View Full Version : Want to Buy
- WTB: VIS CARBON FIBER SPOON LIP FOR 98+ DC's
- WTB: White(ferfered) 88-89 Crx hf driverside fender
- WTB:$ GS-R BLADES in So Cal $
- WTB: EG Passenger Door SOCAL
- WTB: 99-00 Si Driverside mount ASAP !!! (So. Cal)
- WTB: APEXi N1 silencer
- WTB: ignition switch
- WTB:90-93 Integra bodyparts
- WTB: IACV
- wtb: 99-00 civic si harness
- WTB: Eibach Pro-kit springs for 90-93 integra ..
- WTB: Brnze TE37 Cnter Caps
- WTB: 93~95 Civic EX doors (Black)
- WTB: D-series tranny w/ no grinds, so cal?
- WTB: (((TAN))) 92-96 Honda Prelude Front Seats...WANTED*
- WTB: I NEED EG COUPE PARTS--oem clock, oem rear speakers, more
- WTB: ES Oval muffler
- WTB: 99-00 SiR cluster for parts/broken speedo or tach
- WTB: 97 Integra Fender Liner
- WTB: 90-91 Civic Gauge Cluster w/ TACH NO AUTO
- WTB: 5th Gen Accord Gauge Cluster
- WTB: YOUR 15" GSR BLADE RIMS!
- WTB: 98-01 DC2 Milano Red Front Bumper in SoCal.
- WTB: WANTED FULL INTEGRA INTERIOR 1996+
- WTB: 90-91 hatchback SI
- WTB:91 CRX Si tranny
- wtb: 94-97 master window switch
- WTB: HF / CX / VX / STD Manifolds..
- WTB: GSR/ITR water pump
- WTB:00 si cluster
- WTB: OBD1 harness pins for VTEC wiring
- WTB: 99-00 civic fender!
- WTB: Carbon Fiber Hood for '94+ Integra
- WTB: Black 15/16" Rota slips with tires (2 sets)
- WTb: b20a head
- WTB: F22b1 or F22b2 long block or swap
- WTB: 88 CRX SI wiring harness, complete and uncut
- WTB: 96-98 CTR HEADLIGHTS AND CTR FRONT LIP....
- WTB: Frost White Integra(DC2) hood [S. Cal]
- WTB:ls gude-crower-pyr camshafst for a allmotor ls
- WTB: 98 above LS engine wire harness, ECU, injectors and distributor.
- WTB: Civic 96-00 camber kit
- WTB: obd1 gsr distributor
- WTB: SideMarkers, Lip, Intake Filter SoCal
- WTB: **94-95 GSR KNOCK SENSOR**
- WTB: 94-97 Integra ABS Unit
- WTB: CRX HF Engine - WILL PAY CASH AND PICK UP - CONNECTICUT AREA!!!!
- WTB: DA trailing arm and knuckle
- wtb: P30 ECU AND EG PARTS
- WTB: VAFC
- WTB:1 new/used rear-JIC FLTa2 for ITR LCA, yes you heard me 1 coilover!
- WTB: Both front inner fender covers for 99' Civic Si.
- wtb: d series header
- WTB: gsr girdle with # 2 3 4 maincaps
- wtb:crower-gude-pyr- ls b20 camshafts....
- WTB: RSR HEADERS OR EX MAG
- wtb: jdm gsr complete short block
- WTB: oem sunroof visor and window visors for eg SOCAL
- WTB: Pentium laptop
- WTB: In So Cal...C'F Hood, front lip and Hatch for 92 Hatch.
- WTB: magnaflow e's style or any oval aftermarket muffler
- WTB: B Series Spark Plug Cover
- WTB: i need a rear motor mount bolt for my civic diagram inside
- WTB: civic 96-00 rear hatch shocks and 96-98 climate bezel
- WTB: CF Lip or Any Black Plastic Type Lip for EK Coupe in South Carolina Area
- WTB: master cylinder brace SOCAL
- WTB: HONDA CRV B20 BLOCK
- WTB: Block posting studs
- wtb: b16 tranny with lsd installed asap
- WTB: Clutch/flywheel combo for B16a2, Clutchmasters, toda, spoon, or exedy
- WTB: black dc clock
- WTB: USDM OBD-1 P72 GSR ecu
- WTB: mugen oil cap, reservoir socks, radiator cap
- WTB: CRX HF harness
- WTB: 15'' SPRINT CPRs ***SOCAL****
- WTB: CRX swap parts (mounts, linkage, etc...)
- WTB: brake caliper!
- WTB: Carbon Fiber Hood for '94 Integra
- wtb:90-93 teg axles, civic radiator, p28/p30 ecu ASAP
- WTB: Spoon Sports EK Gauge Cluster - or Will Trade My EK Civic Type R Cluster + $$$
- WTB: Bronze Konig Helium 15"
- WTB: NEW ZC Pistons w/ rings and wristpins
- WTB: OBD2 JDM RHD Right Hand Drive Engine Harness
- WTB: ITR 5 lug conversion. NEW YORK
- WTB: NEED DEL SOL DRIVERS WINDOW SOCAL!!
- WTB: OBDI P28 ECU Stock or Chipped, but Ready to Run!
- WTB: Hood, Fender, Bumper for 92 Civic Hatch (montreal/Ontario Region)
- WTB: Black Leather Armrest...
- WTB: Spoon Sports 15x6.5 4 lug
- WTB: EK center console *dark gray*
- WTB: 94 integra ls exhaust
- WTB: 90 SI HATCH PARTS? ANYBODY GOT SOME PARTS LAYING AROUND?
- WTB: crx motor
- WTB: 94-01 GSR LCA's
- WTB: JDM EG6 Blue Badge!!
- WTB: OBD1 ecus, damaged or VERY cheap!
- WTB: 15" steelies w/ winter tires
- WTB: 99-00 Civic Si B16a2 driver side mount bracket with the studs.
- WTB: 94+ B-series Lower Tranny Mount
- wtb: Seat Covers, OEM 94-01 Integra black or grey cloth
- wtb: another jdm front for my car *crashed*
- WTB: Secondary o2 sensor for 2000 civic ex
- WTB: black eg steering column shroud, non abs integra prop. valve, black teg climate control
- WTB: 00 SI Civic 5-lug conversion needed
- wtb: d16a6 intake manifold ASAP!! Socal picked up!
- WTB: 98-01 Integra Black Leather Door Panels (CA)
- WTB: B16a knock sensor and cam gears.
- WTB: VSM door handles
- WTB: Gunmetal USDM ITR Rims w/tires - (CA)
- WTB: 98+ JDM ITR TRANSMISSION! NEED ASAP!
- wtb: various b series brackets
- WTB: OEM 1991 CRX Lower Bumper Lenses
- WTB: B16a VTEC head
- WTB: Steering Wheel Hub for 92-95 Civic
- WTB: J's Racing Intake 99-00 SI
- WTB: Recaro SRD or Speed seats
- WTB: J's Racing Engine Damper for DC2
- WTB: 94-97 integra stuff (bumper, fenders, etc.)
- WTB: Front torque mounts for a B16A2 (SI)
- wtb: virgin p75 obd1
- WTB: new or used 60-70mm throttle body for b16
- WTB: Benen Rear Lower Tie & Greddy oil catch can
- WTB: Front lip, 99-00 tailights, Foglights and SI center caps
- WTB: 92-95 civic 2dr Black OEM hood
- WTB: Blades in Ny/Ct/Pa Area
- WTB: 99-00 JDM CIVIC SI GAUGE CLUSTER
- WTB: ITR crank
- WTB: B18C1/C5 Oil Pan
- WTB: LS CRANK!! NEED ONE ASAP
- WTB: EK interior parts/pieces
- WTB: 96-98 ek fender linings
- wtb: B16 Head
- WTB: Integra OEM Sides/rear ANY PAINT
- WTB: hondata s200b
- WTB: Tein SS coilovers for CRX Si
- WTB: 90-91 crx turn signal!
- WTB: p72 GSR ecu
- WTB: 92-95 Civic 2DR Wings West RS Lip Kit
- WTB: Rota C8's hub cap
- WTB: 1 front Integra coil spring
- WTB: 1 Takata 340R harness
- WTB: 5 Lug Conversion/Brake Setup-- USDM ITR or JDM CTR
- WTB: 92-96 prelude manual shifter assembly with cables. Need ASAP
- wtb: 93 civic hatch. dimmer switch
- WTB: 98-02 Honda accord OEM CF hood
- WTB: Honda civic ex Stock front lip
- WTB: AUTOPOWER street-sport roll bar for eg6
- WTB: authentic mugen front lip for 99-00 civic
- WTB: DC2R shift knob
- WTB: d15b7 cylinder head...USDM..non-Vtec
- WTB: VSS (speed sensor) for 95 GSR
- WTB: JDM GSR Cat Flange
- WTB: Knock Sensor
- WTB: I AM LOOKING FOR A STOCK RADIO FOR 98 ACCORD.
- WTB: GSR Shift Knob and Del Sol seats
- WTB: door trim piece (see pic)
- WTB: 99-00 civic driver engine mount ??????????????????
- WTB: OEM Honda/Acura Shift Knob (Leather w/ Red Stitching)
- wtb: d16z6
- WTB: D Series Block.
- wtb: 92-95 civic charcoal evap canister thing
- WTB: A/C Compressor Pulley w/bearing
- wtb: chipped p28 with hondata s100 or s200 system
- WTB: 92-95 oem cat
- WTB: genuine mugen lip for EG or Spoon/ spoon style lip
- WTB: b18b bottom block with pistons etc, etc..
- WTB: JDM eg6 window visors
- WTB: 04-05 Honda Accord EX rim
- WTB: si harness asap!
- WTB: 92-95 civic doors
- WTB: Rear disc rotors 4x100
- WTB: Cvcc Mugen valve cover, any Mugen parts for old school Cvcc or 1200 Civic.
- WTB: brackets, harness, and misc stuff for integ and crx
- WTB: Del Sol Seats.. NON red stripe
- WTB: rota group N
- wtb: 1988-1991 Civic Si (white)
- WTB: 94-95 usdm b16 intake manifold and TB and P30 ECU( 94-95 DOHC Del Sol)
- WTB: 99-00 Spec JDM Civic Type R ECU
- WTB: Stock 92-95 Civic Taillights!!
- WTB: D-Series tranny (Connecticut, Tri-State, and Surrounding Areas)
- wtb: metal jdm type-r front end conversion for 1996 Acura Integra
- WTB:aem uego(gauge)
- WTB: integra stock Resonator
- WTB: complete b18b swap for cheap
- WTB: stock tsx header
- WTB: 99-00 civic HB OEM Tail lights
- WTB: SICK Spoon Parts only! Cluster l Tow Hook l Seats
- WTB: d16z6 arp headstuds, headgasket, oil pump, water pump
- WTB: 96-01 Honda CRV Gauge Cluster
- WTB: D16a6 intake manifold and misc parts - Socal
- wtb: 96-00 civic access floor mats
- WTB: Complete STOCK CIVIC 92-95 1.5 - 1.6 motor swap
- WTB: '98-00 Honda Accord OEM front LIP (Coupe)
- WTB: 88-91 dx hatch window glass
- WTB: cwest, greddy, parts for my civic
- WTB: Zex Nitrous Management Unit
- WTB: 90-91 CRX complete doors
- WTB: OBD2a EX Distributor, 96-98 EX ECU, 92-95 Civic D-series Mounts
- WTB: rota rims
- WTB: O2 sensor '98 Integra
- WTB: D Series Eagel RODS ASAP!!!!!
- WTB: FRONT SWAY BAR
- WTB: 5th gen prelude parts
- WTB: stock 99-00 SI cat
- WTB: Stock EK Suspension - Southern California
- WTB: Set of Mazda 9 Spokes Melenia Wheels in the Bay Area or...
- WTB: 99-00 civic SI rims so-cal
- WTB: 92-93 Integra engine harness and engine to ECU harness!!
- WTB: 2001-UP CIVIC EX AUTO STOCK INTAKE !!!!!!!!! (DALLAS)
- WTB: B16 tranny
- WTB: B series Axles , H22a, h23a axles , RSX axles Broken axles too!!!
- WTB: LS Tranny Blown - I need the Case only
- WTB: 99 civic si headlights, rear bumper, and 96-98 tails
- WTB: 5x114.3 Volk TE37 (15" or 16") or Evo Regamaster same size
- WTB: Jdm Hid DC2 Front end (must be around bay area)
- WTB: 2000 INTEGRA BLACK LEFT,RIGHT REAR INNER QUARTER PANEL AND PANEL BEHIND TAILIGHT
- WTB: 96-00 CIVIC IGNITION WITH KEY
- WTB: B-series AT in NorCal by Friday
- WTB: 92-95 Driver Side Recaro (Wedge) Rail + Slider
- WTB: Apexi Rev Speed Meter!!! Sooner the better!
- WTB: stock cat for a 2nd gen integra
- WTB: stock civic injectors, Vtec solenoid
- WTB: Adjustable cam gear for D16A6 EF Si SOHC non-VTEC
- WTB: Complete GSR or LS (2000-2001) Swap
- WTB: ex or si doors
- WTB: Cargo Cover for 96-00 Civic HB SOCAL714
- WTB: integra motor mounts (driver side), starter, and center console and armrest
- WTB: 99-00 Civic Si Front Bumper and Lip, Fenders, and CTR headlights
- WTB: 90+ Integra or 92+ Civic in WA
- WTB: DX Motor
- WTB: JIC titanium muffler....110mm tip or bigger
- WTB: ONE 35w HID ballast
- WTB: 2004 Honda Accord 16" 7 spoke wheel CENTER CAPS
- WTB: Black BENEN products for EK...Lower tie bar, tow hook, strong bar, Etc.
- WTB: CA: 94-up GSR Black Leather Front Seats.
- wtb: rollcage for 00 civic coupe
- WTB: 16-inch Rota Grids or Subzeros
- WTB: 16" rims with polished lip like rota gt3's
- WTB: Need a D16y8 compatible 5sp tranny close to WASHINGTON
- WTB: 96-98 Civic Dx ECU !!!!!!!!!!!!!!!!!
- WTB: Looking for a set of Steelies (Donuts) w/ Tires
- WTB: 94 LS Cat *Bay Area Preferable*
- WTB: RSX dc5 Skunk2 coilovers & camber kit
- wtb: ITR short ram aem intake for cheap
- WTB: busted hydro b series tranny (good case a must)
- WTB: Rotors, pads, passenger fender, passenger door
- WTB: D Series Swap and 92-95 Civic A/C - i am in Orlando
- WTB: JDM or USDM Stock EG Headlights So Cal
- WTB: HF front swaybars
