View Full Version : Want to Buy
- check it out nj
- WTB: 98-01 Integra HEADLIGHT
- WTB: DA radiator bracket and rubber cushion
- WTB: AWD 95-99 Eclipse or Talon Shell
- 92-95 fenders near Indiana...
- WTB: 1 Fat Five Rim for a 95 GSR
- WTB eg coupe hood and bumper
- Looking for some 99- 00 si parts
- WTB: Stock Radiator Cap, b series driver side abs axle, and many more!
- WTB 91 civic si front driver caliper mount braket
- wtb d series vtec motor
- WTB: Window switch and pod w/ a/f gauge
- ...WTB ROTA SLIPSTREAMS...
- WTB - civic blue door cups
- WTB FMU
- wtb: skunk2 (B-Series) intakemanifold
- WTB hondata S300 or S200B
- jdm crx bass tubes
- WTB ls hydro 5th gear or ls ys1 5th gear
- WTB 2000 Honda Civic Ex Hub Caps, Pocket under the cd player
- FT/FS Rota Track R(Black), Tien S Springs
- ls/vtec or b20/vtec
- Ls throttle body..
- wTb: 90-91 Civic Si Front bumper
- wtb: b20/b18 crank asap!!!!
- WTT: My Spoon Type D Radiator Cap for your Spoon Type F Radiator Cap
- NEED A P20/B000 ASAP!
- WTB: Good white 92-95 Civic coupe/hatch fenders near Indiana.
- WTB: 6 Puck clutch / LSD for a hydro LS
- WTB: ANY 5th gear set that will fit a B16 S1 cable tranny (small spline)
- WTB: 88 CRX Parts!!
- WTB: SOCAL 96-98 civic oem bumper SILVER
- WTB: OEM spoiler for 92-95 EX
- wtb: b16 1st gen engine
- WTB - Stock Gsr diff
- WTB : Oem GSR front strut bar
- WTB: 99-00 SI a/c Bracket
- WTB: HALF SIZE DUAL CORE radiator for my b18c !!
- WTB: Red Recaro SRD's (preferably in South Florida)
- WTB: 98-up Integra Front Bumper, Headlights, Oem optional sides, Rears
- WTB: 90-93 Integra Neuspeed FUSB Black
- wtb: 99-00 Primary o2 sensor (4 wire)
- WTB: 15 OR 16" RIMS
- Mugen resivor cover
- WTB: 92-95 civic manual steering rack
- WTB Integra Type R Wing ITR
- WTB - H22 lighten flywheel
- 92-95 Civic Hatch Rear Seat Brackets
- WTB: JDM EF9 Hood or SiR Carbon Conversion Hood - Florida
- WTB: 96-00 Power Window Relay
- an-r or bisimoto
- Blank centercaps for gsr/si rims/gsr spoiler
- wtb bogarts
- WTB: SOCAL 96-98 civic type-r lip & grill SILVER
- WTB:Whole P/S system for 99 EK
- 96-98 cupholders
- WTB-Honda Del Sol carbon fiber Trunk Lid socal
- 95 honda prelude dark green
- WTB:D2S BULBS FOR JDM ITR HEADLIGHT
- WTB: lower timing belt pulley OBD2 GSR
- wtb...........95 civic EX underdash harness
- wtb...........95 civic underdash harness
- wtb: eg cf hood
- wtb hx wheels....CT
- WTB: 98-01 integra parts
- WTB: 3 S2000 clusters
- WTB : ek/eg/civic coupe/integra have $4000
- WTB: Manual Steering rack from a 92-95 civic
- WTB: 1989 CRX HF metal front bumper support and A/C condensor
- WTB: S2000 hid ballast
- looking for parts for my eg
- WTT:MY BUILT ITR BLOCK FOR YOUR STOCK ITR BLOCK
- WTB D16A6 block
- WTB: Cam seal and PCV nipple ASAP!
- wtb integra jdm front bumper only and good fitting jdm fenders
- wtb: B18b altinator pulley and manifold
- WTB: 5 lug bogarts
- WTB: koni yellow shocks...94-00 teg
- WTB: 15 inch 4x100 bronze Konig Networks for daily driving
- Stock integra fans
- WTB: D15 Upstream o2 Sensor
- WTB d16a6
- wtb...jdm eg6 rear interior parts...
- WTB: boost/air fuel gauges, p28, turbo timer
- WTB eagle rods,boost controller,wastegate,crower turbo cams
- WTB: NSX / Legend 2 Piston Calipers
- WTB: OBD1 P75 ECU
- WTB: D16Z6 Longblock
- WTB: 96-98 civic headlights
- WTB: A/C Parts...everything for it to make it work...93 GSR
- WTB: HKS or Greddy B-series turbo manifold
- WTB: 15" or 16" rims w/tires CHEAP PLZ. San DIego
- WTB: 92-96 Prelude Parts
- WTB Driverside door and Driverside fender ASAP Will Pay cash location in Temecula
- wtb : itr stock muffler
- wtb: s2000 hardtop
- WTB- obd1 B16 alternator, integra GSR seats
- WTB: b16 Pistons ASAP
- WTB: GSR complete gear set
- lowballer need some things!!!! e-manage.LIP. b serise halfshaft...etc
- WTB: B20 short block
- WTB: Coilover 99 accord
- WTB: Ls, GSR, or B16 Tranny.
- WTB: 98+ Corner Light Brackets!
- wtb or wtt ls for turbo parts
- WTB: wheels asap!!! blades, rota,old school jdm ...4x100 show me what you got
- WTB: Two good white fenders for my coupe/hatchback '95 (Indiana).
- WTB: H22 Raceheader
- WTB: 14" Hubcaps
- WTB D16z6 crankshaft in good condition
- WTB SOHC Vtec Head
- WTB 00-01 USDM ITR interior carpet
- WTB: CLEAN 98 CW ITR
- WTB: D16Z6 D16A6 D15B NY NJ CT AREA
- WTB: 99-00 Wiring Harness, EX preferred, will take anything
- WTB: OEM 92-95 civic front fender liners Connecticut
- WTB: 2 REAR Stock/OEM INTEGRA SHOCKS 94-01
- Need HF bumpers for my EF
- WTB: 97 to 99+ Civic Front End Conversion
- Looking to buy 92-95 hatch
- WTB: JDM dc2 door visor (brand new) or MINT! 714 (OC area)!!
- Rear Quarter Panels.....
- WTB: Exhaust system for 97 Civic EX Coupe
- WTB: ASAP Knock Sensor for OBD1 95 GSR
- WTB: GREDDY TURBO MANIFOLD "HEAT SHIELD"
- Cam Seal (STR BDL) h22
- wtb: uncut ef dx interior wiring harness
- WTB: Valve Cover
- WTB-2 in coupling
- WTB: D16Y5 Head, Civic HX ECU (P2N), Intake Manifold (D16Y5) (all 96-98)
- wtb aluminum rear brake drums
- ITR Valves
- need eg-ex door panels
- WTT: OBD0 MSD dizzy for a OBD1 stock dizzy
- WTB: 190 WALBRO FUEL PUMP and BRAIDED FUEL LINES.
- WTB: JDM DC sports 4-1 Header and T1R/Fujitsubo/Spoon Exhaust for DC2
- WTB Koni Spring Perches for stock springs
- WTB! B18b1 After market rods and pistons for turbo! Boosting 18-20 psi Both standard size!
- WTB: COMPLETE OBD1 b16 intake manifold asap
- WTB B series 92-95 Eg 94-01 DC ENGINE MOUNTS
- $$$$$$$WTB MOTOR$$$$$$
- WTB: CRX Suspension Parts or Rolling Chassis
- 95 EX Cluster
- WTB: k series K20 turbo manifold
- WTB: Virgin p28 ECU
- Will PAY GOOD $$$ for clean 88/89 crx doors
- WTB: EK9 Spoon wing
- SoCal WTB: ESOVAL 2.5" ID muffler
- WTB b16 valve train
- WTB: EP3 parts, driver side mirror, pass door and fender
- WTB greddy 15g
- WTB: Del Sol radiator core support!!!!
- **WTB: Integra oem optional lip
- wtb your 99-00 si parts
- WTB: T1-R 63mm Exhaust system for 96-00 hatchbacks!
- WTB: TD-42U distributor.... d16z6 d15vtec
- WTB: EG oem Fog Switch jdm or usdm....
- wtb vtec conversion kit
- wtb breather kit
- WTB: Buddy club spec IV cams camshafts BC4
- WTT: My Spoon axle back for your T1-R (EK9)
- WTB:> 97+ prelude auto / tiptronic tanny / transmission ... in so cal!!!
- wtb: full race traction bars for eg
- WTB: 1988-1993 Stock CRX HF
- wtb eg b
- 92-93 DA oem front bumper
- WTB: OBD1 P72
- WTB: 99-00 Civic REAL DEAL MUGEN LIP
- WTB: D-series Greddy Blue Box w/ harness
- WTB: d16y8 head
- WTB: b18c1
- WTB 89 crx drivers side fender. and jdm b16 alternator. first gen.
- WTB/WTT: 15" Honda HX Rims
- wtb stuff
- threw a rod, need a d16y8 short block
- wtb looking for usdm or jdm integra cf climate control
- wtb: jdm armrest elmintor
- wtb: stock gsr oil pan ....untapped
- WTB 98 green integra bumper
- OBD 0 PR4 ECU, 90-93 integra ECU
- WTB: EG Climate Control
- WTB: DOHC ZC cable trans, can be busted, grinding, i don't care
- 92-95 SI rear calipers+ used slicks
- 96-98 climate control radio center console bezel
- need cheap 2 1/16 gauges....
- WTB: Emblem " RS " Front Grill JDM
- WTB COMPLETE EG INTERIOR BLACK ASAP
- WTB: Untaped GSR Oil Pan
- wtb: alternator brackets B series
- WTB 88-91 honda crx steering wheel
- WTB: 92-95 Civic TYC headlights black
- WTB: EK Doors, Si Grill, Si Rims, 96-98 Dash or teggy dash...
- eg manual steering gearbox
- wtb b18 a/b or b20, complete running block
- wtb: 99-00 oem civic EBP hood or OEM style Carbon Fiber hood.
- wtb 92-95 civic driver side head light socal prefered
- WTB ASAP!!!!! ONE cam cap for a gsr head, the one the distributer bolts to. mine broke, need it asap
- Wanted to buy: HID KIT for my 96 db8 :) - Cash in HAND
- wtb: h22a oil pan
- wtb I need a shifter assembly from a 94-97 accord or 92-95 prelude
- WTB EF TRACTION BARS NEW OR USED
- wtb intermediate drive shaft from 90 accord 5 speed.
- 96-00 :: civic :: seat bolts! -- need badly!
- WTB: Driverside OEM 98+ Integra rear bumper body kit shell
- wtb: Conversion harness
- WTB: MD/Balt. 89-91 CRX Rear bumper.
- WTB: 98+ oem Integra Type R front lip
- WTB d16y8 and tranny
- WTB Autometer gauges
- wtb y8 exhaust manifold
- WTB:89 crx si main relay
- WTB: R1 GTR6 17's or 18's
- WTB: CF HATCH
- 90-91 crx si dash & mugen mr5 center cap
- WTB SOHC vtec Solenoid.
- FORGED B16 RODS
- WTB: 98+ integra front bumper back bumer and fenders
- WTB P72 obd2 ecu
- WTB: 96-00 Civic HB rear bumper
- CARFAX NEEDED!!!!
- WTB// 92-95 eg hb mudflaps in Socal
- wtb bare b20 block and jdm ITR trans 4.785 FD or other lsd hydro bseries trans w/ better than stock
- WTB- VAFC 2 with OBD2 Harness
- WTB LS 5th gear
- wtb eg bumper
- wtb: Rsr Exmag exhaust
- WTB: hatch strut mounting thing
- wtb : gsr knock sensor
- Stock H22A Shortblock
- WTB 99 EBP CIVIC SI SHELL
- WTB Tapped y8 oil pan
- SWAY BAR
- wtb intake manifold and rods
- WTB: Rota Circuits
- wtb civic cx rear hatch window
- Catalytic Converter
- :WTB* OBD-2 vTec Distributor!
- WTB: 17-inch Rota Subzero - Royal Black or Royal Gunmetal
- WTB: 17-inch 5Zigen Fn01r-C - BRONZE
- Trade my Acura Centercaps for your Honda Centercaps
- wtb: 88-91 civic stock dx head
- WTB: bad/ used/ throwaway o2 sensors, I just need the plugs.....
- WTB: 4x100 civic rims. Gunmetal w/ polished lip or ITR like rims
- WTB: DOHC VTEC spark plug cover
- WTB: 96+Civic in Chicagoland/IL area
- WTB: Advan Rg, volk gram light Gold 5x114 trade ITR Gunmetals
- WTB: Racing Seat Brackets
- WTB: 90-91 Civic Si Gauge Cluster
- WTB: 1992-1995 4 door Civic complete Header to Exhaust system (SoCaL)
- wtb for my turbo project
