View Full Version : Want to Buy
- WTB/WFF 96-00 civic manual window crank handles
- wtb seats civic or integra
- WTB: H22 Clutch cable
- WTB: ek rear license plate cover
- WTT Eagle B18c1 for B18b rods
- wtb: OBD2B ecu plugs
- need a z3 or a2 tranny with lsd socal
- WTT: Bride Zeta III for JDM Recaro SRD(s)
- WTB rhd firewall or full conversion!!
- 500+ fuel system
- ~Bay Area looking for EK suspension Struts and Springs or Coilovers + Short Shifter~
- WTB stock b16a2 intake manifold
- wtb EK hatch. nothing too expensive, just a daily.
- WTB: ITR / GSR Shift Linkage
- WTB: 96-00 Civic [2Dr Door Lock Actuators, Arm Rest]
- w.t.b dc2 itr front rotors and calipars
- wtb. Racing Hart C2 type C center cap nut
- WTB: circuit hero tow hooks!
- WTB!!!! connector to vtec oil pressure switch
- lowering springs for ek civic
- WTB: OEM DC5 Integra Type R car cover
- WTB CTR Wheels and Black Recaros
- WTB obd1 vtec dizzy
- wtb: chipped p28 w/ gsr basemap
- DIY hf turbo manifold for d16!!
- wtb elec boost controller!!!
- WTB tires what till fit on a 18x8" rim..
- WTB: integra type r doors (nor cal/bay area)
- WTB: 10k/8k coilover springs
- WTB:ek4 sir front bumper
- WTB: T2W4 Euro-R transmission
- WTB EM1 Driver side mount post and Rear T Bracket
- WTB GSR oil pan CASH IN HAND
- wtb gsr throttle cable
- NEED A T3 TURBOCHARGER ASAP!!!
- W.T.B ctr and itr cams
- I need a walbro install kit for civic
- WTB: SWIFT Sport Springs
- WTB: 98-02 Honda Accord Automatic Transmission
- WTB: 750hp Precision Intercooler, fluidyne radiator, edelbrock fuel rail
- WTB: Red Recaros, Mugen Gen 1 Wing
- WTB: LS parts (oil pan, flywheel, rear main seal cover, crank pulley)
- wtb: blue srr harnesses
- Albany, NY, WTB 2000 Civic EJ parts ..
- WTB: I NEED A REAR CENTER SEATBELT!!
- wtb: Stock eg exhuast, springs, and cluster
- WTB: JDM EG6 Rear Interior
- WTB: used b sereis tranny
- WTB:ASR Brace EG/DC Application!
- TW H22 Dog Box
- EG HB Shell
- civic wagon
- 4040 non abs prop valve
- wtb - DC integra parts
- WTB...TENZO DC-5 RIMS...
- for EP3, need HFP Springs
- Wtb: ecu cover
- **WTB 99-00CTR HEADLIGHTS**
- WTB: one gsr fat five
- WTB: 22MM Rear Sway bar bushings and D brackets.
- OBD1 Wiring harness for b16/d16
- W.T.B EG/DC B-series cmc, shift+linkages,pedals
- WTB: A couple EG Sedan parts
- WTB: aftermarket hydo trans pressure plate
- WTB: Any 90-93 acura integra LS RS GS GSR 2dr or 4dr in tennessee
- WTB: H22A Intake Mani(skunk2 or EuroR) or K20 RBC Intake mani
- WTB: B SERIES SWAP in PA
- WTB ITR USDM ECU 1997 only 37820-P73-A02
- WTB: 96-98 civic headlights! cheap/rice
- WTB: EAGLE rods for LS
- WTB TD-44U DIST. ASAP!
- WTB any B series tranny (Lawton,Ok)
- wtb: integra civic type r intake cam
- WTB: Integra 3 inch exhaust
- LS hydro tranny! I may need one.
- WTB: "EG" clock
- W.T.B DC integra 1" brake master cyclinder
- W.T.B EG civic abs pump
- W.T.B EG/EK full coilovers...
- 92-95 Civic Sparco Harness Bar
- PA cheap Eg shell!!
- WTB Cheap Project car
- [CT] - WTB '96 - '98 front end pieces
- WTB 92 civic intercooler piping (from the TB to the fender hole, 1 piece)
- WTB: B18 BLOCK
- WTB: Harness tail from Door to car 96-98 civic ex
- WTB: Crower 403 or 404 cams for LS
- WTB cheap gsr cams !!
- wtb boost controller, bar map sensor, and pipping
- WTB Recaro Seats for my RSX.. RED or Black lmk
- WTB: Running b20 longblock
- More WTB LSVTEC Stuff
- WTB: Spoon Calipers
- ctr or 00/01 cams, ek9 steering wheel, ctr cluster
- WTB: 89-91 Si Transmission
- WTB: Del Sol Power Antenna
- WTB; EG (2 door) PASSENGER window switch (automatic)
- wtb: obd2 sohc vtec wiring harness
- WTB: b16 exhaust manifold complete (CA)
- WTB: APR 2000 rod bolt
- WTB EG6 Amber Clock!
- wtb: obd2b p75 manual and b series starter
- WTB: OBD1 GSR ECU P72
- AEM FPR pronto!!!!
- WTB: CRX SI Brake Cable
- HONDATA S200
- WTB Integra OBD2 LS IACV Idle Air Control Valve
- Need a good d16z6 motor
- 99-00 CIVIC SI CENTER CAPS (1)
- WTB DSS 3.9 or +
- WTB Milano red DC2 Folding Mirrors
- WTB: D16 88-91 Civic/Crx LSD & Axles
- WTB : ID1000. Injector Dynamics 1000cc injectors for B series
- OBD2A EK 96-97 engine harness
- WTB: 12.5:1 or 12:1 Forged pistons(81mm)
- EG hood latch/ black window crank
- Looking for a complete Single Cam , LS, or B16 swap .
- WTB asap SI rear tranny bracket and dr. side top post mount
- WTB: MESHES 4x100 or Dr-20
- WTB: 96-00 civic coupe exhaust
- WTB: LS rods (aftermarket only)
- GARAGE SALE!!! K-Tuned, RHD, Hasport..etc.
- WTB: obd2 b series vtec dizzy
- WTB SIR EG6 Audio Console
- WTB: RSX Type S
- WTB D16Y8
- WTB: B-Series Mounts
- WTT:01 ITR Cams For S2 Pro1's..
- WTB: Stock EG steering wheel (NON-Cruise)
- WTB JDM integra oem hood
- WTB: eg hatch shell
- WTB: DC teg parts!!!! ASAP!!
- NEED HELP...NEED IMPORTANT PARTS
- WTB: OBD2b GSR/TypeR/Si under-dash harness and B-series adj cam gears
- WTB Bottom cam belt cover for b16b\b18c
- wtb: usdm stock itr header, cat, and b-pipe
- WYB, 1990 crx hf seat pans. Please!
- WTB: Clutch fluid reservoir tank with cap & bracket
- WTB JDM integra rear seats for about 200 shipped
- wtb...2000 si oem intake
- ek 4 door seadan lx or ex shell
- VA: WTB: 99-00 CIVIC SI OR EX
- WTB: Several eg6 parts
- WTB: GUNMETAL H CENTER CAPS FOR 5 LUG
- WTB - 96 D16 TRANS
- w.t.b 94-01 integra rear lca...
- WTB: '97-01 Prelude Battery Tie Down
- takata long
- WTB: EK B swap parts
- WTB:15" AXIS OG OLDSKOOL WHEELS
- acura cl parts needed
- WTB: ASAP B16a2 Crank Fluctuation Sensor & Lower Timing Cover
- WTB circuit hero shifter extender
- wtb H22 spark plug cover
- WTB: B series throttle body
- WTB:....(Delaware) 98-02 Accord Parts
- 99-00 Si grill
- WTB: 88-91 CIVIC STANLEY SIDE MARKER LIGHTS
- WTB: B18B Bottom End - Must Have Been Running Good - (So Cal)
- wtb portflow or endyn gsr head
- WTB: one gsr fat five wheel
- WTB: Adjustable B-Series Cam Gears
- wtb: 94 civic coupe passenger mirror
- WTB H22 SPRINGS AND RETAINERS
- WTB: AEM 1060 or 6060
- Wtb: civic si 00 p/s pump and delsol/crv b series a/c bracket
- wtb integra rear oxygen sensor
- wtb. TSX RODS or k24 aftermarket rods
- Wtb oem Ek side markers
- A/C Bracket 94'-97' Vtec DelSol
- WTB H23 fuel rail aftermarket
- Spanner Wrenches, The ones used to adjust coilovers
- WTB: K24 DC Swap Parts
- PA WTB: Windshield Glass for EK Hatch
- wtb ef8 crx glass top
- WTB B20 Parts
- WTB: Competition Stage 5 b18 cable clutch
- wtb 98-01 integra driver headlight
- WTB catalytic converter
- WTB:B20b Block
- WTB EX tranny
- WTB: 1995 D16Z6 Complete Motor Swap (SOCAL Only)
- WTB: 06+ Civic Si OEM axleback/muffler
- WTB: EF Clutch Pedal Assembly (Indiana)
- in need a an hf manifold for diy turbo
- wtb: del sol center console, oem car cover, ameripol top and more
- wtb: 99-00 Civic Si B16 4-2-1 header, Apexi Noir for 92-00 coupe
- WTB: Used B18B1 OEM Rods
- WTB: wideband O2 sensor
- WTB: s2k push button start!
- WTB Turbo!
- WTB Under Dash harness for 0bd2 integra
- WTB: H22y CLUTCH!!! ( SO CAL ONLY PLEASE)
- WTB: B20 Vtec parts
- WTB: 96+ honda civic SIR front bumper and rear bumper molding
- WTT: I need a 2005 or 2006 CR-V Service Manual and ETM
- wtb:civic coupe/integra/del sol
- WTB: 90-91 civic hatch turn signal assembly
- WTB 97 and newer Stock Prelude Injectors 290cc
- Need an ecu for a vx
- WTB real jdm EF8 axles
- WTB/WFF: b18 flywheel
- WTB :: EG HB REAR SPEAKER DELETE COVER
- WTB: integra JDM FRONT END
- WTB: adjustable cam gears
- WTB EF Sedan Shell or Cheap Runner NJ
- WTB: GSR HYRDO TRANS asap!
- WTB D16A1 Tranny Gear Set... (1st gen Integra)
- WTB es tuning oval muffler
- WTB : 96 Acura 3.5RL Parts
- WTT B series turbo kit for nice wheels, no rotas
- WTT: Koni Integra struts for EF Struts
- WTB: Broken or blown B series Transmission
- WTB: h22a4 injectors or 310cc injectors
- WTB: GSR Block Girdle, Main Caps, Bolts, Windage Tray, Pickup
- WTB: Desmond Regamaster EVO Silver 16" 4lug
- $40 finders fee reward
- wtb jdm integra front end converson
- WTB: 98 integra throwout bearing and pilot bearing
- 94-00 Integra Driver-side Seatbelt Buckle
- 15" mugen cf 48's looking for trade
- WTT DC4 for a white EK Hatch
- WTB: ITR Cams, ITR Valvespring, B-series VTEC valve cover, USDM VTEC solenoid
- WTB: catch can set up
- WTB Wanted Work Equip 01 Wheels 4x100 (Shop's are welcome to give me a price quote)
- H22 downpipe
- WTB Ek Full Coilovers - bay area
- WTB Tanabe Medallion Concept G Exhaust
- WTB Cusco CF Strut Bar EK Chassis
- WTB H22 stuff.!!!!!
- wtb: moates chip burner
- oem usdm itr lip + oem ls muffler tip
- wtb d16 short block
- Lthao61 WTB thread: Lots of parts
- Want2 Buy99-00 FRONTEND in Milano Red
- ITR THROTTLE BODY and SENSOR
- WTB: Electronic Boost Controller
- WTB: Jackson Racing FMU
- Looking for a cheap header
- WTB: Apexi N1 exhaust or axle back
- WTB: NRG SHORT HUB/ 2.5 QR FOR EK/EM1
- Valves
- WTB:99-00 Taffeta/Frost White EK OEM Door Handles & Driverside Fender
- WTB 93 HondaDel sol stock
- WTB 98-01 INTEGRA OEM LEFT MIRROR
- WTB: OBD-1 P72 ECU
- wtb: blox type "A" tuner series cams and blox dual valve springs for my GSR
- wtb: ssbp parts itr wing, hid ballast
- WTB:catalytic converter for 1999 civic ex/si
