View Full Version : Want to Buy
- WTB: 94-97 F22b1 With 5mt
- WTB: Stock radio for a 96-98 civic EX
- WTB: 14" Steelies and SNOW TIRES
- Looking for 4x114 NR10
- wtb 96 d series vtec engine harness.
- 94+ gs-r 5th gear set .787 gear ratio only!
- WTB~ OEM Rear muffler only.
- WTB: ITR Tranny
- WTB: LS intake manifold
- WTB 97-01 prelude headlight bulb socket
- WTB b16a2 camshaft holder/tower
- wtb socal the oC: looking for a clean non moded p28 ecu
- WTB: Integra Fender and DB8 Driver door
- wtb 91 crx lowering springs
- Oil Sandwich plate adapter
- wtb: hx wheels, with or without tires
- EG6 Door
- WTB: B16 / B18 swap
- wtb:99-00 fog light oem bracket
- WTT: Momo Italy Corse Steering Wheel + NRG Short Hub + NRG quick-release for BLK S2K steering wheel!
- WTB GSR crank
- looking for transmission
- WTB: Ls obd1 distributor
- WTB: OEM integra type r front lip 98-01
- WTB 96 CIVIC and DX emblems
- WTB stock ek Hatch exhaust
- WTB B18B stock pistons and rods
- WTB: Tein S-tech 90-93 Integra
- WTB: CRV (B20B4) cylinder head
- need one a/c line for dc2 97
- WTB 92-95 civic cabin harness
- EK coupe rear Shocks
- WTB Fender hardware for ef
- WTB: Many OEM EK parts-all interior pieces, cruise control motor, st. wheel, seats, exhaust, etc.
- WTB: 98 ITR long block
- ****WTB; hks cam gears for b series****
- wtb:Vision carbon fiber spark plug cover for type r
- WTB: skunk2 stage 2 cams
- BUYING: Progress Lowering Springs for 92-95 Civic Coupe (GOOD CONDITION)
- WTB 92-95 eg Civic vtec dash floor engine bay harness complete uncut manual
- WTB ASAP
- WTB. 96 type r brake conversion!!!!
- WTB: '01 integra cabin wire harness
- WTB:JDM Rando Sports body kit for DC2
- wtb VTEC cam holders, caps, rails, with bolts....
- REAR LCA's from 94-01 Integra or 92-5 Civic
- WTT: F1spec type 3 seat for good condition integra cloth seats
- WTB: Honda Prelude 92' Si H22 parts
- need a vtec solenoid...
- WTB: 1994+ Integra,DB7, DB8 Driverside Door (front and or rear) Northeast
- i need a vtec solenoid...
- WTB Front Bumper support EF
- WTB: 1 15" Kosei K1's wheel 5 lug
- WTB B16 VALVE COVER
- WTB intercooler and piping that will fit behind stock bumper for 92-95 civic
- WTB Header and exhaust for b18a1
- WTB: OEM 05-06 headlights
- WTB: Nardi ORIDO STYLE Steering wheel
- WTB: KEYS RACING Steering wheel *Good condition*
- WTB: championship white ek hatch exterior parts
- wtb: 96-00 Civic Fog Light Switch Dark gray, black, type k interior
- ported b16 head by portflow,alaniz or rlz engineering asap
- WTB: Integra ITR wing aka JDM type R wing
- WTB: 97 civic 3dr GSR Mounts/axle
- WTB Rims and Tokico Shocks or any other shocks for 96-00 Civic Hatch EK
- WTB Bare Ys1 92-93 Trans Case
- WTB: Sleeved B18C or B20 Block
- WTB: heater core& inerior crx si harness
- WTB: S2000 Parts AP2 or AP1 rims/AP2 front bumper + Headlights
- STB d16y8 5-speed trans
- WTB: BONE STOCK 92-95 hatch.... shiny or $h1tty... post em all
- WTB: ctr cluster or Ek4
- WTb:Drag/drag 16" gt3's
- WTB non stock aftermarket only vtec cams for b series with or with out springs..
- ---------WTB 4 Wire O2 for D16Z6
- wtb integra parts: gold rota slips, gold lug nuts, short hub
- WTB: 17" wheels (no tires)
- Looking for a b18 block.
- WTB-STOCK D series header for a ek 3dr dx hatch.
- WTB crx skunk 2 dual bend short shifter
- WTB: In desperate need of a obd 0 si harness uncut
- WTB: Integra Fat Five Rims
- 96-00 Milano Red Passenger Mirror
- CRX stock exhaust
- 90-93 Integra Hubs
- WTB: 96+ Integra 1" master brake cylinder & booster
- WTB: Bare H22 Head
- wtb d16z6 crankshaft asap.!!!!
- WTB: OBD2 to OBD1 Injector Clips
- WTB : DA Front Calipers and Antenna Mast
- WTB : 450 Injectors
- WTB: GSR Blades
- WTB:b16 DIY ITBs anyone?
- eg
- WTB: B SERIES TURBO PARTS
- WTB: Type R Motor
- WTB ITR ARM REST with badge!!
- WTB USDM ITR Cluster
- wtb: oem header heat shield for 00 civic cx nonvtech 1.6l
- WTB: Cheap, reliable car $1000 or less
- WTB: 92-95 Civic EG Rear Lower Control Arms
- WTB: 92-95 EG Civic Suspension Parts
- WTB: Tapped d16z6 oil pan, Oil feed+return kit
- WTB - Recaro
- WTB: Resistor Box for Injectors
- WTB: EF9 Mugen Exhaust
- WTB: Extended Wheel Studs (16)
- wanted: ZC ecu
- WTB: B16a OBD1 Engine Harness
- ______WTB: OBD1-OBD2 / 280cc-330cc Fuel Injectors / OEM Map Sensor ______
- WTB: AP1 S2000 Complete Factory Intake Air Box
- WTB-SIDESKIRTS & SI TAIL LIGHTS FOR MY 96 EK COUPE
- WTB: D-series engine for EK
- WTB: set 15" Steelies 4x100
- WTB 92-96 Prelude Cluster
- WTB: SUspension for the s2k
- WANT TO BUY AUTHENTIC MUGEN WING
- WTB: MOMO hub for honda del sol!!! NEW OR USED
- WTB: 99-00 Honda Civic Climate control Harness
- wtb : edm rear foglight for dc2
- WTB: Apexi World Sport or Greddy SP2 or EVO2 Axle Back
- (((WTB))) FRONT WINDSHEILD MOLDINGS FOR 94-01 INTEGRA
- 99 to 2000 fbp civic si oem spolier
- WTB: 96+ 2DR INTEGRA SIDE MIRRORS (BLACK)
- wtb: greddy 94-99 integra gsr turbo kit
- (WTB)= 88-91 EF hatch front end parts
- Smog box for 1984 Civic
- WTB: 1 Oem Acura integra diver's side brake line
- wtb 96-98 Civic EX manual engine harness
- WTB: Intercooler and piping for eg
- WTB: Stock 96-00 ek muffler. NY
- wtb gsr head
- WTB:header for 01 teg gsr
- WTB AEM EMS Acura
- WTB: EP3 skunk2 Coilovers
- WTB D16 Fuel rail
- WTB:> D16Y7 exhaust manifold ASAP~!!!!!!!! who has one?
- WTB: 94 up Integra DB8 Near WA state!!!!
- WTB power window switch for da9!!!
- WTB EF9 front bumper!!
- WTB: RPM Throttle Body 68mm, 70mm or 72mm
- WTB 3 Bar GM Map, 750cc injectors, Coilovers, Lips
- WTB: GSR oil pan
- WTB: 93 Integra Thermostat housing with Sensor
- WTB: 94-up integra FL FL FL!!!!
- WTB: 92-95 EX oem Gauge clutser TACH!!!
- WTB VX Center caps
- wtb gsr blades?
- WTB Civic EG EX Door Panels!!
- WTB: 94-01 Integra Driver Side Fender Liner/Splash Guard with Hardware
- WTB: Stock Rear Swaybar for EK
- WTB 92-95 WIPER SWITCH
- WTB: Si front lip and CTR rear lip
- WTB: Clean, Stockish GS-R
- WTB: 93-97 Honda DelsoL Inside Driver Door Handle
- wtb: STOCK EG6, EG9, EJ1 cassette head unit
- WTB. 99-00 si rear lower trailing arms, calipers, and rotors. trying to do a rear disc swap.
- WTB B series Valve Cover/B Series Timing Components etc etc cams shit to finish my project!!!!
- WTB: Beaks Rear Lower Tie Bar (96-00 Civic EK)
- WTB Sunroof glass 92-95 civic coupe
- WTB small yellow wastegate spring
- WTB: valve cover to s d series
- wtb: front bumper for 5th gen lude
- 1999-2000 Honda Civic Si B16A2 LONG BLOCK NEEDED BADLY!!!!
- WTB- crx si / civic si seats any 88-91
- WTB: Spoon N1 Axle back
- WTB GSR OIL PAN!!!
- WTB spare tire plastic cover board
- looking for transmission case
- WTB a pm6
- WTB: b-series 5speed manual hydrolic transmission
- WTB type R steering wheel
- WTB: OEM DC2 Side skirts, unpainted
- WTB ctr rear tail lights
- WTB: JDM Front Clip (GsR) Complete w/ Motor
- WTB: OBD2 VTEC parts for a LS/VTEC Build.
- WTB-CRX FENDER PASS-CF HOOD
- WTB top mount b-series
- Looking for header and exhaust
- OK: wtb aftermarket radiator 92-95 CIVIC OR 90-93 INTEGRA
- WTB: Civic Si Rims/Wheels with good condition tires
- in need of a si spoiler
- wtb: b18a oil pan
- O2 Sensor for a d16y8
- WTB- CRX EF gauge cluster plugs + wires off 90-91 CRX OR dash harness
- WTB: '96-99 Civic Window Crank
- Civic VX O2 Sensor 7-wire
- WTB
- wtb: lowering springs for 92 civic
- mr5 center caps...
- WTB: B Series Axles And Shift Linkage
- WTB: DA automatic Motor Mounts ALL 4
- WTB: 94-01 INTEGRA Interior · A Pillars · Rear View · Sun Visors · Climate Control · TN
- 96 civic milano red bumpers
- WTB: FULL d16z6 or SOHC vtec swap for 93 EG Hatch
- WTB----B&M Pro-Edge Short shifter...
- slipstream rotas
- WTB: 94-01 Integra Ignition
- WTB: Swapped Crx or Civic hatch prelude to trade or cash
- WTB: JDM 2005 Honda Integra/RSX Owners Manual
- WTB 94- 97 Accord Springs
- WTF:: INTEGRA TYPE R REAR SWAY BAR!
- Wtb. oem del sol bra.
- WTB: Integra Type R Catback Exhaust ITR
- wtb: integar red side mirrors pref 98-01
- wtb/wtb parts for turbo b16 integra
- W2B gsr or type R distributor thats 100%OEM
- WTD: EF Civic bits...
- WTB: Stock Exhaust Manifold for my 96 Civic DX
- WTB: parts for 96 DB8
- WTB or Rent Timesert kit for b18
- EK Hatch ! - Socal
- WTB Tokico Illumina (Fronts Only)
- WTB: Throttle Body with working sensors for a 92 Civic CX D15B8 engine
- WTB: USDM B16 Intake Manifold Complete (BAR)
- wtb: Tial 44mm wastegate .7 bar spring (10psi)
- WTB.STOCK EG COUPE TAILIGHTS AND FRONT CAMBER KIT FOR EG
- WTB: dark grey outlet panel and door sill panel
- wtb: 95 civic ex seats, carpets
- WTB!!NGK BLUE or Magnecore 8.5 spark plug wires, for a B18C1
- WTB - Obdo distributor
- WTB: integra rear bumper
- WTB: 94-97 dx/lx/se stock oem header
- WTB: 95 civic IDLE CONTROL VALVE!!!
- Wanted old money & silver/coins
- value of a 1993 accord, h22
- WTB: EJ8 and EG6 parts, b series parts, rims, exhaust, cheap turbo setup, d series clutch, to much t
- WTB: 92-95 complete shell
- WTB Manual Steering Rack for EF
- wtb 96 civic ex headliner
- WTB: GSR Block
- ((WTB)) **If you have REALLY crappy 94-97 DC2 front seats, I need your rails/sliders**
- WTB Crx tranny
- WTB: tokico blues for 96-00 civic
- WTT: B16 Cable Tranny (with 3rd gear grind) For Integra Transmission, MA, CT, RI
- WTB Left and Right Front Lower control arms for 95 civic WITH swaybar holes
- gsr crank
- WTB - SPORTMAX 501 15X8
- wtb horn button
- WTB d series aluminum flywheel
- ***WTB: GSR Transmission with Quaife***
- EP3 test pipe, bolt-ons, anything else MD
- foglight brakets anyone....i need them!!!!
- rhd crx sir front conversion
- WTB: EK 2 door Lower oem side skirts
- WTB: EG 92-95 civic Complete ac system
- crx d series motor mounts in good condition
- [WTB:] TIAL 38mm Wastegate Body/Bottom Portion
- WTB: maryland NEED Longblock for CRV, need engine B20 ASAP - HAVE CASH - also need someone to do it
- WTB Front and Rear Camber Kit 95 Civic
