View Full Version : Want to Buy
- WTB : Shift Cables for H22A
- del sol body and interior parts
- WTB: Automatic hatch, coupe, under $2k, OHIO
- WTB: 99-00 civic trunk carpet
- WTB 99-00 Civic SI rear t-bracket and Boomslang harness
- WTB: GM 3 Bar Map Sensor with Pigtail
- WTB: 03-05 OEM Accord rims
- WTB: OBD2 integra injectors
- wtb: stock white eg bumpers
- WTB: ANY coilovers for EH EG civic
- WTB: B series clutch slave cylinder and Front right brake line for 99si New Jersey
- 96-00 civic stock high pressure ac line
- WTB: GSR lower timing gear and F22A1 coolant pipe
- WTB : Parts For a Transmission Conversion
- WTB/TRADE: a manual tranny car that runs. $300 cash and a Gateway Laptop 3520GZ
- WTB: 92 Civic non airbag glove box
- WTB: 99-00 si wheels
- WTB tsx intake
- WTB: OBDI d-series dizzy
- W2B: 92-95 coupe cf hood or trunk.. 562
- WTB 88-91 civic Speedo cable
- HX WHEELS
- WTB h22 itbs
- WTB: 96-00 Honda civic hatchback
- wtb abs removal stuff for 00 teg.
- WTB: Top-Mount Downpipe
- WTB: BLUE JDM SRD RECARO CASH IN HAND
- lookN to buy a boost controller. help!!!!!
- WTB: RSX-S Throttle body
- WTB: 92-95 civic power steering high-pressure line & more
- WTB: P54 or P7J AC Bracket
- WTB: A/C Idler Pully and Tensioner Parts D15 del sol
- 90-93 B18 throttle body
- WTB: SAFC2 or AFC NEO
- WTB WTT LS hydro tranny
- WTB TPS SENSOR.
- WTB: A set of eagle rods(ls)
- wtb: catalyic converter for emissions
- WTB: OBD2B P75 ecu ls manual
- 88-91 CRX HF Cam Cap
- WTB:Turbo stuff
- WTB: Skunk Test Pipe and/or Invidia Test pipe & Header wraps
- wtb: ac condenser for 96-00 civic
- ++++++++WTT: My Black Leather s2k Seats for your Red Leather Ones (TN)++++++++
- wtb: D series lightened flywheel and 6 puck clutch
- WTB: RC 750cc Saturated Injectors
- WTB: 93 Prelude sunroof, tanabe, skunk2, koni, fender
- WTB: MAGNESIUM BLUE VOLK CE28Ns
- WTB: OBD2 catalytic converter
- wtb two regamater evo 16x7 5x114.3 45offset
- Looking for a good cheap EF or EG in Western N.Y. area
- WTB: Rear Cargo Cover For EK
- Aftermarket cat back exhaust for del Sol
- Lookin for an adaptor for the fuel rail.....
- WTB: stock engine swap parts
- WTT: BRAND NEW TIAL 38mm WG for a 44mm
- wtb: ny b16 3rd gear from cable tranny
- W.T.B. OBD1 VTEC ENGINE HARNESS .SO.CAL
- <b>WTB:</b>1998 Honda Accord Front Bumper Cover
- WTB: ANY decent looking honda or acura around $2k (ILLINOIS)
- wtb warped or blown gsr head
- WTB- Vtec solenoid for OBD1 b16!!!!!
- WTB: Turbo, motor and misc. stuff!
- I need a picture of a GSR ckf sensor
- NJ- WTB dc2 driver side door
- NEED: Dseries CABLE VSS, AND REVERSE GEAR SENSOR!
- WTB: 1991 civic Si front lip!!!
- STOCK EG Parts and Steelies WANTED
- WAnt To BuY An EK SHELL. Budget $1900 (WEST ARea)
- ANYONE HAVE OMNI DRAG COILOVERS IN STOCK??
- >>>Need EP3 Seats A.S.A.P I Have Cash In Hand<<<
- wtb denji or sharkeye headligh
- WTB: SELL ME YOUR UBER RARE 16" JDM WHEELS!!!! NO ROTAS PLEASE!
- WTB: TSW Revo Wheel
- WTB: JDM DA One piece headlights ASAP
- ****->WTB: 94 Honda Accord Radiator<-****
- WTB 92-95 Civic COMPLETE A/C
- WTB: VTEC HEAD
- WTB CRX HF Rear Drums
- WTB:1pc rear diffusser
- WTB: Regamaster's EVO's
- front lip
- WTB: 88 CRX headlights with brackets
- ***WTB--->750CC OR 1000CC RC (PEAK HOLD) INJECTORS***
- looking for d 16 around Dallas
- WTB: Stock B series OBD1 injectors
- WTB: CRX Hasport A/C Bracket
- WTB ASAP 92-95 REAR HATCH GLASS
- Garrett GT3582R 4 bolt
- WTB: DC stuff like Tails, Type R Wing, DC4 Test Pipe and Sway Bar rear section world sport
- Wtb Sohc Parts(camshaft-turbo Kit-cam Gear-piston-head Studs-rods-injectors-head-ect)
- WTB: autometer tach w/shift light
- WTB: CP Pistons for B18c1
- wtb: b18 front lower toruqe mounts
- WTB :: 96-00 Civic EX Manual Trans / K4F / S40 /B000
- WTB: black center caps, CRV caps? Anyone?
- WTB: One GSR blade... one!!!
- 96-98 HEADLIGHTS oem
- WTB 92-93 Civic Black Dash/Power Door Panels **MUST BE MINT**
- WTB OEM 93 95 Coupe EJ1 Bumpers and Fenders
- WTB 92-95 civic Gauge Cluster...
- WTB : Side markers (complete package) for 2000 civic si
- WTB:92-95 civic window seal
- Ohio-WTB Sparco Torino
- WTB: 99-00 civic Si front bumper and Lip
- wtb 90-91 integra ls half shaft(intermediate shaft)
- WTB! JDM ITR dc2 Fender! Left Side (US Driver side)
- WTB: 1996-2000 Civic Front Knuckles Non-ABS
- WTB: rear t bracket
- WTB:96-00 Honda Civic Dx Crank Pulley..Oem..D16y7
- WTB: STOCK 96-00 EX or SI catback/muffler (PA,NJ)
- wtb hatch ef model
- WTB: ACT sprung clutch disk for 2000 civic si b16
- WTB a list of things-NJ CHECK IT OUT!
- WTB Integra engine stiffeners (GSR or ITR)
- WTB: JDM p30 pistons
- WTB: VSM 96 98 ek front bumper and SIR lip
- WTB Si-Vtec Lip for Integra 94-97 OEM only
- WTB LS longblock, Pa area
- WTB Cusco 6pt r 7pt Roll Cage new or used
- Need Lsd diff for b series hydro trans
- WTB CRV or Del Sol VTEC a/c bracket
- ****WTB**** I need a few things...sideskirts...cd player
- WTB: 99-00 Si Parts ( Tails, Harness, Etc )
- WTB: Rear ITR lower control arms.
- WTB: driver side rear disc brake suspension
- Benen Radiator Stay
- WTB: B17A Engine
- WTB: B18B with tranny
- WTB: H22 CKP/TDC sensors
- looking to buy honda civic hatchback rear seats etc....
- gsr tranny in va
- *****WTT: Mint Jmags with new tires*****
- Broken ECU p05/p06/p28
- i need a cingular cellphone help
- WTB: GSR short block
- WTB: Comptech Intake & ice box for si / gsr CIVIC
- wtb: 99-00 si tranny CLUTCH DISC ASAP NOR-CAL!!
- CHEAP MAGNAFLOW EXHAUST
- W.T.B KNOCK SENSOR N O2 SENOR A.S.A.P
- WTB: EM1 (99-00 civic si) Engine mount brackets, DC/EM1 linkage, 81mm head gasket, b16 belt
- WTB D15b longblock d16
- WTB!! skunk2/blox/ITR Inatke manifold for B16
- WTB!!! Skunk2 pro 1 cams + cam gears
- WTB- ITR DC2 cf door switches
- >>>>>wtb: ek coupe stock hood and stock head lights<<<<<<
- WTB: Volk ce28n 16x7, 4x100
- wtb a sohc turbo kit
- WTB: H23A1 stock injectors & injector harness
- engine wire harness 92-95 civic
- WTB:gsr/b16 valve cover,adj fuel pres regulator,ITR oil pump,720-780cc injectors
- 92-95 prelude shell :: as little rust as possible
- WTB: EG door panels already modded for the GSR DASH
- EG OEM CF hood
- WTT plus cash or WTB Hondata S300, I have S200
- Lookin for a front bumper "94 or 98 Integra"
- WTB:96-00 civic shock/spring tops just the top parts with the studs asap!!
- WTB: Cam Gear BOLTS and Woodruff keys for GSR *cam seals also*
- WTB: TEIN S. Techs and EK4 SiR Lip for 96-98 hatch.
- wtb: stock 92-96 prelude rear sway bar
- SEARCH FOR-----> 16x7 [4x100] DUNLOP CPRs (silver)
- WTB: 96-00 Civic Hatch Wing
- WTB EK HATCH!!!~*~*~*~*~*~*~*~*~*~*~*~
- wtb 93 black side panels???
- WTB: H&R Race Springs, 96-00 Civic
- WTB: Half shaft/ Intermediate shaft for B series hydro
- WTB: some precision injectors 780 and up
- 90 Civic EF Mirror. Drivers and Passenger. Or pass blocking plate
- WTD: 88-91 OEM CRX Floormats, willing to pay
- wtb: 88-91 civic/crx stainless steal DC headerone..
- Honda Harness Plug for the factory civic radio
- WTB: Rays blue Lug Nuts and Valve stems
- WTB: OEM EG Floor Mats 1992-1995
- WTB crx door trim
- h22 into eg axles
- WTB: RHD Black Dash for an eg
- Looking for a Car in WA
- WTB HOnda crx si (stock) chicago land will drive
- WTB 92-95 civic HB fenders and front bumber
- WTB: Verizon PHONE
- WTB: NEW OR USED 15" / 16" POLISHED SLIPSTREAMS
- wtb h23 or h22 complete
- need a hydro b16 tranny
- WTB: Intake Manifold For MPFI Swap.
- want to buy :: del sol 1pc headlights
- WTb stock civic 92-95 front bumper
- WTB 94-95 civic teal grean front end
- WTB EK foglight covers
- Sidekick 3
- Integra Cluster wiring harness...
- WTB 22x8x15 drag slicks
- wtb idle air control valve
- wtb: DC headers for DA9
- WTB ek buddy club kit.
- I Need Parts For My Sohc and my 95 civic coupe (turbo-pistons And Alot More) Check T Out!!!
- WTB: I HEART INTEGRA (pix of car) decal sticker
- Looking for a good used header for 91 LS (SCCA) ITA integra.
- WTB - GSR block only
- WTB Comptech Supercharger for 2001 v6 accord
- WTB RECAROS
- new york!! need obd1 vtec harness and obd1 dohc vtec dizzy
- Is anyone selling a 94+ integra LS or GSR around 3500 2dr coupe but will consider 4dr
- WTB: 98+ Integra Front Bumper
- WTB: 92-93 integra driver side motor mount
- CRX - Ready to Buy! Southern California.
- h22 stock or aftermarket header
- WTB- CRX HF ENGINE HARNESS.
- EX Tranny!!!
- Any 92-95 civic ECU
- WTB sleeved b18,b20 block perfer at 83mm MAX or fresh 84mm hone.
- WTB BMX Quadangle frame.
- Integra Cluster or maybe others...
- WTB H Series Tranny
- WTB: EACV for GSR
- WTB: 92-95 Front Door Speaker housing...
- WTB: 94-01 Integra fenders CGP
- WTB: 92-95 CX distributor (Clean Good Condition)
- RHD 92-95 EG manual steering rack & pinion, front subframe brace & front lower control arms
- WTB SHIFT LINKAGE
- WTB: ARC Intake for s2k
- WTB: 98-01 Integra OEM PASSENGER HEADLIGHT!
- WTB: Triple guage pod for integra
- WTB: Stock B-series block! Must have low miles!
- WTB: DSM 450cc injectors
- WTB: 98-02 Accord sedan stock tail light / trunk lid
- WTB: Rota Retros
- looking for the cheapest most gutted integra shell..!!!!!! or even better..a free one someone just w
- WTB: CRX interior parts (BLUE ONLY)
- WTB 88-89 crx moldings
- WTB GSR SEATS ALL AROUND SOCAL
- WTB: cable vss
- wtb jdm ctr or itr cams 00-01
- WTB Del Sol Parts
- WTB: JDM H23A Vtec CRANKSHAFT CRANK
- WTB: Kosei K1 TS in Orange or Konig Kolor Very Orange
- WTB: retrofitted 96-98 civic headlights
- WTB 88-91 civic/crx A/C compressor and misc interior pieces
- OBD1 p72 or p28 mapped to p72
- WTB: D16z6 Header
- WTB: Integra A/C lines
- WTB: JDM fenderliners
- WTB: Civic type r oil cap (polished) or equivalent
- WTB: OBD2b o2 sensor for Integra GSR
- WTB: OBD1 Integra GSR injectors
- LOOKING FOR 1 INTEGRA LS RIM
- WTB: D16y8 Exhaust manifold w/ converter
- WTB: b16 hydro tranny with LS 5th and aftermarket LSD
- WTB: t3/t4 turbo with 4 bolt dp
- WTB: EG Floor Harness
- Wanted P06 p05 ecu
