View Full Version : Want to Buy
- WTB!!! i need a GSR transmission
- WTB- K Series converted wiring and charge harness for eg
- Im looking to buy or trade a good working turbo kit for my b18b1
- LF turbo parts.
- Eagle H-Beam Rods and Vitara Pistons
- WTB: intake for 91 hatch b16
- WTB 00-01 GSR Rocker Assembly
- WTB: OEM 1999 Accord radio
- WTB: stock K20 pistons
- WTB: Momo Hub 94-01 Integra/ 92-95 civic
- WTB: 90-91 CRX SI Left Tail Lamp & Swirly Wheel Center Caps
- WTB: 92-95 civic brake lines
- WTB: OEM 96-98 Coupe Wing
- us oem integra type r seats
- WTB: 92-95 Civic Hatch - Axle back / Muffler
- WTB: Brake booster for 94-95 civic no ABS
- wtb/trade: b series rod, main, and thrust washer, arp rod bolts, headgasket
- WTB: RSX OEM Shift Knob and Neck connector
- WTB: 01-05 Civic Parts/Motor
- 96-00 CIVIC EX(W/TACH) CLUSTER
- WTB: Blown z6 block or z6 with mains+ crank
- WTB: OEM ITR Springs (Suspension) & Shift Knob
- WTT B18C JG Victor X for B16 Victor X
- WTB Integra DC2 black interior pieces
- WTB: WINTER BEATER NJ
- Integra auto tranny?
- Parts needed for mini me swap .....ASAP
- wavetrac LSD for k20
- WTB b-series wiring harness.
- WTB Integra seats close to the FL
- WTB Full axle-back exhaust
- WTB - 86/87 CRX Si Final Drive Set
- WTB BLOX INTAKE MANIFOLD
- PA WTB Skunk2 stage 3 tuner series cams
- FS/WTT Buddy Club Spec 4 IV's for your ITR/CTR cams
- 96-00 Civic Airbag Clockspring
- Wtb rims/wheels Si, blades, fat fives, ect...
- wtb: b16 hydro
- WTB Civic EG Audio Console
- Wtb:iacv
- WTB P72/P30 upper power steering bracket
- WTB Steering wheel hub
- WTB: obd2a P72 ECU (USDM) !
- WTB: B16/type R head
- WTB: Bride Low Max Seat Rail for GE8
- -:WTB:- 91 si side moldings
- valve cover
- WTB H22 crankshaft
- WTB H2B HEADER
- WTB: Set of Enkei Silver RPF1 16"
- WTB Sun Visor Clip Gray
- WTB 92-95 civic EX/DX Cluster
- WTB h series fuel rail, crank pully,dizzy LOOK!!!
- WTB-Complete VX swap
- WTB any OEM honda 5 x 120 rims
- WTB MD: Subframe, AC, Center Console and Radio thing lol
- WTB: Ac Compressor
- WTB Keyless Entry Remote for 99 Civic LX
- .:.WTB.:. Integra cluster plugs/pig tails & 92+ Electronic VSS
- GSR/B16 Lower Power steering Bracket!!!
- WTB EBP EM1 body pieces please (OH)
- WTB: 92 Civic DX parts
- D16Y5
- WTB: B-Series Cable transmission VSS Vehicle Speed Sensor
- WTB: CRV Crank Pulley
- looking for del sol!
- wtb: lug nuts m12 x 1.5
- WA WTB Suspension DC
- WTB B SERIES BREATHER KIT, DRIVER SIDE SRD LOW POSITION SEAT RAIL
- WTB: built z6 motor for turbo!
- wtb: integra type r armrest
- WTB: B18B Motor for 99 Integra LS
- Looking for 15" enkei 92's mesh type wheels
- WTB- CHEAP HONDA!! SCRANTON, PA
- WTB Turbo Z6 Head paypal ready
- WTB: eg hatch passenger fender
- WTB Del Sol Climate Control with AC
- WTB: Acura legend 93-95 front brake caliper dual piston
- WTB Valve Spring Retaining Locks
- '96-'98 Civic Hatchback Rear License Plate Frame
- WTB: Any Honda daily driver with no rust. Blown motor/trans?
- 92-95 eg parts wanted
- WTB: 1 GSR Blade Wheel
- SOMEONE HELP PLEASE
- WTB Integra SI VTEC Lip
- WTB: H22 Mugen Header/Exhaust
- D16y8 head asap
- NEED DASH HARNESS AND ENGINE HARNESS AND FRONT SUSPENSION PARTS FOR A 92 CIVIC HATCH!
- LOOKING FOR: CTR EK9 RED HONDA EMBLEMS!!!
- 1996-97 Del Sol front bumper
- Car - motor = Yes
- WTB: Prelude H22A4 Injectors (290CC OBD2) 100$
- 99-00 fog light lens cracked
- WTB : AUTO > MANUAL CONVERSION MOUNT
- WTB: K20a2 Head parts
- wtb:acura el gauge cluster/speedo
- WTB LS swap
- 99-00 Si d (sway bar) subframe brackets
- WTB:: 91 civic si corner and Front bumper lights
- WTB rear mud splash guards for 90-91 civic ef
- wtb: dc4 rear sway bar
- Need 99-00 Heater and AC Climate Controls.
- COMPLETE H2B adapter KIT
- skunk2 tuner 3 camshafts for b series
- WTB 92-95 Civic MT vehicle speed sensor VSS
- WTB: JDM EF8 CRX Front Bumper
- WTB ''90 Integra Distributor
- WTB CRX DOOR WANTED
- 99-00 si p/s pump and brackets.. a/c comp and lines
- WTB LS power steering bracket..
- WTB: Edelbrock Performer X D16 intake manifold
- WTB: 99 or 00 Civic Climate Control
- 1 black recaro pass. side
- Need a ac bracket for swap d compressor to b18c1 engine
- D16Z6 WANTED!!!!!!!!!!!!!!!!!
- WTB: Eg6 Parts
- WTB: P61 ECU
- wtb gsr ef project stuff
- WTB del sol rear spoiler
- WTB: RHD throttle cable for DC integra ASAP
- WTB Del Sol Suspension and Headlights parts
- look'n for a 88-91 civic sedan
- WTB: B16A2 Crank Position Sensor
- wtb ek jdm thin molding for fender
- WTB: 96-98 DX Civic exhaust manifold OR full EX exhaust swap
- WTB: DC4 teggy tail lights harness/gaskets
- DB Mudguards
- WTB Turbo/Parts for home made build
- WTB CLEAN ACURA INTEGRA 4k to spend
- WTB: Innovate or NGK wideband
- Turbo items needed
- WTB: Valve covers - all kinds b16/b18/d16/f22/k20/h22 etc
- wtb: crx under dash fuse box
- WTB: si muffler or es oval
- WTB:Looking to buy EM1 civic SI
- WTB: B18c1 GSR OBD1 Dizzy
- WTB: Shift knob for DC
- WTB: Del Sol Vtech DOHC shift linkage
- wtb bseries thermostat housing and fan switch socal sgv
- WTB P73 Oil Pan in Los Angeles
- WTB ac hose - Discharge Line (high side)
- WTB: 2 or 4 15" Rotas
- WTB: ITR Intake Arm
- WTB: Greddy Emanage Ultimate
- WTB:Front & Rear Tow Hooks
- Needing a D16y5 distributor for 98 Civic HX
- WTB crower 403 cams
- WTB: Precision SC6262 Billet JB T3 Turbo .82 V-Band
- WTB:96-98 Civic Ex engine harness and a z6 vtec solenoid
- wtb a pair of 75mm Apexi exhaust silencers
- ID: WTB: s2000, prefer hardtop
- Ek hatch exhaust located in md
- WTB Manley I-beam rods for LS 14412-4
- WTB: b series carbon fiber plug cover
- Western MA - WTB 4 steelies, 14" !!
- WTB: Si Vtec Integra corner lights
- wtb d16z6 main cap/crank caps
- WTB or WTT: 88-91 Honda CRX
- WTT Ipod touch 32g 3gen
- WTB - GSR Exhaust
- WTB: EXTENDED top hats for my coilover set up!!!!!!.
- WTB B SERIES VTEC HEAD COMPLETE
- wtb crx y49 Barbados yellow driver side fender
- WTB: DC2 MUFFLER
- wtb adjustable test pipe
- WTB: Socal Stock steelies with tires
- WTB BUILT B SERIES HEAD VTEC
- WTB ITR in the Northeast....
- WTB: skunk2 pro1's (b-series)
- WTB: d16z6 crank pulley AND key
- WTB: steelies and nice hubcaps (honda ones)
- WTB: few 95 integra parts
- WTB: 97-01 Honda prelude Coil
- WTB: B16A2 or B18C5 TB
- WTB MAP Sensor
- Need b16, itr, or gsr MT transmission.
- WTB: OBD0 to OBD2a Jumper Harness
- WTB stock exhaust
- z6 bottom end needed in southeast Idaho
- Wtb daily driver or beater! Civic or integra
- WTB INTEGRA STUFF AND B-SERIES PERFORMANCE STUFF
- WTB: EG Manual Steering Rack 92-95 Civic
- WTB: EG6 rear interior
- WTT: Full 3" exhaust for full 2.5"
- Wtb d16z6 crank pulley and key
- 92 to 95 civic rear oem spoiler
- WTB: 90-93 Integra Coilovers
- B16/itr tranny gears
- any sponsors want to hook me up? cam gears arp head studs fuel pump
- WTB 00 Civic Si B16 T- Bracket ASAP
- WTB EP3 interior
- WTB: 22mm crank pulley D15B2 x2
- WTB: Ef b-series mounts
- WTB: jdm decat
- WTB: D16Z6 Long Blocks
- WTB:Passenger side motor mount for 05 accord ex
- WTB: EG coupe parts. local or ship
- LS VTEC Parts, B series Trans, Intake Filter, EG Windshield Trim
- WTB: Integra GSR Black Leather Drivers Side Seat (SO CAL)
- CRX/ aftermarket LCA's/front@rear camperkit
- WTB..92-95 eg/ej sway bar
- WTB: Ef civic coilovers
- Computer Search
- WTB: OEM S2K HARDTOP!
- WTB: Catch Can!!!
- WTB 99-00 civic harness
- WTB: EG Window Wiper Switch
- WTB: '79-82 Honda Prelude ANYTHING!
- WTB: 92-95 EG Windshield Trim
- WTB: Pr4 ecu !
- WTB: Obd2b - Obd1 harness converter
- WTB: Type R LSD
- need 00 civic front mud guard
- WTB: 88-91 crx rear D series trans mount
- wtb: B series oem sparkplug cover
- WTB: Replica Mugen Valences
- WTB AUTRONIC FUEL ANALYZER
- WTB: Skunk2 Rear Drag Launch Coils
- B16 hydro transmission
- Please close.
- wtb-forged pistons and rods for gsr
- WTB:Integra hatch carpet clips
- WTB: rear camber kit for 95 integra
- WTB: 92-95 Civic hatchback BLUE interior
- WTB: Rear tailgate EG hatchback in white or black
- wtb turbo t3/t4 4 bolt
- WTB: 91 hatch mudgaurds
- WTT: OBD2 B18B block
- WTB: Energy Suspension 8096 upper shock bushings (top hat) crx
- WTB:92-95 CIVIC H22 AXLES
- WTB: Integra DB8 Exhaust and interior peices
- WTB 99-00 civic si blue front bumper
- 99-00 civic si stock shocks/springs
- WTB 88-91 Civic Speedo Cable
- WTB: Circuit hero shift extension
- Passenger side ek mirror CYPRUS GREEN
- wtb- full coilovers for bb6/97-01 prelude
- wtb pistons
- WTB: T3 60 trim turbo
- WTB 06+ Rear Bumper Sdn
- WTB All the parts for a Mini Me Swap
- WTB : Rear mudflaps for 99-00 Civic Si
- wtb: full bike rack for ek (coupe) and/or bike
- WTB OBD1 DC2 GSR Engine Harness.
- WANTED: Prelude Ignition Barrel & Keys 94/4th Gen
- ░▒▓ s2000 cluster w/pig tails, modifry unit, speedo-healer... ▓▒░
- WTB: GSR/EX/Si front brake upgrade for EG Hatch
- WTB: Stock OEM 92-95 Civic Lip (SF Bay Area)
- WTB Looking for 90-93 CIVIC/Integra RIGHT HAND REAR CALIPER
