View Full Version : Want to Buy
- WTB: 4x100 Steelies + Tires
- Looking for any aftermarket Intake manifold for a Gsr
- wtb: 92-95 Eg civic 90-95 integra manual parts
- WTB Drivers side molding for 90 crx
- I NEED A PRC ECU ASAP
- NEED ASAP *** H22a MAP sensor***
- wtb: ctr cams
- Rear Calipers (Civic / Integra)
- wtb: ef/eg/ek shell la/tx/ark/ms
- wtb 97 + Prelude sh atts unit sensor
- stock 1991 civic si front lip
- WTB eg hatch si shell close to utah
- wtb 96-00 civic light gray passenger side airbag and the thing that holds the sun visor in place
- WTB resistor box asap
- WTB H22 transmission.
- JDM CRX PARTS - MUGEN CRX KIT
- Crower rod for B18C
- WTB: Viper Alarm, B Series Header, Intake manifold, KYB AGX or Tokico Illuminas
- NEED 01-05 Passenger side ABS sensor ASAP!
- WTB: 96-97 Accord Coupe pasenger door and fender!!
- wtb: RHD crx firewall swap
- WTB: 17" RIMS & TIRES
- WTB : In PA , Dx or SI cable trans. 89-91 not 88
- wtb runing sohc vtec d16z6/y8
- WTB: integra 94+ Aftermarket Rear LCA"S
- WTB: 94-97 Accord Rear SeatBelts TAN
- i need just 1 ctr piston
- b17 rods
- WTB: Precission PT70, BW372, 42R
- 92-95 ex coupe sunrrof assembley
- WTB; RSX SEATS
- OBD2b engine harness 99-00 civic si ex uncut & ECU
- WTB: D-Series LSD transmission
- WTB: P30 pistons & P30 or PR3 Rods
- WTB: S2000 factory radio
- NEEEEEED!!!! EK h22 swap motor mounts ***********
- WTB: 04 style TSX wheels
- WTB: Z6/Y8 Head
- WTB: Apex N1 catback for 01gsr
- WTB: UKDM EDM CIVIC rear fog lights
- WTB: 98+ Spec ITR Swap - Type R
- WTB front parts,crossmember,airbag for 06 Civic sedan
- WTB: jdm itr cf hood
- WTB: 92-95 Coupe/Hatch driver side mirror
- Wanted: Couple Crx Parts
- Wanted: Acura Integra Blades In So Cal
- WTB ready to use 94-01 LS crankshaft
- WTB: Single cam passenger side axle
- nedd stuff asap
- PLEASE LOOK wtb:ssr schumacher caps/ek optional ashtray/ignition cover light/bumper pole part/ + mor
- wtb: alpine head unit
- WTB: backdoor intercooler piping
- I need this bolt... single cam valve cover bolt (long one)
- ekei 92 replicas
- wtb slipstreams
- NEED ASAP - DC/EG front driver side strut fork
- WTB: Del Sol VTEC ECU
- WTB. One (1) Rota Slipstream 16x7 4x100 Any Color. So Cal.
- WTB: Chip burner / reader Moates Burn1
- WTB: 96-00 Civic 4 Door Driver Side Subharness/Plug
- wtb ls motor or d series motor must be low millage automatic
- WTB: 1999 Honda Civic 4 Dr window regualtor
- WTB: PG7 ECU.
- WTB: H22 IACV (western WA)
- WTB: EG left power mirror
- WTB front lower control arms for swaybar!!! EG
- WTB: DA mounts
- WTB: MI: Stock steelies 4x100, rear disc conversion, 99-00 Si cluster
- WTB>>> ZEX Nitrous JETS!!! .030 and .026
- WTB: Axis OG Oldskool WHITE 15x8 4x100
- WTB....GSR clean crank w/ no spun bearing mark
- WTB: Transmission for an 89-91 Civic D series 5 speed.
- WTB 99-00 OEM Si Grill.
- WTB 98-01 Integra tail lights for passenger side
- WTB Integra Axles
- wtb: 94 integra 2dr main cabin harness, NOT dash harness
- WTB GSR Blades Nashville TN
- WTB: 88-91 CRX rad support
- WTB: CIVIC VX ENGINE D15Z1
- WTB: 92-95 Civic Wiper Switch & Blue Int. Door Handle
- few civic parts....
- WTB. CTR CAMS,AFTERMARKET VALVE SPRINGS,REATINERS, AND TALLIGHT FOR AN EG
- WTB: Torque mount, right - EG/EK/DC
- WTB d16y8 intake manifold injectors, civic IACV, 96-98 ex wiring harness, obd2A-obd1 harness
- WTB: BAD P28's and P72's....$70
- wtb: b18c1
- WTB: 96-00 EK Door Panels.
- WTB MAin Harness for 96-up integrA GSR OR 97-UP ITR......
- WTB: 99 Civic Maunal Pedal Assembly
- wtb body parts
- WTB: OBD2 B18c1 lower timing belt cover
- WTB B18b BLOCK!!! NEED ASAP!
- WTB/WTT: LS B18B1 Head!!!
- WTB: K swap parts for EG
- WTB: NA1 NSX Calipers
- WTB: 2.25" Catalytic Converter
- Wtb: 99-00 Si OEM catback
- WTB: ITR rear seats and 5 lug
- wtb: stock gsr shifter
- wtb: 15" rota jmags
- Wtb Gsr Blades
- running d16 motor and parts: lowballers welcome
- WTT: Rsr Exmag Axleback For EG hatch for Spoon N1 Axleback VA
- WTB: NRG Quick Release Hub
- WTB: rust free, accident free 88-91 crx!
- WTB EG interior parts
- wtb LS or b20
- WTB: red torino sparco seat
- 12mm Crush Washers for banjo fiting on fuel rail.
- need h22 lower timing cover and or gasket - ohio
- WTB OBX LSD for B16 trans
- WTB d16y8 driver side engine mount.
- WTB: 96+ civic hatch side skirts
- WTB: bys wing for eg
- WTB 94 dc Integra interior parts
- WTB-B16 Trany case
- Looking for some grey door panel with power windows with the switches.
- WTB: B16 hydro tranny or second gear gearset (2.105) for b-series
- wtb: garrett 57 trim, hks bov, clutch, intercooler piping
- WTB: Aluminum Cylinder Heads
- WTB: passenger side mirror for 1994 LS Integra
- MD: WTB (2) Two Kumho Ecsta 712 205/45/16
- WTB P75 OBD2 ECU
- WTB ONE GSR BLADE
- WTB: 92-93 obd1 engine harness
- wtb wheels
- WTB: '94-97 Integra Full Nose Mask (Bra) or White Bumper
- acura EL center console
- WTB Skunk 2 Pro 2 Cams or Some Stage 3 Cam....
- sir ek4 rear glass spoiler for hatchback...
- BYS Carbon Kevlar Front lip (EG)
- WTB: RHD DC Integra NY
- WTB 1997 2dr Civic hood Black
- WTB-b20-transmission-seats-wheels...Etc
- WTB: D16Y8 crank pulley NY
- WTB 01 ITR 02 Sensor
- WTB: 1 probe piston for b18b
- WTB: 14 inch mugen cf48 greyish/silver with center cap 1 or a pair
- motor parts
- WTB: 52mm greddy black face egt gauge
- WTB Integra LS B18B1 2-1 header piece and oil pan
- WTB OEM Lug Nuts and Wheel Lock
- WTB mounts for EF (crx)
- WTB: AxleBack/exhaust (pref ITR)
- WTB B16 99-00 SI power steering pump or equivalent
- WTB: P30 (B16A) AC condenser Bracket
- WTB D16y8 intake manifold
- ARC shift knob for Honda Civic
- WTB: OEM Type R sideskirts and rear valences
- WTB: D15b7 distributor
- WTB: 02-04 RSX Type S cat!!
- WTB: GSR Reverse Change Assembly & 1-2 Shift Fork
- WTB: del sol corner light
- Looking for SHELL
- wtb: DC2 gsr lower timing belt cover
- WTB EG Gauge Cluster EX/SI 5sp
- WTB: Type R replica or Q8 wheels
- Wtb seats around Pensacola FL area
- WTB: ARP extended studs / OEM civic hatch (eg) car cover / black (eg) carpet
- WTB: 99-00 Civic Front Bumper, Si, Hatchback, OEM
- wtb:y7 piston and rod
- WTB OEM ITR CAT BACK EXHAUST
- WTB OEM ITR FPR
- WTB - Tilton, Clutchmaster, Competition Clutch - Twin Disc
- WTB 96-00 civic coupe or hatch .
- WTT MY USED skunk2stage2 cams and s2 valve train for oem itr cams/valvetrain
- WTB Gauge Cluster
- WTB> 92-95 Hatch Rolling Shell! near PA/MD
- wtb: 1 hx rims only
- WTB ALL Turn Lights and Bulbs! (And Windshield!)
- WTT: 05 yamaha R6 for K swap
- WTT my ls swap for your b16/gsr swap
- WTB: stock b16 or gsr short/long block only! No built shit, half ass rebuilds or poor man type r bui
- Bare stock closed deak h22a block
- WTB: B SERIES HEADERS! something diff. than ITR!
- WTB: Timing belt covers for B series
- wtb ctr stuff
- WTB DOHC ZC Intermediate shaft
- WTB: left inner 99-00 civic coupe taillight
- WTB 94-97 accord interior parts
- 95 civic ej interior or swapabble interior
- 99-00 d16y7 uncut harness
- WTB...BLACK OR RED RECARO DRIVER SEAT ASAP
- WTB EK driver side swap mount braket
- WTB: P28 W/S300 BOOST
- WTT: Chipped p28 for a Obd1 P30 B16 ecu ASAP
- WTB: 5x114 wheels for the s2k
- wtb:y8harness,dizzy plug
- WTB: 99-00 Civic D16Y8 Long Block
- WTB: 96-00 cvic coupe black floor mats
- WTB knock sensor for gsr
- WTB: Comptech Header For GSR
- WTB/SOCAL: B-Series Vtec Sloenoid......ASAP!!!!!!
- hx rims
- WTB: 88-91 cable SI tranny
- WTB : AEM Tru Boost Controller + AEM Wideband
- WTB: B series valve cover and/or spark plug wire cover
- Wanted 4 lug rota slip streams
- I Need a b18c1 complete-semi complete short block, cams for dohc gsr head as long as its for a gsr h
- WTB LOW COMPRESSION PISTONS
- WTB Inlinepro turbo manifold
- WTB: Looking for a car for the winter under $1,000
- WTB Pistons
- WTB: mounts
- WTB: EG hazard switch & dimmer switch
- WTB: 98 Integra LS parts
- B series g/box rebuild parts
- WTB: HX Wheels and Tires, southern NY!!!!!!!!!!
- H22 Sleeved Block and Port Polished head
- WTB: ARP
- WTB: 96 Honda Civic 4 Door Power Window Switch (Main)
- wtb:moldings/weather stripping/etc
- WTB: 2 front shocks 01 Integra.. tokico kyb
- WTB: DA Hood and hatch + jdm 1 piece headlights
- EG Coupe Bumper, Hood, Corner light and Headlight
- WTB: CRX Dual Din Bezel Frame
- BLACK EG CENTER PIECES BETWEEN SEETS
- WTB: Speedo Gear for my 99 si or the diff out of a b16 b18 trans
- WTB: RAYS Valve Stems
- WTB: DC5 2-1 exhaust portion
- 92-95 civic
- WTB: 96-00 Honda Civic Lowering Springs
- anyone have a rhd DA for sale??? please post pics and price >< thank you. appreciate it.
- wtb: apple iphone
- WTB: TIAL Wastegate 38MM
- WTB: 94-teg,gsr stock radiator
- WTB 98 Integra 2 door driver window regulator
- WTB: 92-95 ex/si engine wire harness
- WTB: EG cluster & steering wheel..
- WTB: CTR Power Folding Mirror Switch (Dark Gray) *CA*
- WTB: 2000 si ebp drivers side fender em1
- wtb eg coupe headliner
- WTB: 17'' RSX type S wheels (5 spoke) Maryland area
- WTB coilovers for 92-95 coupe Tein, F&F, Omni, etc around $500
- wtb: 94-97 Integra steering rack coupler and possibly rack.
- WTB: Integra 90-93 LS Aftermarket Intake Pipe (3")
- Buying 99 civic lx light grey passenger seat
- WTB cRX si Front bumper support
- wtb: h2b header
- WTB D16A6 oil pan
- WTB: OEM Front Brake Lines 96-00 Civic
- WTB B16a gen 2 Longblock
- WTB: 1 eagle rod for b18b...
- wtb IACV for The SIR2 b16
- wtb: jdm theory windshield banner/normal windshield banner
- WTB: Skunk2 Pro1's!!!
- WTB; asap nose mask or hood bra for eg civic or trade
- WTB: 90-91 crx mudflaps/splash guards
