View Full Version : Want to Buy
- WTB: JE turbo pistons
- WTB:92-95 ex tranny
- wtb: g3 teg 2dr rollbar system
- WTB: brake booster for 88-91 civic dx/lx/si
- WTB: 17inch TIRE tires in SOCAL
- WTB: OBD2 Injector clips
- WTB: 99-00 melano red Front Bumper. Paying $300 +Shipping
- WTB: b16 a1 swap to go into 1991 civic si
- WTB: Rota Circuit 10 16" Bronze
- WTB: D15B1
- WTB: ASAP!!! 89 integra distributor
- wtb:: jdm/jdm style ferio wing..
- wtb: a good b-series header asap
- Wtb: 92-95 optional lower dash piece
- WTB: 92-95 civic thingsss and some decent sound
- WTB: 92-93 2-door Integra full cat-back exhaust (used)
- wtb: usdm (90-91?) or jdm crx fenders ASAP!
- WTB: 94 accord a/c compressor
- wtb: 90-91 Integra Ls Distributor non-obd
- WTB: CTR pistons standard bore w/ rings and pins
- WTB: Rota C10 or C8 Bronze 16x7
- WTB: OEM eg springs (SF Bay Area preferred)
- WTB: p54 del sol AC bracket
- WTB: In Arizona only; Hondata S200
- WTB: 92 integra jack shaft & 91 civic HB passenger door and fender
- WTB: 90-91' Honda Civic Passenger side manual window regulator. Located in NC.
- WTB: Catback Exhaust for 93 Si hatch MD/NOVA/DC
- wtb: mount insert & ps1 game(herc's adventures)
- WTB: Pioneer or Alpine headunit N' Good condition
- WTB: 99 Civic vent w/ cruise control and dome light switch
- WTB: D15B2 starter
- WTB: Cheap Tires
- WTB: OBD1 GSR Distributor
- WTB: 90-93 Integra 2 Door Manual Seat Belt Full Conversion Kit
- WTB: A/C Lines for Integra 98+ !!!!!!
- WTB: Skunk2 Valve Springs & Retainers, B-series.
- WTB: ROTA 16" C10's plz
- WTB: B18CI OBD1 DISTRIBUTOR
- WTB: Short Hose In Clutch Line for 92-95 civic
- WTB: clean 90-91 CRX in PA/NJ/NY/DE or nearby
- WTB: 92-95 Civic hatch bezel with clock
- WTB: AEM EMS 30-1000 OBD1 ASAP
- WTB: GSR or B16 hydro tranny...need asap so please help!
- WTB: NEW Tein Super Street Coilovers (97 integra GSR)
- WTB: ITR suspension (shocks/springs/rear LCAs/bars)
- WTB: 92-95 Ex Gauge Cluster.. AUTO!
- WTB: OEM ITR lip for 2001 GSR
- WTB: F/R CR-X CUSCO STRUT BARS
- WTB: crx clutch pedal bracket
- WTB: 99-00 Civic hood and LS short block...
- WTB: 99-00 GSR polished wheels!!
- WTB: AGX FOR 91 CIVIC HATCH
- WTB: Front Bumper
- WTB: d series tranny hydro and 92-95 civic rear stock shocks...
- WTB: Apexi V-AFC 1
- WTB: 92-95 OBD1 P05 P06 ECUs
- wtb: gsr/ls/b20 short block
- WTB: rear itr or ctr 5 lug setup
- wtb:one advan rg 16x7 4x100 (any color)
- WTB: 94 Civic EX Dash Trim
- WTB: Misc B16 parts
- WTB: GSR Seats (so kali)
- WTB: EG stuff (door panels, jdm stuff)
- WTB: eg Stanley headlight and corners
- wtb: 14" integra snowflakes
- WTB: auto-manual parts
- wtb: 4dr eg interior (grey door panels,plastic pieces..etc)
- WTB: Hi flow Cat/ WTT: GSR leather seats
- WTB: D16y8 Fuel pressure regulator, 3" ITR CAI, EJ2 Rear discs,
- WTB: Black ITR front lip (98-01) and some other exterior parts
- WTB: OBD-1 GSR Distributor, SoCal
- WTB: D15B7 ECU & Wiring harness
- WTB: 92-95 civic HATCH driver side tail light
- WTB: Stock 99-00 Si stock injector(s)
- WTB: Del Sol stock exhaust
- WTB: 84-87 CRX front lip spoiler/valence/trim
- WTB: Piaa yellow ion fog bulbs H3...
- WTB: Looking for B16 pistons b16a
- WTB: B16 pistons
- WTB:Del sol seats wit green stripe
- WTB: Full exhaust for 96-00 Civic EX.
- WTB: OBD2 Knock Sensor
- WTB: Honda/Acura centercaps, that will fit onto '00 GSR blades
- WTB: hatch or crx in va/nc/sc/ga
- wtb: 92-95 civic STOCK front bumper
- WTB:white eg hatch bumpers
- WTB: Hondata Intake Manifold Gasket
- WTB: LS engine b18a1 -- Mass, CT, NH, VT...
- WTB: Calipers for my 92 Vti Sedan
- WTB: 90-93 integra rear engine mounting bracket
- WTB: Civic ECU
- WTB: 1989 Honda Crx Si Center Divider
- WTB: 195-50-15 or 205-50-15 tires
- WTB: 4-wire o2 sensor and egt gauge
- WTB: SIR T Fenders with orange sidemarkers in black
- WTB: 390cc dsm injectors
- WTB: 90-93 Integra Passenger Side Mirror
- WTB: 16x7 Work RSZ-Rs
- WTB: 92-95 civic hatch cargo cover
- WTB: OBD-2 LS ECU
- WTB: 205/45 16" Nitto 555R's
- WTB: ES Poly Shifter Bushings for 93 Integra.
- wtb:15"s rota circuit 8's bronze
- WTB: b-series motor torque mount
- WTB: lower CONTROL ARMS for 89-91 CRX SI
- WTB: PIECE of rsx-s Harness
- WTB: hard to flex to banjo fuel line to fuel tank... 1992 civic SI hatch. (see pic)
- WTB: S2k driver airbag
- WTB: 90-93 integra rear mount bracket and half shaft
- WTB: 98+ all red integra coupe tail lights in bay area
- WTB: You Got a TRanny i want it B-Series
- WTB: Defi D gauges Es oval, magnalfow oval, sway bars
- WTB: 99-00 Civic DX exhaust mani (w/ cat)
- WTB: I need this part asap!!
- WTB: stock B16a2 fuel rail (NOR CAL)
- WTB: PR4 ECU
- WTB: P73 OBD2A Integra Type R ecu
- WTB: 99 - 00 EK civic radio bezel
- WTB: D15B6 Fuel Injectors
- WTB: Pioneer 3 way speaker (TS-A1665) and ITR stock exhaust
- wtb: Need head gasket for b16/also piston rings bseries please help !!
- WTB: VAFC
- WTB:NEW OEM .25 OVER Honda factory piston rings
- WTB: ASAP SOCALI 88-89 hatchback drivers window!!
- WTB: Rear seats from Integra "blueish/black" ones.
- WTB: B18B SWAP
- WTB: Helms manuals, Civic Floor mats, Engine hoist etc
- WTB: Acura Integra Type R Lip 94-97 socal
- WTB: h23 starter, oil pan, valve cover
- wtb: 94+ integra ls shift linkage + shifter socal la
- WTB: complete JDM integra front end
- WTB: B18a1 or B20a5 Motor with low mileage!!!
- WTB: EK Honda Optional/SiR Front Lip
- WTB: first gen b16a distributor
- WTB: 92 INTEG P/S POWER STEERING PUMP
- WTB: Visors
- WTB: Type R Flywheel or other flywheel so cal prefer
- WTB: OEM Accord 16" wheels with tires. 4X114.3
- WTB: 96-98 airbags ASAP!
- wtb: rebuilt b16 y1 trans
- WTB: Vison corner or Amber corner for Eg
- WTB: Radio bracket for 90 civic
- WTB: Oem Civic Si grill and 99-00 oem civic fenders
- WTB: 95 Civic coupe drivers side mirror
- WTB: GSR CAMS
- WTB: 94+ passenger side fender.
- WTB: carbon fiber hood for JDM front
- WTB: high compression valves,CTR pistons,valve seals, Mugen gasket
- WTB:99-00 Front driver's side fender Electron Blue Pearl!
- WTB: Carbon Fiber Duckbill for 92-95 hatchback
- WTB: Getting car back from wreck after 2 years, please help me put it back together. Need the foll
- WTB: Stock EG clock..
- WTB: JDM THIN SIDE MOLDINGS FOR 90-93 2 DOOR INTEGRA
- WTB: looking for rims...$1500
- WTB:cat back exhaust for 94-01 teg
- WTB: ITR CAMS
- WTB: catback exhaust for a 1990 4DR civic
- WTB: obd2a p73 ecu.....
- WTB: V-AFC FOR B16A
- WTB: HO (175+ amp) alternator for '94 Integra
- wtb: black greddy bosst, egt, oil pressure guages
- WTB: ANY 96-98 Civic front lip
- WTB: SI wheels Tri-state area
- WTB: 91 CRX SI tranny.
- WTB: 99/00 SI Dorrs Complete -
- WTB: crx hood passenger fender and front bumper
- WTB: Lots of civic EX stuff, front end, interior, mirrors, and MUCH more.
- WTB: 1992-1995 Civic Parts ( Spoiler, lip, etc )
- WTB: B Series Starter
- WTB: d16y8 DISTRO
- WTB: pocket bike... blata ?
- WTB: 5 lug conversion + wheels
- WTB: Main relay for 88-91 civic
- WTB: 92-95 USDM Civic OEM clock. NOT JDM. NO Amber !!!
- WTB: itr muffler
- wtb: 1995 GSR helms
- WTB: integra LS b18b oil pan
- wtb:bogart 15x8 4 lug and rear runners 15x3.5 other parts too!
- WTB: 2 working single wire O2 (oxygen) sensors
- WTB: Hondata Prepped ECU
- WTB: b16 throttle body!
- WTB: P28 Ecu's
- wtb: 89-91 civic crx d series 5speed tranny si or dx south florida prefer
- wtb:jdm h22a pistons
- WTB: GSR block
- WTB: Integra GSR O2 Sensor on Header
- WTB: radiator support for 91 civic si hatch
- WTB: engine mounts for '00 Civic Si
- WTB: act or exedy B-series clutch low or no miles
- WTB: 1997 Civic EX ECU and Wiring harness
- WTB: Civic hatch Window.....
- WTB: pair of front koni yellows for integra
- wtb: wheels!!!
- WTB: Gunmetal ITR rims in Northern Cali
- WTB: (1) ONE! GSR Fat Five / HammerHead Wheel
- wtb: MI - d-series swappp with auto tranny
- WTB: 98-01 Integra Passenger side Headlight
- WTB: Del Sol AC Bracket
- WTB: ITR IN CALIFORNIA!!
- WTB: p28 ecu or p72
- WTB:: A/C Compressor for a 96 GSR
- WTB: OEM CTR cams or 2001+ ITR cams
- WTB: DX/LX SOHC Hydro Tranny.. local So Cal 909
- WTB: 94-01 Integra Windsheild moldings/stripping
- WTB: Accord/Prelude 5-speed conversion parts
- WTB: OBD I AUTOMATIC P75 ecu, or po6 will work also
- WTB: Red Recaros
- WTB: Virgin 5spd P28
- WTB: ls rods that fit itr pistons or ls rods with itr pistons
- WTB: Help a ITR owner out.
- WTB: Stock oem Ek side skirts......
- WTB: Short Hose In Clutch Line for 92-95 civic D16
- WTB: ONE 15" silver Rota Circuit 8
- WTB: 88 civic hatch corner lights
- wtb: jdm itr interior stuff!
- WTB: 5th gen prelude shift cables and linkage
- WTB: any 96-98 lip (ctr/sir/mugen/whatever)
- WTB: B series tranny tailhousing
- WTB: RSX block
- WTB: dont know what it totaly is?
- WTB:88-91 crx fenders hood WW bodykit and more
- WTB: WHEELS!! any!! So-Cal Area
- WTB: GSR Leather Shift Knob
- WTB: 98+ Integra tails
- WTB: Mugen or type r grill
- WTB: GSR rims
- WTB: itr interior pieces (usdm/jdm)
- wtb: 4dr spoon or spoon style non-cf mirrors
- WTB: OBD2B ecu pigtails / male wire conversion harness adapter plugs (obd2a might do)
- wtb: h22 lma's 97+ spring type
- WTB: obd1 gsr distributor
- wtb: motor mounts
- WTB: CTR type grille 96-00 civic ex
- WTB: JDM Style Headlights
- WTB: "B" series starter, OBD1 GSR distributor, GSR shiftlinkage NEEDED ASAP !
- WTB: after market cross member for 90-93 integra
- WTB: Oem 92-95 EG hatchback tail lights
- WTB:clutch, lsd, mounts.
- WTB: 94 Accord Axel
- WTB: AUTO tranny 94-95 civic Si
- WTB: D16Z7 Cam and Cam Gear
- WTB: Auto to Manual Conversion for 98 EX
- WTB: CRX HF Front Sway Bar!
- WTB: bay area, mp3/cd player head unit
- WTB: 90-91 Civic Si Complete Engine harness
- WTB: H22a BLOCK AND BLADES
- WTB: D-Series LSD transmission
- WTB:88-89 Civic H/B Side Trim
