View Full Version : Want to Buy
- **WTB** EK MIRRORS ASAP!!!!!!
- WTB: b18a1 iacv
- wtb steel braided brake lines for 99 civic si
- WTB: OBD1 P75 LS B18B manual ECU & distributor
- WTB: MINT OEM Si or SIR front lip for a 92-95 civic hatch
- WTB: 00 civic cluster with tach and oem spoiler
- Wtb: Stock b16 oil pan
- WTB: D16Y8 Automatic Transmission in So Cal
- h22 iab box and header heat shield
- WTB: VX EGR control unit, fuel line
- i need a ek cluster ASAP
- WTB B18!!!!!
- wtb: misc parts
- WTB: Integra 94-01 Climate Control
- tial 44 wastegate, top mount 4 bolt downpipe, intercooler, and a good blow off valve
- WTB:AEM Wideband
- WTB 4x100 steelies with tires
- WTB: Bare B16/B18 Block, and EK B-sieres Mount
- WTB Obd1 H22a LSD tranz cash in hand***
- WTB oem 02 RSX Type-s Suspension, intake & exhaust
- h22 spark plug cover / header heatshield/ps braket off 97-01
- WTB Obd1 GsR IACV!!
- WTB: Ronal Teddy bear rims. ASAP!!
- h22a4 p/s bracket please asap
- WTB CRVtec B20vtec
- wtb precision 600 intercooler
- wtbk b series solid mounts asap
- Wtb: h2b kit
- wtb obd1 vtec distributor
- wtb: GM 3 Bar MAP Sensor/ aem wideband
- WTB: B16A 'A' Pipe AKA Header Pipe
- WTB: B-series clutch (Forced Induction)
- WTB: Built H22
- WTB: Integra door handle
- WTB: s300
- WTB: Kaizen speed H2B oil pan
- WTB: Starter Cable + Battery Base
- WTB: MINT Map Sensor, and MINT IACV D16z6
- WTB: 92-95 Civic Hatch full amber corners
- WTB lighten flywheel for b-series
- WTB: 83.5-84mm 11.5:1 pistons
- WTB:Spoon TwinBlock Calipers
- WTB: EURO R intake manifold
- WTB: InlinePro T3/T4 Cast Manifold
- WTB: B16a2 Engine Wire Harness.
- wtb em1 engine harness, ek hasport mounts
- WTB: Catch Can
- WTB Stainless steel tubular log manifold and low temp fan switch
- WTB: B16 Skunk2 Tuner cams stage 1
- WTB b18b crankshaft pulley
- Any SSR Magnetic key
- CA: WTB 4x114.3 wheels in 800$ range
- 94-01 Integra mirror triangle covers
- WTB: 93-96 H22A 345cc Injectors ODB1
- <<< WTB: OEM CTR WING >>>
- WTB: 96-98 civic dash BEZEL
- 99-00 Civic Air temperature motor & center dash vent
- 92-95 civic rear dog bone mount
- WTB CTR mirrors, door panels, headlights
- WTB: spare tire lid 94-01 integra
- hood bra for 96-98 civic needed
- WTB: DC5 red recaros
- WTB: engine tidbits (IAC, IAT, timing belt covers, etc) Bseries
- WTB: 15/16" or 1" Master Cylinder
- WTB 96 -98 CTR OEM Front Grill
- wtb 94-01 teggy parts
- WTB: 1 OEM 240cc OBD2 injector & harness
- WTB:s200 Blue Box
- WTB sir lip
- wtb: 92-00 Civic coupe Apexi NOIR/WS2 catback (or just axleback)
- wtb: used B-series RMF Narrow header replica
- WTB: Stock B-series 240cc injectors!!
- WTB: 99-00 Civic Complete Power Window And Lock Conversion
- 5th Gen Prelude Projectors
- S2K cluster needed
- LOOKING TO BUY: 99-02 ACCORD V6 TRANS
- WTB: OEM 99-00 Honda Civic Si Rear Lower control arms
- Extended ball joints/roll centre adjusters for EK/DC....WTB!
- WTB: Big parts list for b18b1 turbo
- WTB: 96-00 ex tranny
- WTB 99-00 OEM SIR headlights mint
- WTB: Sell me your JRSC or Greddy turbo setup for GSR!!!
- WTB 5x114.3 17x8 to 8.5 +30 to +35 Los Angeles
- WTB: B18C Timing Cover
- WTB: CTR Rear Lip
- wtb salvaged or wrecked s2000 for project car
- koni neuspeed/sp3 rear shocks civic 92-95
- WTB 92-95 civic EX
- WTB Civic EG EX/Si Lip, OEM 92-95
- WTB: B-series cable trans
- WTB: B series spark plug cover
- WTB: Integra Parts
- WTB: B series block
- looking for b16b ctr rods
- whose got cheapest prices on hondata??? need asap
- WTB: B16/18 dropout or engine/trans
- WTB: 1996-1998 Civic DX ECU (for automatic transmission)
- WTB. 98+ Integra Parts. suspension/exhaust/exterior
- wtb
- WTB Crank pulley from a 1995-1997 V6 Accord.
- WANTED: OBD1 P72 GSR 5SPD ECU - VIRGIN
- WTB: OBD-O B18 LS engine wire harness
- wtb:h22 pro1's
- WTB: UKDM Fog Lights
- EG Hatch PASS FENDER!!! QP,Side Skirts/hood more...
- wtb h22 50mm crank
- wtb:thermal 3" exhaust and del sol seats
- wtb: 94-00 integra hood release cable
- WTB: B series CF Spark Plug Cover (ITR Style)
- WTB B series Aftermarket Cam Gears
- WTB: CLEAN!!, GSR SWAPPED DA
- wtb: 94-01 integra clutch kit
- WTB: coilover sleeves for 94-01 integra
- WTB: Hasport Mounts - B Series - 96 Integra
- WTB/TRADE: GSR throttle Body OBD1
- del sol interior plastics
- WTB: Prelude Top Hats ASAP
- WTB 98 civic alternator and pigtail
- WTB: OEM 94-97 integra headlights
- WTB 98-01 DC2/DC4 integra front/rear bumper.
- last items WTB before swap/break in
- WTB CTR Door Interior Door Handles
- WTB: H22a4 manual wiring harness and ecu
- Rear camber kit ed/ef civic
- F22a ARP head studs
- WTB: 92-95 Civic OEM Moonroof Visor
- WTB: Clean Title, Low Miles 1998-2001 GSR. Close to Stock as Possible
- rocker assembly b18c1
- WTB. gt35r or gt42r complete turbo kit for b16 head
- WTB S2 manifold or old blank Blox manifold
- WTB gsr oil pan::::
- sleeved h22a4 block
- WTB 4040 Brake Prop Valve for 99-00 Si!!!!!
- WTB FA5 lowering springs or coilovers.
- WTB: Integra Type-R
- Pa: WTB: Cat-Back for ej8
- wtb! CRX/CIVIC EF TRACTION BAR!
- WTB: JDM F20B / H22 Exhaust Manifold Header
- WTB GSR OEM OIL PAN
- Strutsssssssssss
- ****WTB Engine Mounts**** FL
- WTB Charge pipe 92-95 civic type s flange.
- wtb silver side mirrors for 99 civic
- WTB: Thermal catback for 92-95 civic hatchback.
- CX/VX transmission
- WTB apexi n1 catback for 2 door integra!
- wtb: d16y8 head
- Hydro Clutch Disc-anything sprung no stock
- WTB 92-95 eg Driver side mirror housing
- WTB: EDM 94-01 Integra taillights
- WTB LS TURBO and sell/trade my usdm GSR
- WTB: Philly area EG BUBBLE SHELL MINT CONDITION
- WTB jdm itr front bumper beam
- WTB: 96-00 Civic EK Parts
- WTB: eg6 amber clock
- WTB: DC Door handles
- WTB: 92-95 engine mount for ac compressor bracket
- B16 longblock
- wtb ek9 oem spoiler
- WTB D16Z6 intake mani
- WTB: EG Rear Disc Conversion + Gs-R fronts (Good Condition)
- WTB: jdm ITR wheel
- WTB: JDM ITR Driver side fender
- need 92-95 honda civic dash
- WTB 88 clutch and flywheel civic/crx
- WTB GSr or type R stock Rods
- WTB: 03-05 EM2 Gauge Cluster (Coupe)
- Del Sol Sound System / Stealth Box
- WTB aem water methanol kit
- 90-91 Civic Drivers side sidemount seat rails...Willing to pay 5k
- WTB: 96-00 Civic Door Panels (powered)
- WTB: Coilovers //\\ 98 Civic Sedan
- WTB: B-series Adjustable Cam Gears
- ***99-00 CIVIC SI T BRACKET ASAPPPPP***
- Nardi horn button with cruise buttons
- D series used clutch
- looking for a jdm ef hatch front end
- 15x7.5 wheels for a 98 Integra
- WTB: OEM Alloy Wheels from '95-'97 Accord V6 (SoCal)
- WTB::: Forged pistons 81mm b series
- Wanted: 93 EX complete timing kit
- wtb ef lowering springs
- WTB: cf hood for eg hatch
- wtb: b18c1 gsr block mount 3 hole
- WTB: Koni Yellows
- WTB: 99 civic jrsc pulley d16y8
- WTB: shiftlinkage
- WTB: Del sol seats and other eg parts
- WTB: 99-00 civic coupe parts!!!!!
- WTB: 99-00 Fogs / Lens Only / Any Brand
- WTB d16z6 complete swap or longblock ASAP
- wtd t3 ar 82 4bolt backhousing
- wtb:SSR exc centercaps
- WTB C&R FULL SIZE RADIATOR
- WTB gsr stock airbox with reserve air tank.
- WTB: Ek Parts ASAP!!
- WTB: 96-00 civic coupe parts!!!!!!!!!!!!!!!!!!!!!!!!!!!
- WTB: 92-95 VSS
- Need '97 Civic EX/AT exhaust manifold, NorCal
- WTB: RSR Ex-Mag Cat Back / 92-00 Civic coupe/sedan ONLY
- WTB: (1) 16" 4x100 Spun Supamesh Gold
- WTB: 92-93 Integra GSR Spoiler/wing light asap!
- WTB omni front lower control arms
- Velocity Stack filters for OBX/TODA itb's
- WTB: B18c1 Timing Cover
- WTB: obd2 Gsr dash harness
- wtb> wideband
- WTB: OEM ITR GRILL CLIPS
- WTB: 99-00 Si EM1 Air Intake
- 92-95 Civic Rear LCA's (Skunk 2 preferably)
- WTB EG HATCH Interior
- WTB B Series Clutch Disk 6 or 4 puck
- WTB Del sol drivers whole door and window
- WTB: OBD1 Gs-R/B16 Distributor in Working Condition
- WTB Eg/Dc Suspension
- WTB: OBD0 to OBD1 conversion harness. *ASAP*
- WTB: 2004-2007 s2000 AP2 wheels
- WTB: B series vtec and h22a valve covers
- WTB coilover suspension for eg/dc
- *WTB: itr rear seat/eg hatch parts help me!!*
- WTB...EF traction control bar...
- WTB: Nice fitment wheels for my s2000!
- Looking/WTB: FULLY BUILT Long block/complete B-Series motor
- wtb: 5x114.3 knuckles or complete setup
- Looking to spend 3000
- WTB:Innovative Mounts for EJ6 (2 Bolt Post Mount) MID-WEST
- wtb: 1000cc injectors
- WTB: EM1 Test Pipe / 2.5" / Adjustable
- WTB : Civic 96-98 cup holder ** complete**
- looking for a real ef brah
- WTB: 99-00 Civic Radio Din Gauge Pod Holder
- WTB: DA exhaust
- WTB: b series transmission. preferably LS to keep cost down.
- 95 gsr oem cat
- P30 intake manifold
- WTB: SOHC Header
- WTB b15b7 sedan exhaust mani
- wtb: h22 cam gear,s2,bdl,ect
- WTB: D16z6 Long block, short block..... w/e
- Wtb F23 crank
- WTB 4dr GSR!!
- jdm head lights and corners eg6
- WTB skunk2 cam gears for b series..oil catch can
- OEM EK4/9 Rear Spoiler
- WTB: OEM DelSol Bra / Nosemask
- WTB: Hydro B series axles
- WTB: Integra Front Subframe Brace / Rod / Bar
- WTB EG SI-R CENTER CONSOLE
