View Full Version : Want to Buy
- WTB: BLACK Shifter Area for 92-95 EG.
- WTB: Stock cat converter
- WTB: obd1 Integra automatic ecu
- WTB: GSR Block With crank
- WTB: EX Wiring Harness
- wtb:b20 block come one someone gotta have one!!!
- WTB: B18C5 Longblock only
- WTB: S2000 parts
- WTB: Del Sol Rad Support (core support) + Any other Sol parts
- WTB: GSR crank pulley
- WTB: Takata Harness, Autopower 4 Point Roll bar 4 DC, Koni Yellows for ITR
- WTB: B-series Exhaust manifold
- WTB: obd2b gsr ecu
- WTB: CRX 88-89 HF wiring harness!! needed badly!
- WTB: OBD1 LS ECU & Dizzy
- WTB: F&R 92-95 HATCH MUD FLAPS
- WTB: T1R, Spoon, Mugen 2.5 Collector Header
- wtb: h22, b series parts, integra, hatch
- WTB: brake kit
- WTB: 96+ Integra Driver Mirror
- wtb: b18a1 tranny for my crx or any suggestions that anyones has for a b20vtec need tranny
- WTB: K20a2 Shortblock
- WTB: Integra RS Brake Parts for NON ABS conversion.. BOOSTER, MC, PROP, LINES!@!
- WTB: OEM Type-R skirts - Both stock and optional skirts will work....
- WTB: 15-16" Wheels <<<
- wtb: 92 95 hatchback rear strut seat
- WTB: SpeedMaster SM-046 (sio cali)
- WTB: EG lip, GC coils, DOHC VTEC VC, JDM parts, etc.
- WTB: WINGS WEST RACING SERIES BODY KIT - CANADA
- WTB: front driver & pass side fork's for prelude suspension
- WTB: 96-98 EK HARNESS ASAP
- WTB: stock 99-00 Civic Si Exhaust
- WTB: Integra 98+ rear bumper
- WTB: EK AC vents and etc...
- WTB: 99-00 civic si prop valve.. need ASAP
- WTB: CTR LIP or C-WEST BUMPER!
- WTB: integra stuff (NORCAL)
- WTB: Tanabe, Blitz; other catback for del Sol VTEC
- Wtb: Foglight harness for EG
- WTB: Goodridge SS brake lines...
- WTB:Stock Z6 throttle body and timing covers
- WTB: Z6 dizzy
- WTB: 96-98 ek side skirts!!!!
- WTB: GSR UPPER POWER STEERING PUMP BRACKET.
- WTB: OBD-0 DIZZY
- WTB: NSX Headlight Assembly ....
- WTB: Clean Set of Civic Si WHeels...
- WTB: Radiator for 98 Acura 2.5TL
- WTB: 2GEN LEGEND BLOWER MOTOR
- WTB: b16/b18 hydro Tranny NO GRINDS Northeast Area
- WTB: 2 Alpine Type R 10" 2 ohm DVC subs
- WTB: 94-00 light grey integra front seats (so. cal)
- WTB:Many things for my 92 hb
- WTB: IAB Control Solenoid and Check Valve for secondary runners
- WTB: JDM EG Centerconsole (connects underside of radio to lower cupholder area)
- wtb: jdm itr headlight harness(non-hid)
- WTB: d15b7 engine head
- WTB: TRANNY, ECU, B20Z Block, GSR HEAD, FULL SWAP ETC...
- WTB: front mud flaps and JDM window visor for CRX (so-cal)
- wtb:civic stuff....
- WTB: NSX calipers
- WTB: 4 15" Tires in Seattle Area
- WTB: 98+ ITR LIP
- wtb: delsol or intergra seats in socal only
- WTB: 1 Prelude Type S piston Standard Bore
- WTB: Knock Sensor OBD2 for h22a4 2000
- WTB: ITR cheap $$$
- WTB: Integra Type R Crank and Rods
- wtb:cable ls tranny ,90-91 integra axles and half shaft ,manual 90 integ ecu mounts
- WTB: 96 accord high flow cat
- WTB: 92-95 civic, 94+teg suspension
- wtb: 94 hb cx oem rear struts
- WTB: EM1 Cluster
- WTB: ys1 LSD!!!!
- wtb:94-01 integra rear motor mount
- WTB: B SERIES AXLES and HALFSHAFT
- WTB:TRANNY GSR TYPE R HELP!!!
- WTB: Balanced & polished crank for y8 block!
- WTB: 99-00 hatchback both doors
- WTB: single cam long block!!!! anything d16 and cable 5spd trans d-series
- WTB: HID ballast (McCulloch)
- WTB: Cable b16/b18 transmission
- WTB: SSR Superfin caps/locks (2)
- WTB: 98-01 DC2 Front bumper (black)
- WTB: S2000 Steering wheel *W/ Airbag*
- WTB: GSR head! Just the head!
- WTB: B-Series Hydro tranny ASAP
- WTB: D16Y8 fuel rail........
- WTB: 99-00 Electron Blue Si TRUNK LID
- WTB: 96-98 CTR headlights
- wtb: 98+ driver side fender liner / splash guard
- WTB: ITR JDM OEM HID Headlights (Complete)
- WTB: 98+ Integra front & rear bumper, and headlight assembly.
- WTB: Integra Mirror
- WTB: 17" Tires North Carolina
- WTB:b20 block and vtec head (gsr,type r,b16) or bare head
- WTB: EG RHD conversion or front clip.
- WTB: B-series dipstick(engine)
- WTB: Ti-retainers
- WTB: WINGS WEST BODY KIT
- Wtb: 94-97 Front
- WTB: Stock USDM ITR Front and/or Rear Seats.
- WTB: 94-97 Accord Power Steering pump
- WTB: D15B2 head
- WTB: 3" catback for my 95 LS
- wtb: vtec mechanism
- WTB: non-VTEC ecu *need ASAP*
- WTB: Cut-out doors or stock doors for EG HATCH ASAP!!!
- wtb: 92 integra ebarke cable
- wtb: 90-91 Integra Stage 3/Stock clutch used/new
- WTB: 90-93 Integra Carpet + Black Fenders
- WTB: 92-95 EGR
- WTB: 92-95 eg Driver door
- WTB: Wings West 94-97 2Door Integra side skirts
- WTB: LIPS!!!!!!!!!!!!!!!!!!!!!
- WTB: 89 accord manual transmission
- WTB: Combination Switch for 92-95 Civic Hatch
- wtb: ClutchMasters stage 3 clutch (CM3)
- WTB: D16Z6 Power Steering pump, Del Sol ash tray, Del Sol 3rd brake light
- WTB: Socal 97 2D Hood / Bumper / Grill (Like by this week!!!)
- wtb: Broken usdm type r cluster, or carbon fiber bezel trim with cluster gauge faces (speed rpm etc)
- WTB: DOHC vtec head parts...
- wtb: JUN oil filler cap
- WTB: Nology Spark Plug Wire for a B18c1 motor (Red)
- WTB: b16 pistons/bearings
- WTB: Stock EG Manual Mirrors
- WTB: H&R Springs and Ajustable Shocks Accord 5th Gen
- WTB: Stock EK Intake
- WTB: B series Hydro Tranny case and VSS differential gear
- WTB: CF Lip for JDM Integra
- wtb: front lower motor mounts w/ tranny side bracket
- WTB: Honda Center Caps & Emblems
- WTB:92-95 civic left mirror
- WTB: 99-00 Milano Red Painted or CF Front Lips *So.Cal*
- WTB: 94-01 GSR tranny housing
- WTB: Tokico luminas for crx.
- WTB: valve adjustment tool
- WTB: stock side skirts for 92-95 coupe......soCAL...
- WTB: ARC splitter for EK.
- WTB: vtec solenoid plugs, knock sensor plugs
- WTB: IACV that will fit 96' Teg LS...
- WTB: Built Sohc Vteac Head
- WTB:P28 ECU and Wiring Harness!!!!!!!!!!!!!!!!!!
- WTB: JDM ITR aluminum a/c mount bracket !!!
- WTB: 88-89 CRX front bumper in mint condition or close to mint
- WTB: 89+ Rear LCA's lower control arms. EG, DC, EF doesnt matter. what you got?
- WTB: b16 short block
- WTB: 98-01 integra parts
- WTB: drivers side mirror block off plate (OEM Honda)
- WTB: Civic Parts [ASAP] // Prefer DFW
- WTB: DC 4-1 header d-series
- WTB:96+ EK body front clip..... engine hardness,headlights,rads,fans,bumper,
- WTB: gsr shortblock
- WTB: Airwalker or BYS front bumper (EK) - Southern California
- WTB: Complete K20A - Southern California
- WTB: EG power steering pump bracket (w or w/o pump)
- WTB: 92-95 EG hatch interior
- WTB: D16 Obd I Alternator
- WTB: Anyone know where i can find some Konig Glides??????????????????????
- WTB:Oem crx seatbelt
- WTB: 5x114.3 Steelies
- WTB: Deep dish wheels (4x114)
- WTB: b16 obd-0 ecu
- WTB: B SERIES SWAP PARTS
- WTB: DA exterior parts
- WTB: hondata
- wtb: ITR rear seats
- wtb: jdm integra-R axles
- WTB: DOHC ZC or 88-91 ex/si engine
- WTB: d16z6 wiring harness!!!!!
- wtb: ITR or RSR EXMag Exhaust
- WTB: EBP Si Lip
- WTB: Racing Hart CP8R 17" Bronze 5x114.3
- WTB: obd1 p72 ecu (94-95 gsr) - have p73 FS to trade if wanted/ needed!
- WTB: AEM Intake for 99-00 Civic EX
- WTB: Back issues or Turbo & High tech (95' -00'
- WTB: Blue Rays or Spoon Lugnuts 12x1.5
- WTB: Knock Sensor For JDM GSR
- WTB: Black Interrior Pieces for 92-95 Civic Hatch
- WTB: civic 00-99 oem red/clear tails, 92-95 vinyl front seats, 92-95 jdm cluster 5sp
- WTB: single DIN honda CD player, prefer broken
- WTB: Cable B16 Tranny preferred with LSD and a clutch
- WTB: z6 dizzy
- WTB: Benen Front/Rear Tow Hooks ***CASH ON HAND***
- WTB: ITB's 4 a B16A
- WTB: 1998 integra GSR comptech header
- WTB: 92-95 del sol non-vtec ecu....
- WTB: JDM Black housing 94 -97 accord headlights
- WTB: B series alternator brackets
- WTB: Headlight passinger or a set 98+ integra
- WTB: Carbon fiber side mirrors for 98 integra??
- WTB: JG Victor X Intake Manifold (GSR)
- WTB: p8r head *rare* have cash.
- WTB: CATCHcan..... in socali
- WTB: 94-97 Accord Security Attachment Kit asap! 08e55-sv4-101 attatchment kit
- wtb:shock forks and rear lca's
- WTB: 15" ROTA SLIPSTREAMS, FLAT BLACK......PHILLY AREA!!! LET ME KNOW!
- wtb: nitrous bottle heater
- WTB: SoCal Orange County Area...Some EG parts...
- wtb:96-98 obd2 distributor
- WTB: 92-95 EG Fender liners, both sides.
- wtb: thermal muffler
- wtb: sohc d series vtec cam cover
- WTB: gsr shortblock b18c or b18c1
- WTB: the fender V-TEC moldings from a 92-93 GS-R in socal
- WTB: 99-00 SI rear bracket
- WTB: New/Used EG Driver side Front Door.........have cash in hand......
- WTB: GSR Cams
- WTB: b series starter
- WTB: 14-15" Wheels with tires in or near WILMINGTON, NC
- wtb: need any color 99-00 bumper,grill and fenders
- WTB: and bseries or h series tranny!!!
- WTB: Misc. Alternator parts
- WTB: 92-95 civic oem hood (painted black)
- WTB: ASAP oem jdm itr exhaust manifold
- WTB: obd2a b18b1 complete ls swap for my 98 hatch!!
- WTB: 92-95 Civic Drivers Side Manual Window Regulator
- WTB: 96-97 Accord front lip
- WTB: Eibach Pro Kit, Neuspeed Sport, H&R OE springs...90-03 Teg
- WTB: 88-89 CRX Si Cluster, 88-91 Civic Hatch/CRX stock hood!!! -SoCal
- WTB: JDM ITR 4-1 Header
- WTB: B16 or type R head
- WTB: One 14" Civic wheel
- WTB: LS Tranny, 680CC Injectors, Half Core Radiator, 68mm+ TB, Quaife LSD- AND MORE - Stuff for sale
- WTB: B16 Head or B18C Head.
- WTB: D16z6 upper timing belt cover
- WTB: 96-00 Civic Hatchback Headliner
- WTB: engine harness for 91 crx hf
- WTB:99-00 CIVIC COUPE VSM FRONT BUMPER AND PASS. FENDER
- WTB: knock sensor harness plug
- WTB: steering wheel RSX,S2000,itr ctr
- WTB: 96 P13 Prelude ECU OBD2 USDM!!!
- WTB: 94-00 stock integra hood <$40
- wtb:recaro srd or speed in black !!!!!
- WTB: Tanabe G Medalion Muffler/Exhaust
- WTB: These plugs + 3" of wiring
- WTB: (2) HX rims ***NORCAL*** or ***SOCAL****
- WTB: cams for a b seris
- WTB: GSR oil pan, pickup and tray...
- wtb: integra ls throttle body, ecu
- WTB: 94+ B18b Header and exhaust manifold.
- Wtb: p28 or p30 Manuel Ecu
- WTB: RHD CRX front cut
- WTB: 92-95 OEM front bumper, hood, fenders
- WTB:B series flywheel bolts
- WTB: Koni Ground Control coilovers for 94+Integra
- WTB: RAYS BLACK LUG NUTS
- WTB: del sol dual core radiator for my b16
- WTB: half shaft/ intermediate shaft for integra (manual)
- WTB: D16Z6 Dizzy
