View Full Version : Want to Buy
- WTB good condition oem muffler
- WTB: B-Series Motor!!!
- wtb 95 h22 rear tranny bracket
- WTB (TX) Suspension, interior pieces, And more!
- wtb hasport, avid or innovate mounts all or seperate
- WTB Work Equip 003 15x9 Gold!
- wtb: 00 civic si parking brake cables
- WTB Honda for circle track racing
- WTB: Integra Type R Headlight brown plug
- WTB: OEM 99-00 Civic Radio Pocket
- wtb any dd honda
- WTB: ITR doors, ITR valances and side skirts
- WTB 2.5" Electric Exhaust Cutout
- WTB: Bare B18 block
- WTB: Driver side rear ABS sensor for 98-01 Integra
- WTB: ITR rear sway bar d-brackets
- wtb: b16/b18c aftermarket valve springs and retainers
- WTB: Aeromotive A1000 FPR/ -6 Lines/fittings
- Volk Racing Center Cap TE37 16 inches
- WTB EK9 suspension springs
- WTB: Koni yellows/ground control & upper left motor mount for ej8
- WTB:ITR CALIPERS
- WTB: s2k oil pan. F20c
- WTB: 06-07 Accord Sedan EX V6 Wheels
- WTB: Wire Harness
- WTB Z6 head!!
- Arp Head Studs
- WTB: Kosei TS 15x7 - 4x100
- WTB:Mugen goods
- WTB: 98-01 Acura Integra ABS Bracket
- WTB: springs and retainers
- WTB: D16z6 valve covers
- WTB: EG6 Spoon Parts
- WTB Time-Sert #1812 M8 x 1.25
- WTB retrofitted 96-98 headlights
- WTB: 92-96 Prelude or 90-93 Accord Shifter Cables
- WTB: JDM DC2 Fender w/sidemarker
- WTB h22a crankshaft
- Wtb 98-01 integra headlight
- wtb: erie pa : itbs's for b16 type r thread
- WTB obd2b p75/LS ecu
- wtb mike belben b series degree kit
- WTB: JDM ITR DB8 Window switches
- WTB: d16y7 complete head or full b16a2 long block swap
- WTB OEM USDM Del Sol floor mats
- 99-00 CTR headlights
- WTB: *MINT* CTR EK9 DOOR PANELS
- wtb hasport tranny mount
- wtb: D-series Mfactory 3rd gear
- Wtb: 94-01 Integra center vents/climate contol surround
- WTB: Skunk2 Shocks 4 EK Hatch
- D16Y8
- Wtb: oem b-series vtec solenoid
- wtb eg or dc itr rear sway bar
- WTB B-Series A/C Compatible Turbo Kit
- Oem integra carbon fiber
- stage 3 cams for b-series
- Looking for a OBD2 knock sensor
- wtb 96-00 civic airbag delete tray
- WTB: B series hydro clutch
- WTB hondata s300
- wtb dpfi engine harness
- wtb del sol weather stripping
- WTB victor x intake manifald b18b
- wtb: eg/ek/dc2 coupe/hatch shell md/de/pa/nj
- WTB 99-00 OEM Honda Civic Si factory rims
- WTB 06-11 civic si muffler/axleback
- wtb: b series moroso oil pan, stage clutch, ek billet mounts
- EK zeal wing
- WTB K20Z3 Complete Swap $$$ In Hand (so cal?)
- Want to buy 96-00 EK Hatch cargo cover, anybody???
- wtb b16 b18c cylinder head
- WTB: OBD1 LS timing covers
- WTB: 99-00 CTR Si-R Headlights
- DS (left) Fender & Rear Bumper Filler (above bumper and below taillinghts) for 94 teg
- WTB: Catch Can -12AN
- WTB "good" oem b series crank pulley
- Need B and D series Stuff look
- wtb: LOOKING TO BUY EF2 90-91 CIVIC SEDAN HOOD BRA AND WINDOW VISORS
- WTB 98-01 2DR DC2 SPLASH GUARDS!!!! :)
- WTB: 96-00 Civic Sunroof Panel
- WTB CROWER STAGE 1 cams for a 96 b18b
- WTB dynamics or*deatschwerk injectors at least 700cc or bigger
- WTB: Integra Type R Hub
- FL: WTB Anything Free
- WTB: Complete Air conditioner setup for 96-00 Civic D series
- WTB: 04-08 TSX/CL9 Coilover Setup
- WTB: Works Bell Rapfix II quick release
- WTB: 94 Civic 5spd EX harness w/ABS
- WTB 99-00 single cam Vtec ecu
- WTB D series LSD
- WTB AEM wideband guage
- wtb: k20z3 jrsc or comptech supercharger
- WTB: Blue Del Sol Floor Mats
- WTB Integra Type R oem rear strut bar with cut outs NEW
- WTB: EG 2dr/hb hood and front bumper. CF or OEM in MD/DE/PA
- WTB: EF b16 swap parts
- WTB 90-93 DA integra STOCK springs or something similar
- WTB ; civic 96-00 wiper switch
- WTB 96-00 b series mounts
- wtb ef full coilovers, aftermarket lca for ef , wood nardi etc
- WTB: OBD1 B16 dizzy, and OBD1 P30 ecu
- WTT: EK4 SiR cluster
- WTB WINDOW ROLLER
- WTB B Series NA Cams, IM, TB for 12:1CR
- 92 EX Accord needs new power rear view mirror, driver's side
- WTB: OEM UKDM/EDM Clear Turn Signal Lights.
- WTB: Ground Control Coilovers
- WTB H22/H23 Short block NC area
- WTB: 16in Volk TE37
- WTB: 5 Zigen Div 3
- WTT GReddy Type R bov
- WTB: RHD CLIP EG
- WTB:::B-SERIES PARTS
- Wtb 94+ 4 door front seatbelts (gray) and auto ls throttle body
- WTB Clean Swapped EG or JDM Front End Integra GSR - $7000
- WTB: DB8 Rear Seat Bottom in Blue
- Wtb: gsr Ex. Valves
- WTB: Personal Steering Wheel
- wtb: stock b16 header and heatshield
- WTB - FACTORYB-SERIES LSD ASAP
- WTB: B Series Turbo Stuff
- WTB GREDDY E MANAGE S2000
- Delaware wtb rims w/ or w/o tires
- WTB: Lots of Misc 96-00 civic parts for my new restoration
- WTB: 92-95 Civic HB interior plastics
- wtb jdm dc5 body kit
- WTB D16Z6 LOWER TIMING COVER
- WTB: 99-00 Grill
- 97-00 domani/EL/Gemini hood bug deflector
- WTB: 99-00 civic si front knuckles
- WTB: Integra 5 spd Shift bezel
- WTB rsx side mirror
- WTB: EG FUEL FILTER BRACKET, B18 OIL PAN, PICKUP, WINDAGE TRAY, BLOCK, CRANK!
- Looking for virgin ECU for 1998 Honda Civic A/T with VTEC
- WTB: 15x7 wheels w/ tires
- WTB: STOCK FRONT LOWER CONTROL ARM
- WTB/WTT Obd2A to OBD1 jumper harness
- WTB: 14x5 / 14x5.5 WHEELS
- Wtb: del sol vtec shift linkage
- WTB: Gear position switch and main harness 98 LX at
- WTB: 98+ Integra 2 door tail lights
- wtb pipe cam holder b16 or b18 vtec w bolts and studs
- WTB: RHD EJ1 or EG6 RHD Clip
- b16a-b18c vavle springs injectors etc
- WTB single full swap in sa tx asap
- obd1 to obd0 jumper harness
- B series dizzy and mount bracket
- WTB: 96-00 civic replacement catalytic converter
- WTB: OEM 96-00 Civic CX, DX, LX exhaust manifold
- WTB: D16Z6 head complete
- WTB 1 ITR CONNECTING ROD
- wtb d15b7 dizzy
- Wtb:15 white Track R(nv)
- wtb a broken B16 hydro trans
- WTB: MPFI ECU and Harness for EF Hatch B16 swap
- WTB, NEED.... 98 EX OIL PAN, ASAP!!
- WTB: EK4/EK9 RHD FRONT CLIP
- wtb: rear passenger window regulator and motor for 94+ Integra 4 door
- Twin Carb jets from 80's early 90's Honda
- WTB: GR-2 shocks and/or H&R OE Springs 00 GSR Coupe
- WTB: S2 Tuner2, 044, ACL, ARP
- WTB: H22 Crank
- WTB: B18C B18C1 B18C5 BLOCK
- WTB 94+ Integra Front end (preferably 98-00)
- WTB: ap2 front bumper and CR lip.
- WTB 92-00 Civic corner light socket
- WTB: 97-01 Prelude under $6k
- WTB: OEM Spark Plug Cover (B-Series)
- S2000
- Wtb 16 inch te37 low profile or flush mount centercaps
- WTB rear hatch weather stripping 92-95
- k24 crank
- WTB: 96-00 Civic Parts | D Series
- WTB: 92-95 civic ac delete duct.:.
- WTB: USED B-SERIES HYDRO LIGHTWEIGHT AFTERMARKET FLYWHEEL.:.
- WTB Tokico Illuminas Shocks
- WTB: y8 injectors
- B16A OR GSR HEAD!!!
- wtb 92-95 oem air box
- wtb civic interior parts
- wtb: 15" 4x100 bbs/work/stance/axis
- WTB: Valve covers!
- LF: D-series ...... Cam Gears, valve train gear
- WTB: TX or OK 98-2001 civic hatch or EM1
- wtb: y8 fuel rail and regulator, z6 injectors
- WTB: DC2 none sunroof headliner
- WTB: S2k
- WTB: BDL Fuel Rail B SERIES
- WTB: Integra Interior Pieces
- WTB K series swap
- WTB: Socal: 94+ integra 5spd 2dr.
- WTB:Prelude shifter cables
- wtb: hondata s300 installed in p28
- Looking to buy: del sol quick release/hub and wheel
- WTB GC coilover for da9
- WTB: ROOF RACK. Thanks!
- wtb: db/dc parts: oem steerin wheel n more
- Wtb parts for ek hatch, recaro, ctr, asr.
- WTB: 2 15x8 wheels for my radials
- WTB: 3" Exhaust for DA Integra
- WTB: Integra Brake Booster (DC chassis)
- WTB 2 pair of 90-91 Civic EX front knuckles
- Looking for springs Sportlines for a 96-00 Civic.
- WTB: 96-98 SIR OEM REAR BUMPER FOR COUPE/SEDAN
- WTB GSR Swap
- WTB: Full B16B CTR Longblock/Full swap Maybe
- 92-95 civic parts
- WTB: Super clean EK Dark Gray Carpet
- WTB: T1R midpipe or similar
- WTB: prelude h22 parts
- WTB: ARP main studs B18c
- WTB civic/integra parts
- wtb b-series swap cash in hand
- WTD: Eagle rods, Forged pistons, ARP, Walbro,Skunk 2
- WTB: P05 P06 P09 OBD1 ECUs
- WTB: D15b2 Oil Pan
- anyone parting out a 99-00 dx or cx?
- WTB: ARC TITAN OVAL SHIFT KNOB.
- D16Y7 Exhaust Manifold / Catalytic Converter
- WTB: JDM Integra Type R Championship White 16inch rims
- WTB: Passenger side power mirror for '04 Civic EX Coupe
- WTB: JDM Power Folding Mirrors for 94-97 Accord Sedan
- WTB:44mm or bigger waste gate Tial
- Wtb 88 to 91 civic Si
- Wtb em1 front and rear camber kit !!!
- WTB: 4.4FD ITR or CTR transmission
- WTB: AFI or FULL RACE, turbo manifold, NEW**
- wtb em1 driver bracket mount and ac bracket for ek b swap
- MOROSO OIL PAN
- FBP Em1 Trunklid and Grill
- WTB: 44mm dump, flange, clamp
- bogart fly star lugnuts
- WTB b series injectores
- Wanted: Brand-New Titanium ARC Ball SHIFT KNOB
- QSD H2B kit
- WTB: B18C block
- WTB shift knob,3" muffler, lower control arm for ek hatch
- WTB: ITR 4x114 Wheels
- wtb crx interior
- WTB: ABS removal 94 GSR
- WTB:5 lug disc conversion
- WTB: 96-98 OBD2a Ex 5spd wiring harness
- WTB LS-VTEC Del Sol parts
- WTB: OEM Si lip, grill, and other parts
- WTF: JDM OEM 96-98 SQUARE CLEAR FOG LIGHTS (PAYPAL CERTIFY)
- wtb hondata/omnipower 4bar map
- WTB (1) 99-00 Si Wheel (DFW area)
- DC B-Series Header for an LS.......
- WTB: OBD1 injectors
