View Full Version : Want to Buy
- WTB: 8 inch springs 2.5 inch ID (450lb and 350lb)
- WTB: That black timing belt cover thingy.
- WTB: EG interior door handle, lock, cover
- wtb: honda accord bumper
- WTB: Front lip for my EG.
- WTB: MD Emissions pass!!
- WTB: 2 o2 sensors for my 99 gsr & corner light plugs & tan back seat(4door)
- WTB: Integra Rear Swaybar Mounts, throttle cable, bock guard
- WTB: KY: b18c swap minus tranny
- WTB: PY ITR wing or PY hood
- WTB: Taffeta White EK Wing!!! I know you have one, now cough it up!!!
- WTB: factory 99+ GSR black leather shift knob
- WTB: JDM EG6 gauge cluster and autometer A/F gauge
- WTB: OEM EG fogs
- WTB:B18C / B18C1 GSR short block bare is ok So. cal.
- WTB: Smoked out (Clear) Spark Plug Wire Cover
- WTB: DC2 stock shocks in Wisconsin
- wtb: 94-01 stock hood
- WTB: 92-95 Eg Parts *MISC*
- WTB:ground controls...
- WTB: OEM DEL SOL CORNERLIGHTS
- WTB: h22 peak and hold injectors and resistor box
- WTB: 98-01 red and clear stock tail lights
- WTB: 92-96 Prelude Header!
- WTB: Rear seats for 98 civic hatch
- WTB: Rear seats for a 98 civic hatch
- WTB: Del Sol Neuspeed Koni Yellows
- wtb: integra center console
- wtb: ek sideskirts.....
- WTB: P13 ecu. I NEED an OBD-1 P13 H22 ecu
- WTB: 5 lug conversion w/ champion white wheels.ASAP
- WTB:92-95 hatchback white bumpers
- WTB: integra BLACK middle console
- WTB: LS/Vtec Engine or pieces to make one
- WTB:complete z6,y7,y8 block
- WTB: looking for a carbon fiber lip for a dc2 jdm front end
- WTB: black leather integra g3 headrest x2
- WTB: Shock + Coilover as a set only!
- WTB: spoon seats buckets
- WTB: Headers for a 2000 Civic Si!!!
- WTB: B17 rods and crank
- wtb: tps / injectors
- wtb: 00-01 integra parts.. anywhere in CA
- WTB: DOHC VTEC Valve Cover, HX wheels!!!
- WTB: CRX Tail Lights. Looking For Good Condition/Not Chipped or Cracked.
- WTB: 90-93 Integra Front Springs
- WTB: VTEC Valve Cover and Rocker Arms
- WTB: B18 piston rings
- WTB: Katana Motor
- WTB: AEROMOTIVE FUEL PUMP, FPR, FUEL RAIL, etc. for my LSVTEC
- WTB: 2 HX rims
- WTB: any jdm 14" wheels 4x100
- WTB:: LS head
- WTB: Skunk 2 Stage 1 Cams
- WTB: 92-95 Civic EX dash
- WTB: Hydralic D series transmission
- WTB: GSR Lost Motion Assembly.
- WTB: 88 CRX hf distributor (or any OBD0 d series dizzy)
- WTB: Carpet for 92-95 hatch
- WTB:15inch SSR PROFESSOR SP1 wheels
- WTB: obd 1 distributor
- WTB: ITR or S2K throttle body and others
- WTB: 94-97 ITR lip
- WTB: D16z6 in MD/NOVA/DC area
- WTB: wanted, front and rear seats from 96-00 civic hatch
- WTB: Throttle Cable for EG with Bseries, Timing Belt Cover for b18a1, Spoon Style Side Mirrors, etc.
- WTB: Sprint Hart CP-R's
- WTB: LS head (b18b1) and turbo cams for LS
- WTB: ITR 5 lug w/ wheels
- WTB: corbeau bracket and slider for dc2 ASAP!!!
- WTB: VIS carbon fiber duckbill wing for eg and stock hood
- WTB: 98-01 Integra CF hood and 98-01 cf front lip
- WTB: integra c/f trim pieces
- WTB: b-series mounts, int. shaft
- WTB: 96-98 Civic EX MANUAL ENGINE HARNESS
- WTB: passenger side inner wheel panel
- WTB: Rear Seatbelt part
- WTB:::::::1990-1991 Itegra Ls B18A motor mounts/Tranny mounts bolts.
- wtb:b16 head
- WTB: 4th gen prelude interior parts
- WTB: Gauges
- WTB: p-30 Honda ECU?
- WTB: 89 Civic DX to SI Harness
- WTB: Brand new Comptech swaybar/tiebar combo for 98 Civic.
- wtb: b16 tranny
- WTB: eg half radiator
- WTB: 95 Civic Coupe mudflaps!
- WTB: P30 ECU
- wtb:
- WTB: 85mm piston ring set
- wtb: '88 CRX DX Window Regulator . .. .
- WTB: EG FRont bumper
- WTB: EK SIDE SKIRTS NOW!!!!!!!
- WTB: Eg rear mud flaps...
- WTB: LSD for gsr........
- WTB: D16z6 alternator asap!
- WTB:FACTORY CD RADIO W/hardness & CODE
- WTB: 90-93 acura integra seats
- WTB:ASAP civic EX dash with airbag
- WTB: uncut 92-95 civic dash harness (SoCal)
- WTB: d16y7 Oil Pan
- WTB: Y1 cable B-series transmission.....
- WTB: P06 ecu
- WTB: Bride Zeta II Black in color w/out rails anyone???????
- WTB: jdm itr front conversion
- WTB: TYPE-R TRANNY or B16
- wtb: crx radiator fan and brackets
- WTB: 92-95 Civic Rear Speaker Setup
- WTB: B17 Rods and crank
- WTB: GSR Rims 98-01 (Blades) CANADA
- WTB: stock 90-91 integra ls exhaust manifold Indiana
- WTB: B16 cable tranny
- WTB: 1992-95 Civic EG Front Fenders.
- WTB: 1992-95 Civic EG Front Bumper Cover.
- WTB: 1992-95 Civic EG Headlight Housings.
- WTB: Type R Rear Swaybar Endlinks
- WTB: 92-96 Prelude Airbags
- WTB: RSX Type R full lip kit
- WTB: 1 Rota slipstream 16"
- WTB: JG cam gears
- WTB: I NEED A 98-01 INTEGRA BUMPER!!!!!!!!!!!!!!CAR IS GETTING PAINTED
- WTB: B16 timing covers
- WTB: 120 gig hard drive
- WTB: 96-00 genuine JDM civic type r ctr rear lip..
- WTB: 04 S2000 factory wheels
- WTB: EG rear bumper, GSR shifter, gaskets, b16 headstuds and more
- WTB: new or used eg sedan exhaust...
- WTB: 94-97 integra rear bumper
- WTB: Ground control 25mm adj. swaybar...ek, dc...
- WTB: Sohc VTEC Swap
- WTB: S2000 headlights
- WTB: 94 and up 2 door integra pass side front fender splash guard
- WTB: 94+ rear bumper, b18b bare block/crank/rods SOCAL only.
- WTB: 92-93 Cable GSR Tranny
- WTB: Alternator for 88 CRX Si!!
- WTB: Anyone Have This Stuff?
- WTB: 15" rotas w/tires in SAN DIEGO
- WTB:USDM 94+ Millan red right fender in mint condition!
- WTB: EP JDM R headlights
- wtb:b&M fuel reg-walboro 255 intake pump-and aftermarket fuel pump ASAP
- WTB: B18C1 Head Gasket and Intake Manifold Gasket
- WTB: Cheap rotas...
- WTB: DC5 rear "INTEGRA" emblem
- WTB: d16z6 distributor
- WTB: 96-00 Bseries Motor Mounts
- WTB: stock GSR fuel rail and injectors ASAP
- WTB: Any D16 bottom end. BLOWN OR GOOD!
- WTB: Complete A/C system for EK Hatch!
- WTB: EX or DA front knuckles\spindles\hubs whatever they are called.
- WTB: Ek side skirts
- WTB: Nitrous kit
- WTB: RSX Type R Rims
- wtb: b-series clutch & light flywheel for cable tranny
- WTB: B16 IACV (pic included)
- WTB: 99-00 SI FRONT BRAKE LINES
- wtb:5g coupe/hatch driver's side taillight(outer piece only)
- WTB: 16" Work Emotion Gunmetal 5x114.3 ASAP.
- WTB: SPOON CLUSTER OR JDM ITR CLUSTER FOR DC2
- WTB: Looking for Catback exhaust for 91 crx
- WTB: 4dr Integra seats
- WTB: blue EG door panels/ ashtray lighter piece
- wtb: H&R sport springs for 94-01gsr
- WTB:BENEN Tow Hook(s)
- WTB:h22 92-96 sleeved block
- WTB: One hx rim with or w/o tire
- WTB: OEM 03' civic 15 spoke wheel.
- WTB: broken driver side 98-01 headlight
- WTB: GSR Distributor TD68U
- WTB: Z-Speed catback exhaust
- WTB:LOOKING FOR APEXN1 OR GREDDY EVO FOR LS INTEGRA
- WTB: 98+ CONVERSION IN BLACK AND DRIVER SIDE FENDER!!
- WTB:JDM EK Goodies!!!
- WTB: 94-01 Rear Lower Tie
- WTB: New JDM 4-1 Header ITR
- WTB: da9 shyt...
- WTB: GSR throttle body in perfect condition with sensor OBD1 version 94-95
- WTB: Front Koni's for DC2
- WTB: B16A starter
- WTB: B- Series Cams
- WTB: 2002 TL-S PARTS
- WTB: New shoes for my dark angel! (Volk Racing TE37 - Advan)
- wtb: MUGEN RnR's blk/red
- WTB: eg6 or dc2 gauge cluster
- WTB: Integra NEW ENGLAND
- WTB: 94-01 OEM Integra LS air intake
- WTB: D-Series Tranny... ASAP
- WTB: DC2 rear traling arm
- WTB:CHEAP good running OBD1 complete SOHC swap,motor
- WTB: PM7 ecu... if you have one please show it
- WTB: GSR LCA's
- WTB: does anyone have one dc2 stanley sidemarker?
- WTB: D16z6 engine complete
- WTB: Type One racing header
- WTB: 70mm tb gasket for ITR intake manifold.
- wtb: b-series shiftlinkage complete, b-series axles in good condition
- WTB: B16 hydro tranny
- WTB: civic EG hb back bumper
- WTB: 92-95 EX front Spoiler, JDM EG Hatch Spoiler
- wtb: a vtec solenoid b series nova area
- WTB: Front End
- WTB: wrecked/messed up/broken '98+ Integra headlights
- WTB: 94+ Integra GSR stock intake
- wtb: integra gsr 94-95 obd 1 fuel pump w/filter complete..
- WTB: 2 RECARO SRD'S OR SPEEDS
- WTB: real universal HKS super mega flow or knock-off
- WTB: 2 Spoon Wheels 16" 5x114.3
- WTB: 99-00 CTR headlights, 6-8K HID Kit H4
- WTB: JDM teg Front end
- WTB: exhaust for 98 gsr without all the piping.
- WTB: D series Power AEM Steering pulley!
- WTB: 310cc Saturated Injectors
- WTB: 15' Wheels w/ tires NY/NJ/CT/PA 500-600 cash
- WTB: Pass side dorr for 91 crx
- WTB: CF hood 88-91 crx
- WTB: VAFC controller
- WTB: Civic Si lip...Preferably in Milano Red.
- WTB: GSR oil pump
- WTB: need a d series cable tranny!! help me out plz =)
- WTB: NSX calipers
- WTB: NORTHWEST AREA civic SOHC block
- WTB: 94 integra interior/exterior parts -NYC-
- WTB: Integra Lower Hatch Panel
- wtb: upper rear control arm-from civic si or 94 and up teg.
- WTB: Crower 403's and Valve springs!
- WTB:::::::::::::: Takata harness :::::::::::::::I know, it wont be easy :)
- WTB: 98-01 Integra Carbon fiber front lip
- WTB: Honda del Sol OEM Fenders
- wtb: 99-00 civic passenger side headlight
- WTB: 96-00 civic hatchback
- WTB: jdm 96 ITR rims with tires - bay area
- WTB: 92-95 Civic Si Hatchback Stock Muffler.
- WTB: EG armrest
- WTB: K&N style reusable cone filter (3") / valvecover breather / filter cleaner & oil / dp flange
- WTB: H caps from Civic SI
- WTB: K&N style reusable cone filter (2.75"/70mm inlet) / valvecover breather / filtercharger stuff
- WTB: Catalytic Converter **any**
- WTB: Texas, black 94+ Integra seats in cloth, front and rear.
- WTB: rear accord ABS ring
- WTB: Hard drive for $20
- WTB: D15B1!!
- WTB: D-series header, cash on hand.
- WTB: clutchmaster stage 4 pressure plate
- WTB: 96-98 SOHC VTEC ECU
- wtb: itr muffler
- wtb: pr3 standard bore piston rings OEM
- WTB: 4 New 215-45-17 Tires
- WTB: Stock CRX Parts in Socal!
- WTB: OEM 98+ integra bumper lights
- WTB: Power Steering Pulley
- WTB: 1 Goodyear Eagle GTII or set 205/55/15
