Civic Si oem parts
- WTB: 5 Panel Wink Mirror for DA
- WTB LS SHORT BLOCK, GSR SHORT BLOCK, B18C1 SHORT BLOCK
- WTB Bare gsr head
- WTB Blue S2000 Seat/s MW region
- 96-00 EK coupe window switch ASAP I MIGHT DIE
- TX: WTB civic or integra shell
- WTB: d16y8 wiring harness
- WTB: OBD1 PR4 ECU (92-93 Integra LS/RS/GS)
- wtb kpro,ekkswap axles, kswap clutchline
- WTB SUNVISOR FOR 2007 CIVIC SI
- WTB: eg and B series engine parts
- WTB: 97-98 PTC/CTR ECU
- WTB Mugen Valve Cover
- wtb b20/ls crank
- WTT: My S2000 VIS CF vented hood for OEM CF hood.
- fs/ft oil catch can
- WTB EK BOMEX MIRRORS
- WTB: B-series Kazz Ring Gear Bolts
- WTB: DEEP DISH STEELIES!
- WTB itr lip usdm 98-01
- WTB JDM DC5/EP3 gearbox/transmission
- WTB: 98-01 Integra Hood and Headlights.
- WTB:DA parts-oem battery hold down,oem interior parts,coilovers
- WTB: Civic OEM door panels (2000 EX)
- WTB: ADVAN Steering Wheel
- I want to buy / trade for a smsp b20 vtec header
- WTB: EG Coupe Axleback / Fender
- WTB : Sleeved Block
- WTB used 16in wheels and tires!
- NEED AUTO p28 ASAP!!!!!
- WTB: 98 Spec JDM ITR white rims
- WANTED: b16a or b18c/b18c1 motor asap upstate ny
- WTB: obd1 distributor
- WTB 94-97 CRV AC Bracket
- WTB: DC2 ITR Interior
- WTB: 1999-2001 CR-V
- Want to trade jdm b16a/gsr build 4 Ls engine or swap.
- 3" catback exhaust 92-95 Civic Hatch
- WTB: del sol cluster
- fmu wanted
- WTB: ASR subframe brace for EG/DC
- WTB: stock flow USDM OBD1 B-series injectors
- WTB:Oem B Series Axles 99-00 Si
- WTB: Stock 99-00 Motor Mounts| 96-00 Type K steering wheel
- WTB: ek9 oem steering wheel
- WTB OBD0 to OBD1 Ecu Jumper Harness
- WTB J&S Ultra Safeguard
- WTB skunk 2 or buddy club cat back Em1
- H22 axle cardan
- WTB: B series ATI damper, Flywheel, Flywheel bolts
- WTB 96-00 civic oem key fob
- WTB - EG Teal Driver side Fender
- WTB F22a1 motor for prelude
- wtb AEM CAM gear for a b18b
- OEM GS-R Dual Bend
- Looking for performance Throttle body, 68mm+
- WTB: 92-95 Complete A/C System (Santa Maria, CA)
- Amber sir gauge cluster needle ek
- WTB: 97-98 CTR Climate Control
- i need a obd1 del sol engine harness!
- WTB: ITR Cams or Dual Valve springs/titanium Retainers After Market Intake Manifold
- wtb fuel guage, fpr, s2k cluster
- WTB: D-Series Tranny (Hydro)
- WTB: AP2 front bumper & tail lights
- WTB: OEM OBD2 Integra LS Catalytic Converter
- locks for the EG6 trunk box
- Looking to buy a hatch or 4dr
- want to buy a built b-series tranny
- im looking for 1 or 2 ls mesh
- ntb eg parts list
- WTB: itr 4.7fd trans
- Wtb:ef,sohc vtec,d16z6,cams
- downpipe
- wtb 99/00 spoon style ABS Plastic lip
- WTB: OBD2B to OBD1 Conversion Harness and OMNI 4 bar map sensor
- looking to buy da parts
- WTB: Brakes lines an 15/16th MC
