View Full Version : Want to Buy
- WTB: GSR TRANNY
- Dc2 shell
- WTB: 1-2 Sleeve B-Series Hydro Tranny
- WTB EG Door Panels W/ Tweeter Pod.
- Wtb- kswap harness, hasport eg mounts
- WTB: 99-00 si oem ebp grill/ 99-00 si oem front lip
- Wtb: Purple Tial Q BOV
- AZ WTB: integra shell
- WTB: CTR MANUAL DOOR PANELS
- GA WTB: Integra front end 94-97 lights bumpers or JDM front whole or pieces
- Complete 98-01 gsr throttle body with throttle cable
- WTB: 44/46mm wastegate
- WTB engine harness
- WTB: GSR Turbo/Supercharger Cams
- wtb: itr usdm cluster
- WTB: 1991 civic dx 1.5L crank pulley
- Hx Center Caps
- WTB 97-01 CR-V All Clear Taillights
- Gsr crankshaft
- WTB 98-01 Integra Mud flaps
- WTB 90-93 Honda Accord Half or full mask.
- WTB: B series Skunk2 Pro Series or Toda Cam Gears
- Wanted: Clean 92-95 Si
- WTB - EG/DC Subframe Bolts
- Wtb stage 2 b series cams
- wtb mini ram /ramhorn b series
- WTB: Honda/Acura B Series Knock Sensor
- WTB DC2 Passenger rails Recaro SRDs (JDM DRIVER SIDE)
- WTB ef8 sir bumper with bumper support
- WTB: P30 power steering upper bracket
- Wtb: gsr/b16 bare hear with caps&plates
- WTB 91 EF Sedan hood and d series compressor
- WTB 2002-03 EP3 Koni suspension
- WTB 86-89 Accord parts
- Wtb em1 parts
- WTB just one Oem GM ITR wheel
- WTB: OBD1 to OBD2a harness
- WTB: ITR or EM1 (detailed Criteria )
- MO or IL WTB '00 Civic EX 5MT
- WTB: Phantom Grey, black, or white EG hatch. Tristate area
- IL: WTB: 99-00 Honda Civic Coupe OEM Car Cover
- 6262
- IL: WTB: 99-00 Honda Civic Si Spoiler in EBP
- WTB: 2007/2008 Honda Fit 5 spd shift knob
- WTB OEM stock airbox for 2003 Civic Si EP3
- Need to buy !! Integra Oem mud guards 98/01 sedan !!
- WTB: Moates Demon v2 & NepTune combo or Hondata s300
- Ek interior parts
- Wtb Integra sedan manual 98 up no sunroof LA area
- WTB: p72 usdm ecu obd2 from a 96 or 97 Integra GSR
- WTB: EM1 Climate Control (Complete)
- WTB: B series manual flywheel cover with brackets
- Wtb bare sleeved b18 vtec
- WANTED: CRX/EF DRAG 3-PIECE FRONT END USED
- WTB 949 Racing 6ul 15" 4x100 for my CRX 91766 Ca
- WTB: H22 transmission bottom metal piece cover
- Integra 94-01 complete interior
- WTB: p13 ecu for an H22 obd2 (96 Prelude Si VTEC)
- If you have a stock gsr intake manifold- Please read
- WTB B Series Engine Mounts
- Integra LS 5th gear set
- Wtb: liberty gear set
- Wtb 40/40 prop valve
- Delsol Vtec SHift linkage
- CT-Engineering Icebox for '99-'00 Civic Si
- WANT TO BUY 2X OR 4X EIBACH GROUND CONTROL SPRINGS
- Looking for OEM EM1 Grill or outer bezel
- WTB ID 1000cc injectors
- WTB Wheels: 99-00 Civic Si OR GSR Fat 5s (SoCal)
- WTB ID1000's injector dynamics
- wtb 98 integra oem turn signals
- 97integra rs (wiper motor and master window switch)
- wtb b18 turbo parts
- WTB: Hondata s300 v2 or v3
- WTB bald/spent 275/50/15 MT for mock up purposes EAST COAST
- Wtb; b series vtec head. B16 gsr etc
- WTB: Racing Hart Type C center caps.
- J's Racing front tow hook Civic EP3
- 92-95 civic HB apex WSII exhaust
- who gots oem honda main and rod bearings?
- D16Z6 Needed
- wtb b16 or her head
- Wtb: eg civic exospeed front end
- WTB 88-89 CRX Si Driver Side Headlight Assembly
- WTB: D16Y8 Intake Manifold (M/T) Complete or Bare
- WTB integra shift linkage and engine mounts
- WTB hondata s300 and any obd1 conversion parts
- WTB: 3 OR 4 BAR MAP SENSOR!
- manual rack and subframe
- WTB D16 MAIN & ROD BEARINGS
- WTB D16 AFTERMARKET INTAKE MANIFOLD (Skunk 2 ULTRA RACE preferably)
- WTB D16 76MM FORGED PISTONS & D16 FORGED RODS (if you have)
- WTB 92-95 Civic Eg Harness
- WTB B-Series Intermediate Shaft - Manual Transmission
- 1996 Accord Coupe Speaker Grille/Cover
- WTB : b-series 4.7 FD
- WTB: USDM corner lamps civic sedan 90-91
- WTB: FMU
- WTB: Blue EG CX Interior Parts and White passenger fender W/O trim cutout
- WTB: JDM Front integra Carbon hood
- GSR exhaust manifold
- Wtb: P28 or P06 obd1 Ecu
- WTB: comp clutch stg3/4/5
- wtb. 450cc dsm injector's
- WTB: Bronze 16x8 TE37 5x114
- WTT fresh ITR valve cover for Spoon valve cover !!!
- WTB 1000cc injectors, high or low impedence, $200
- wtb oem b series shifter
- WTB B16a2 PS Pump
- WTB : SoCAL - 93-95 eg coupe WHITE hood and interior
- WTB: Integra DA (91-93) Stock Front Shocks/Springs
- B17
- WTB: 97-98 ACURA INTEGRA RS NON-SUNROOF
- WTB gsr transmission - DFW area
- Ep3 rear brake calipers with brackets & rotors 4x100
- WTB: 92-95 CIVIC Cabin wiring harness
- WTB: 92-93 Integra GSR
- Gsr Head
- ISO B Series Vtec Head
- WTB moates burn2 and chips
- got $300 for 1000cc high impedence injectors
- JDM ITR 4-1 wanted
- WTB: b16 valve seats
- WTB ctr cluster and wing
- WTB either B16 or B18 head
- ef armrest
- WTB B16A IACV ( IAC )
- WTB: (2) PAIR Work Meister s1 or Kosei K1
- Wtb d17a2 ecu
- WTB 99-00 Civic Si Axles
- WTB Edelbrock B-series turbo parts
- WTB: 96-98 EK9 climate control type r badge plate or clock
- WTB k-series oem lsd or aftermarket
- WTB T3 66mm turbo housing
- skunk2 pro series stage 2 cams
- Wtb oem 98-01 integra headlights
- WTB RDX 410 CC or similarly sized injectors
- WTB: EG hatch trunk lid
- wtb d17a2 ecu
- WTB yowai-ss cooling plate for eg
- Em1 oem air box
- 4040 Brake Proportioning Valve
- 99/00 oem coupe rear lip
- 94+ integra ps pump bracket and steering coupler
- WTB: 07-01 Exhaust Manifold (4WD)
- wtb: 2000 si motor mounts
- GS-R/Integra tan leather/plastic interior pieces
- WTB: j's racing quick release
- WTB: DB1 JDM 3rd brake light
- WTB: ITR intake valves
- Wtb 92-96 prelude shell
- vx airbox, intake tube, and resonators.
- Oem b16a intake and exhaust manifold
- WTB 84mm 13:1 PISTONS
- WTB: EG Hatch Shell Los Angeles
- WTB EK/EM1 Door panel
- civic hatch 91 tailight passengerside R
- WTB: EF round fog lights
- WTB Springs and retainers B18c R
- WTB: EK9 CTR OEM red stitch shift boot
- WTB:Mugen License Plate Frame
- WTB: 96-00 civic sedan driver sun visor
- Wtb:3pc wide front for ek (99-00)
- WTB: complete set of cam caps, rails, bolts from a gsr engine
- Fuel injectors/delivery system
- 2nd Gen Honda Fit Cargo Cover and/or Tray
- Jdm b16a ecu obd1 or obd2a with obd2b ecu jumper
- WTB: 60mm Wastegate
- B16 arp head studs
- wtb: 98 GSR items in SoCAL
- wtb p28/ p08 ecu
- WTB: Hondata S300 V3
- WTB: B20B Titanium valve springs and retainers
- WTB b16 head parts
- Spoon Horn Button
- WTB: B-series Lower Engine Brackets/Stiffeners
- Wtb L3 cable trans shift fork(s)
- WTB 5zigen fn01rc wheels 5x114.3
- WTB: Stock Integra Suspension
- WTB: ep3 shift knob and boot
- WTB USED/NEW SPOON DURACON SHIFT KNOB 5SP
- WTB: D Series Jackson Racing SuperCharger kit in Cali...
- WTB: B18c fuel rail/line/F.P regulator/Throttle Body
- WTB 95 CIVIC DRAG SPRINGS
- WTB: honda crv ac bracket
- WTB: OEM EK4 SiR wheels
- WTB OBD1 B16 alternator bracket
- ltb: eg hatch clutch lines
- EK Blue Ion headlights and whiteout taillights
- WTB: B16 Throttle Body 60mm OEM
- 10" Sub Enclosure for Corner of an EG Hatch
- Looking for a few Turbo items
- WTB 99-00 EM1 EDM front grille
- looking to buy RSX parts
- WTB: Panasport center cap(s) CA
- civic hatch 91 tailight driverside
- WTB: B series parts needed
- WTB: GSR Valve Cover (Uncut)
- MPC drop forks
- Eibach ERS 800/900
- Want to buy: white eg hatchback no mouldings, no rust, clean tittle
- WTB: OEM ITR Front Lip
- F22A6 CAM
- Honda Civic EG Lower Tailgate Liner
- wtb hondata s300, gsr turbo oil pan, vented valvecover
- wtb:buddyclub p1 rims 15
- Acura TL 17mm Sway Bar
- WTB comptech battery tie down
- WTB: P75 obd1 ecu
- looking to buy: 1995 civic manual pedal assembly and clutch master
- WTB: 96-00 Civic Coupe/Hatch OEM Window Visors
- ISO hondata cpr black box
- Urgent - k20 5 speed counter shaft
- WTB: RHD EG Manual rack and subframe
- WTB camp1320 bc bars
- ep3 half nose mask
- wtb: turbo manifold for b18 Td05h-16g
- wtb: p28 ecu. auto or manual
- WTB 96-00 Civic Hood & Trunk Lid
- WTB: ITR Cams
- WTB Desmond Regas 16x7 4x100
- D16Y8 Header/Cat
- WTB: 18G Downpipe
- Wtb ITR stock intake resonator
- WTB: EG JDM ashtray for audio console (trapezoid)
- WTB ID1000cc injectors for b series
- b16 si transmission gears or gsr
- Jdm ctr/itr valve cover
- Civic 95 EG Strut Tower Liner Caps / Lidsq
- CT/ Comptech Integra filter adapter!! I NEED ONE of these
- Samco Type R intake tube
- Looking for a 2.5" test pipe
- WTB: No Cut Shifter Box
- WTB: Accord CL1 Euro R Wheels (single or pair)
- ef hatch armrest
- WTB: 66 Tooth Final Drive Ring Gear
- WTB: 09-11 Civic Front Bumper (San Diego)
- WTB- GReddy cast elbow for b-series kit
- h22 sleeved block
- PISTONS , RODS AND BEARINGS
- WTB: Fuel Line Items (OEM) Integra Sedan
- wtb: 90_91 crx dx gauge cluster
- WTB: EG rear seatbelts
- WTB Solid B series motor mounts
- wtb: rain visors for 4Door eK
- window visoRs for 4Door ek
- spoon style shift knob
- 93 civic hatch non abs oem brake master cylinder in good working order
- WTB: B Series LSD Transmission
