View Full Version : Want to Buy
- Valve spring compressor
- WTB: Authentic Spoon Sports H22 Tune
- Wtb 1 eagle rod CRS-5394-B
- wtb:SI WHEELS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- wtb Gsr shift knob, bumper quick release ,del sol ac bracket
- Blox aluminum dual core radiator
- WTB: P73 a03 usdm itr ecu
- WTB: OEM EK9 RECARO SEAT RAILS
- WTB: P73-A02 ECU
- WTB: F22a H23 Bisimoto Header
- F22a H23 Bisimoto Header
- Wtb: B18c5 crankshaft
- Looking for High Comp. B Series Block
- WTB: 1994-2001 Integra 3rd brake light
- aftermarket engine parts
- Wtb: 88-91si air intake/lip and 87 teg lip
- WTB eg6 sir interior checkered pattern
- WTB// JDM DC2 Integra srs steering wheel
- WTB: Spoon Twinblocks In Good Condition
- WTB: Steering Wheel Hub
- WTB pistons, rods, b series mounts, clutch, gsr cams
- WTB: OBD1 GSR Harness
- WTB: D Series Pistons
- WTB: Prelude Neuspeed Race Springs
- WTB: Authentic BBS RS 17" 5x114.3
- wtb eg 40/40 p/valve
- Wanted: Shipper
- WTB Integra DC2
- WTB 99-00 OEM Civic Headlights
- WTB: Any interesting shift knob that fits Civic
- WTB: GSR or 99-00 SI seats? MINT blk cloth
- WTB Stage 1 or 2 H23 Camshafts
- WTB: Beaks or Similar rear x brace - EK hatch
- Need b series build
- WTB: EG8 D15B Engine / Long Block in MidWest
- OBD2a connector plug
- wtb. ukdm eg gauge cluster
- WTB: Stock B16 valve cover
- WTB 440 injectors
- WTB: 97-01 Prelude Ignition Lock Cylinder
- WTB civic 92-95 quick release and short hub
- WTB B series VTEC spark plug cover.
- wtb: 94-95 integra Dash/cluster/radio harness obd1
- WTB: 1999 Acura Integra Carbon Fiber Hatch
- Help me honda lovers! WTB b16 for 95 Honda Del Sol Si
- Stark carvings
- WTB LS Block or Long Block
- wtb b18c1 top radiator hose housing
- WTB: QSD H2B kit
- WTB: B-series Delsol PARTS
- WTB- eg Civic si Hatchback
- WTB the under steering column harness 5th gen prelude, uncut or clean
- WTB: 96-00 Civic Window Cowl and lower radiator bushings
- Wtb: d series edelbrock intake, stage 4 clutch & ek x brace
- WTB: 96-00 EK coil overs.
- WTB Lowering Springs 2" 89 Civic Hatch
- WTB G3 Integra MISC Heater core parts!
- WTB LS Rods and 81.5mm pistons
- crv 5 speed parts needed
- WTB : 92-96 H22 Prelude (Oklahoma or Surrounding areas)
- Wtb: neptune rtp
- wtb 44mm wastgate elbow
- WTB: B18C1 (GSR) CRANKSHAFT
- Wtb b20 block and internals
- WTB: Neptune Demon RTP
- WTB: phearable 70mm TB b series
- wTB: EG steering wheel set up and other stuff...
- Wtb clean stock ej8 dc4 dc2 em1 NJ/PA
- WTB: JDM F22B DOHC WATER PUMP
- H22 RLZ/4piston Head $1000+
- WTB: Jdm ITR HOOD
- Wtb: 98+ integra lights
- WTB: Wire harnesses and engine mount
- WTB: 94-01 integra coupe stock springs
- WTB: CTR Cluster Bezel
- WTB: K20a3 Purge Valve Control Soleniod
- WTB integra tan door panels
- 92-95 D16Z6 Exhaust Manifold
- wtb b16 parts
- wtb: 96-98 tail lights
- WTB: H22 Intake manifold.
- WTB H22 P13 OBD I ECU
- WTB: Crower402 or Part Number: 62402-2 for b18/b20
- Scale model Mugen RNR wheels
- WTB: a few parts to finish my ek hatch build
- WTB: OEM Intake for 99-00 EM1
- WTB:Differential ring gear & final drive B series Hydro
- WTB: Full Blown dual pump hanger
- Nice b-series header
- Want to buy B18C1 Bare Block
- WTB Buddy Club Front Camber Kit 92-95 Civic
- lsvtec line, fittings
- WTB: Red base Honda PRIMO banner (js racing)
- WTB OBD2 distributor
- WTD any vortech parts for civic 99-00 si
- WTB: Demon and Neptune RTP
- WTB b20 distributer and obd2 to obd0 disty harness adt
- wtb an 92-92 oem carbon fiber front bumper
- WTB: MD Single Gsr Blade Wheel(curbed, bent, shitty paint, doesn't matter)
- WTB: Civic Hatch or Integra Shell
- Have a junk head? I need a B16 cam cap and bolts
- oem 2000 s2k taillights
- WTB: 44/46mm wastegate
- WTB valvetrain for b series vtec head supertech or ferrea
- WTB: D16Y8-Z6 BLOCK + JACKSON RACING D SERIES SUPERCHARGER PARTS
- Need parts asap!!!
- WTB: 90/91 CRX radiator fan/ upper mounts
- WTB h22 alternator relocate bracket
- Wtb ctr/ itr cams not wiling to pay an arm or a leg for them
- wtb: t25 to t3 adapter
- wtb fipk or comptech air intake for s2k
- WTB: AEM Digital Oil Pressure Gauge
- wtb: 2000 integra coupe tail lights and black rear bumper
- WTB RBC ecu
- WTB: B18C1 crankshaft
- Wtb aem epm and k smart coils
- wtb: 99-00 civic si front lip
- WTB: 96-00 civic sedan thin side moldings (fender)
- wtb: GSR BLades
- Moates Ostrich
- WTB: Buddy Club Spec 2 Catback Eg hatch
- Wtb rsx shifter box and cable
- WTB: JRSC for 02-06 RSX complete
- WTB: b18c inner timing belt cover
- WTB 15x7 4x100 Enkei Nt03
- Wtb down pipe 4 bolt 3 inch.
- WTB type r 4.7 fd
- wtb personal benetton whhel
- gsr/itr crank moates burn2 itr package
- wtb jdm eg driver side headlight will buy both if needed
- WTB: Honda Books
- WTB: SLEEVED BLOCK B18 LS GSR USED NEW
- GO AUTOWORKS turbo piping / kit b16 or b series
- WTB. hondata CPR
- B18C1 OBD2
- WTB: Stock D16Z6 Exhaust Manifold
- Wtb: itr wing
- EK B Swap Brackets
- WTB: BNIB honda access fog lights Eg
- WTB : S2K AP1 wheels
- WTB OEM Side Skirts Honda Civic coupe EX
- Wtb... Carbing strut bar
- wtb hondata v2 ecu
- wtb b18 dizzy and clock sping
- WTB: EG hatch mid wing
- WTB: Civic VX Wheels, willing to ship to Canada
- WTB B16/ITR Skunk2 Pro Intake manifold , skunk2 68mm throttle body
- WTB: Spoon horn button
- Looking for gsr head parts!
- WTB 94+ integra LS OEM intake airbox & elbow
- WTB: Acura EL Cluster
- RHD autio center console EG Civic
- WTB: RHD EG conversion or RHD EG shell
- WTB 99-00 SI DRIVER SIDE POST
- WTB: D15B7 or D16Z6 ENGINE - GOOD RUNNING CONDITION - NEAR PA/MD
- Wtb: 92-95 Civic Cx/Vx intake tube
- WTB: ls rods
- WTB: Sleeved GSR Block
- wtb h22 swap mounts 96-00 civic
- WTB Pristine Gold Nardi Wood Grain Wheel
- WTB: B18C, GSR, P72 Crankshafts
- EK/EM1 parts
- WTB ej1 interior parts and exterior parts
- 2002-03 Acura TL-S Driver's side seat cover (Beige/Type F)
- Wtb pic r4 coilovers ek or eg
- WTB: OBD2 B-Series Non-VTEC dizzy
- 82mm Pistons
- need to buy DA9 jdm front end stuff! insurance check!
- wtb: enkei rct1 wheels
- WTB: Blue Status Seats EG
- integra type r trunk wall brace
- WTB : B series and H series vtec valve covers
- GSR PS pump&Brackets/ b18b1 full engine and tranny/ ac comp and brackets!
- WTB: Axis Shadow Wheel removable ring/lip trim
- WTB: 94-97 ACCORD COILOVERS
- WTB: REAL OEM CTR WING, OEM/aftermarket fog and sidemark for ek - Sacramento AREA!
- gsr block
- WTB: id 2,000cc injectors
- WTB b18c1 gsr header
- WTB: Koni Yellow Shocks Set for 94-01 Integra 92-95 EG Civic
- WTB: GT Style Mirrors for EG APR, Spoon, M Racing, First Molding, Vision
- itr innards and obd2b p73 ecu or p72 ecu with or without imm
- B16 head
- WTB: EK civic hatch mud guards all 4
- wtb ctr wing base and 99-00 civic hood bra
- WTB: Stock B16A Valve Cover
- 2005-2006 RSX Tail Lights
- WTB : A stock Shiftknob from 94-97 Tegg
- Wanted! Crx climate controls, brochures, fog lights
- Lf: dss 5.9 b series axles/ek9 CTr headlight
- wtb dc rear antenna
- WTB EP3 WING ASAP!
- WTB/WTT: 99-00 SI-R Headlights
- Wtb 99-00 ek power window switches w/inserts from door.
- WTB: 88-91 Ef,crx Pedal assembly!!!!
- WTB: 99-00 OEM EK9/CTR Headlights
- wtb: radiator and IAT connector for 97' civic
- wtb 07 si sedan parts near Springfield Missouri area
- Wtb 5.46 final for k series
- WTB full b series swap w/ tranny SAN DIEGO CA
- EK hatch muffler OEM JDM
- WTB: ITR intake cam
- WTB: B18b obd2 lower timing cover
- AEM EMS OBD-1
- WTB- 92-95 EG H/B clear taillights!
- WTB : 98-01 integra type r front lip
- LTB crower 404 & ef parts
- wtb: 95 hatch side molding and oem headlights
- WTB: GSR PerformerX
- WTB b16 or GSR head
- WTB Del Sol B series shift linkage
- wtb: 15 or 16" Rims
- Wtb turbo
- WTB. Dashboard trim
- wtb k series parts / ep3/rsx parts
- 98+ ITR OEM lip
- WTB: 1-2 Slider and Hub for Hydro GSR Transmission
- H22 IACV OBD1 2 wire type.
- B series tri y headers for my gsr
- WTB: Spoon Twinblocks for ITR
- WTB: 96-98 EK civic hatchback tail lights
- WTT: trade me for my j32a2
- WTB B20 CRV CRANK PULLEY
- WTB: Integra LS transmission.
- WTB ARP rod bolt (1x) for d16z6
- WTB: Stock OBD1 ls injectors and 2.5 test pipe asap
- Vented valve cover b16 GS-R -10AN
- WTB:96-00 civic auto trans
- WTB Sleeved d16 bare block
- WTB: gsr/b16 transmission parts
- crx parts
- WTB quick release setup w/wheel EG/DC spline
- wtb p28 chipped
- WTB: Stock B18C1 GSR Parts
- OEM h22 valves
- wtb: cheap v mount intercooler
- WTB DC INTEGRA HUB/QUICKRELEASE/WHEEL
- Need a rhd conversion for eg 92-95 civic
- WTB GREDDY SP2 EXHAUST
- WTB: EK CIVIC DC INTEGRA OR DELSOL SHELL CHEAP! LOCATED WITHIN COUPLE HOURS MD/PA
- WTB: 32mm 5 LUG w/ wheels
- Wtb turbo cams
- wtb: Champ-White USDM Integra Type R Front End
- 1996 hatch MANUAL window regulator
- WTB: ITR/CTR Cams
- want to rent garage workspace
- Wtb lower front control arms for Gsr cheap
- WTB: Hondata S300
- WTB misc ef hatch parts
- Wtb: Comptech spark plug cover for S2000 and battery tie down
