View Full Version : Want to Buy
- LOOKING for 1 spare black spoon rIM
- wtb. axle back bolt on exhuast
- wtb tires..15in
- WTB obd1 ecu's in bulk
- lookin for 90-93 teg 5sp rear trans bracket, 5spd trans intermediate shaft, and driver side mount
- wated tranny LS ,b16, gsr got 250 any one wanna sell their tranny
- wtb-? where is a good place.
- WTB: B series driver side axle as a core 818
- WTB: Tons of 94-01 Acura Integra Parts Interior/Exterior ASAP *Chicago Area*
- WTB: 94-95 GSR Cloth Center Console
- WTB: B series axles and intermediate shaft
- WTB: 98+ usdm complete front end
- WTB: OEM 94-01 Integra Shocks and Springs
- WTB evo 560cc injectors
- Looking for a Valve spring compressor...
- NEED d16 block z6 y7 or y8 cash in hand
- WTB: ek civic parts
- PA WTB B16 piston ASAA
- WTB: 94-95 Integra Ls Engine Harness & ECU (OBD1)!!!
- WTB: Looking for a 00 ex s40 tranny man.
- Spoon N1 Muffler Exhaust for DC2 DC4
- WTB: Drivers side EDM power adjustable headlight
- WTB: Hasport EF hydro transmission mount
- Looking for: 3" exhaust system for DC integra
- WTB driver side fender 96-98 civic sedan
- WTB B16 throttle bracket and maybe cable as well!!!
- WTB SSR competition wheels 15 x 7.5 , 4x100
- WTB : LS BLOCK 94-95 around 21811
- WTB H22 Block
- WTB: ITR TB
- WTB: STOCK 06+ SI STOCK INTAKE
- WTB..eh front end. hood, bumper, fenders, hatch, drivers door...CT
- WTB --> steering wheel spacer (80mm and up)
- Team Dynamics Pro Race 1 15x7 4x100
- WTB 02-04 Rsx Type S ECU
- WTB: D16Y8 Head & PM6 ECU
- wtb: 04-05 civic ex m/t
- WTB: 99 GSR head
- wtb: eg8/9 parts
- WTB EK parts. struts, body, sensors etc..
- wtb:asap automatic integra tranny 94 up fresno,ca
- WTB: DC2 PARTS
- WTB: 96-00 Type K Column Cover
- Civic 4 Door
- WTB: 94-01 integra passenger sideskirt
- WTB: D16 TURBO RAMHORN MANIFOLD D SERIES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- WTB 2000 integra rear mud guards...
- WTB: EDM REAR FOGLIGHT
- WTB: 99-00 CIVIC COUPE PARTS
- WTB: Third Break light connector 03 accord
- wtb garrett turbo shaft
- question? will a 2000 coupes front mud grauds fit my 98 front civic sedan?
- WTB: EG manual console
- B 16 Differential, stock.
- WTB: LOOKINGTO BUY ! 96-98 CIVIC MUD FLAPS SPLASH GUARDS! 4DR SADEN
- WTB: Turbo Setup for a LS Vtec EG
- Vtec knock sensor
- b20 a/c mount.
- 99-00 si oem rear motor mount
- WTT: HYDRO GSR TRANS FOR HYDRO B16 TRANS
- wtb: itr rear swaybar endlinks
- WTB CIVIC WITH SWAP SOCAL (714)
- WTB/NEED: ITR, TYPE-R CAI, COLD AIR INTAKE - 3"
- ASAP WTB: Integra DC Turn signal and headlight connectors
- WTB: Ostrich Emulator
- WTB 96 SPEC ITR 4X114 WHEELS
- WTB: Hondata s200 with boost
- WTB... OBDI 90hp d15
- WTB: advan rgII's **********************************************
- WTB EP3 Jackson racing race header.
- wtb: metal trim piece btwn headlights and bumper 90 hatch
- WTB: OSTRICH EMULATOR
- wtb/wtt: 88-91 ef hatch shell/blown motor/running for 300$.
- WTB: 94-01 Integra Rear Bumper
- $$$$ WTB: Gsr blades with tires ASAP $$$$ (San Diego)
- WTB: Front Bumper Corner Brackets. 98-01 Integra (Corner Light, Metal Bracket on Bumper)
- WTB Traction Bar for 92-95 EG
- WTB: DA STOCK HEADLIGHT ASSEMBLY!!! ASAP INTEGRA 90-93 ATLANTA
- blue rays extended nuts.
- WTB: 92-93 GSR ys1, XSi Cable trans with LSD or just LSD alone
- WTB SHELL
- WTB: OEM TAILLIGHTS for 94 -97 ACCORD SEDAN
- WTB: B20 block
- WTB: 96-98 CIVIC SPOON LIP
- WTB - 99-00 Civic SI Wheels
- WTB: B SERIES LSD +++++ QSD H2B KIT
- WTB : 96-98 Civic SIR Front & Rear Bumpers OEM or Replica
- lookin for ostrich
- WTB: OEM B16 CRANK PULLEY
- wtb: spoiler for 93 civic coupe
- WTB/WTT: my new Eagle crank for your ITR or other 2.5" B-series header
- h22 obd2 wiring harness
- WTB Nitrous stuff SHOW ME WHAT YOU GOT!!!!
- WTB Ground Control coilovers 94-01 Integra
- WTB: Apexi S-AFC or S-AFC 2 and PnP harness
- WTB: Crower 403-2 cams 94-01 Integra
- WTB: Ek cargo cover
- 88-91 Civic non-si Distributor (OBD0)
- WTB BARE B18B/A Block!
- WTB 92-95 Honda Civic Mugen Twin loop exhaust!!!!
- b20z water pump
- WTB: D series VSS. i have a 98ex motor shipped to Southern California
- new set azeni rt-615 205/50/15
- wtb 4 bolt turbo flange
- b series flywheel and pressure plate bolts.
- si lip oem
- obd2 oil pump.
- new b series flywheel.
- WTB: 92-95 interior/exterior parts
- 88-89 CRX Si Door Panels and Floormats?????
- WTB: 98+ ITR cluster in perfect working condition.
- wtb prelude short throw shifter
- WTB clean da shell
- WTB: OEM Integra Type R springs
- WTB: Tapped D16Z6 oil pan
- WTB: b series axles, gsr header, obd1 ecu for tuning.
- WTB:92-00 civic or 94-01 teg SHELL. located in mid TN
- WTB 2 16" JDM ITR WHEELS ASAP
- Trading B18C5 84MM Darton Sleeves 84MM CP Pistons NEW OEM Crank
- WTB JDM dc2 fenders
- WTB: VICTOR X INTAKE MANIFOLD FOR B16 CASH IN HAND!!!!!!
- WTB: Ignition switch(elec part) and combination switch for EG
- WTB: P72 obd1 ECU
- wtb: dc2 parts
- WTB: o2 Sensor. four wire for a 16v d15
- WTB 99-00 civic si wheels
- WTB: feeler, 94+ integra coil springso
- WTB jdm DC2 type r fenders
- WTB Oversized JDM P73 ITR Pistons With Rings
- WTB: Wiseco B18c 9:1 Comp piston RINGS
- WTB Decent Condition Del Sol Seats! Maryland Area!
- i need b-series hydro tranny
- WTB: 92-93 GSR, XSi Cable trans with LSD or just LSD alone
- wtb 1994 honda civic coupe HOOD so cali 626
- WTB: EJ COUPE THIRD BRAKE LIGHT!
- WTB B18B CASH ON HAND (cen cal)
- *** WANTED: AfterMarket Rear Lower Control Arms ***
- wtb:eg/dc intercooler piping
- WTB: 98-01 Integra Headlights and bumper lights AGAIN
- WTB: Suspension for 96-00 Civic (Tokico Illuminas, AGX, or Koni Yellows)
- wtb: obdII integra O2 sensors
- wtb:4dr integra black leather seats
- obd2b to obd1 jumper harness.
- WTB: Tapped B16 Oil Pan
- WTB: Throttle Body, Valve Cover, LCA, Wideband
- WTB VIBRANT HEADER FOR H22 NON SH
- wtb 05 06 rsx muffler
- Wtt B16 Tranny for hydro GSR tranny or buy gsr tranny
- WTB: CRV 4x4 5speed manual transmission & shifter & cables
- WTB: front lip for ek civic
- ef si cabin harness and engine harness
- WTB: Roof rack for 92 Civic hatch?!?!?!
- WTB: 94+ Integra ECU Wiring Harness OBD1
- wanted jrsc for b16a
- WTB: Hondata, Uberdata
- WTB: Front lip for 04-05 EP3
- WTB: B SERIES MANUAL TRANS TORQUE BRACKET
- Want to buy rev hard b series intake manifold
- WTB metal piece under tail light 96-98 civic sedan
- h23 shortblock
- WTB~ DA integra intermediate shaft!!!!! ASAP!
- wtb: 99 00 civic si/ex dash harness
- wtb: spoon sw388's 16"
- WTB: OEM Airbox
- wtb 96-00 ex cluster (5 speed) W/ TACH
- WTB: RSR ex-mag 2.5" piping +/- axleback for DC2 00 integra gsr
- WTB aftermarket civic b piping
- WTB: jdm da front & rear bumper support
- WTB: 4pc OEM Lip Kit 04-05 Civic EX Coupe (CDN Si); Ontario
- WTB OEM RSX WHEELS
- WTB - B16 or b17 cable transmission
- WTB: crx si stock exhaust, Las Vegas
- WTB: 94-97 integra mudflaps
- eg hatch help
- WTB: Any d series complete bottom end, unopened in good working order
- WTB: HCP H22 EG Mounts
- wtb: nardi
- WTB: EF Sedan parts...
- the differance between jdm rear bumper and usdm 88 bumper
- WTB: B Series Starter
- WTB! your OLD EXPIRED TAKATA long version harness!
- WTB: Acura Integra Sedan 94+models only
- wtb: tial 44mm wg, tial 50mm bov
- WTB: B series linkage
- WTB : OBD2 Ls head/motor
- WTB: rear T bracket
- 99-00 Civic Si A/C
- Need for a complete wiring harness b16a2 m/t
- GSR knock sensor wire and connector
- SRR Purple LCA EK
- WTB: Nr10'S
- WTB: GSR engine bracket
- WTB: drag slicks 22-24 inch slicks with rims for crx 4x100
- ITR 5-lug conversion complete with RIMS
- WTB: Denso/Matsushita Ballast
- WTB Gramlight * SEE INSIDE*
- WTB: Eg OEM White Driver side Fender
- WTB: DC2 interior seats oem black
- p 75 chipped ecu
- WTB/WTT jdm 0bd1 p72 ecu
- WTB: DC2 THIRD BRAKE LIGHT!
- WTB: Window regulator and ACtuator
- WTB: 98-01 INTEGRA REAR BUMPER
- gauge swap
- motor swap?
- WTB: B series stuff...timing belt drive pulley & oil breather box
- WANTED: HONDA DEL SOL REAR QUARTER PANELS!!!
- WTB: Seats AFTMKT Red
- WTB: CRX Sunroof components
- integra ls fuel rail, t/b, and injectors.
- WTB 01-05 civic exhaust
- WTB: Backyard Special EK9 Wing adjusters
- i need parts any one willing to sell
- 4sale ! Xenon 9005 bulbs,96-98 civic REAR TRUNK LIP,JDM TAIL LIGHTS,OEM SPRING
- WTB 94-01 Integra coupe complete front-end
- WTB Complete D16z6
- WTB: CRX rear seat brackets
- WTB: 99-00 Si ebrake cables
- *** WANTED: 90-93 B-Series Timing Belt Cast Motor Mount ***
- wtb: gsr iacv asap
- WTB b16 springs and retainers and b16/GSR 5 spd hydro tranny.
- WTB: 91 Integra FD, or 92 Integra Transmission with FD
- WTB: Stock Power Mirrors *96-00 Civic Coupe* in Black
- WTB: FULL RACE or Rmf/hytec/comtech/anr type header
- WTB: R Crew Header
- WTB: 1996-1998 Honda Civic Hatchback SHELL
- WTB: Eibach Sportline Springs for 94-01 Acura Integra
- WTB: 92 eg Carbon Fiber Door Panels
- Gsr mainshaft
- WTB: clean dc shell
- WTB: GSR EVAP purge Sensor OBD2, the one on top of the IM
- wtb::: F20 RODS and PISTONS ~~ OEM or Aftermarket's
- WTB: Honda Access Window Visors for EF
- WTB: GSR/LS tranny with Quaife LSD!!!
- WTB: D16 D SERIES PARTS REAR TRANNY BRACKET DRIVER SIDE ENGINE MOUNT AXLES
- WTB stock Integra exhaust.. LS,GS,GSR
- WTB: 94-01 Intergra driver seat.
- wtb d16z6 block need it yesterday
- WTB: hydro b16 or gsr tranny
- WTB B16 Head and Tranny for EF
- WTB Vented AN Bung'd Valve Cover B Series
- WTB: Braided Fuel Line
- WTB: Fuel Rail, 94 Integra GSR
- WTB: Power Slot Front Rotors, 94 Integra GSR
- WANTED !!!!!EF9 PASSWORD JDM CARBON FIBER OR FIBERGLASS SIDE SKIRTS !!!!!
- WTB: Hawk HP+ Rear Pads, 94 Integra GSR
- wtb air/fuel gauge and boost
- wtb: ex/si tranny
- WTB 94 integra front lip*show me what u got*IL
