View Full Version : Want to Buy
- WTB: 2WD Civic Wagon Rear Mudflaps
- Integra RS Brake Booster
- wtb cheap 68mm throttle body
- wtb h22 parts and oem k20a pistons
- 92-95 eg civic ac delete duct
- WTB OBD1 P72 ECU
- Wtb: ek coilovers and tires
- Wtb turbo parts,integra parts,and integra part out welcome
- WTB: EG Sedan Torino Red Hood
- Jdm license plate adapter
- WTB: EF B series swap parts.
- Turbo manifold B series LSvtec kit
- Wtb race shocks 96-2000 ek
- WTB wideband
- WTB: Apexi Safc, Safc2, Or Neo
- wtb 3" muffler
- WTB: Misc. Integra parts
- oem gsr or ls differential
- D series valve cover
- WTB CD7 PARTS
- B18c Top mounting bracker Power Steering
- 75.5 ycp teflon piston kit d16
- WTB: D16 AEBS T-Sleeves or Darton MID Sleeves (NEW)
- SC: DC2 OEM Type R wing
- S2k cmc with spacer
- Wtb: integra cruise control button delete
- b series flywheel bolts
- WTB: Small turbo
- DC2 Random parts wanted! (interior)
- Ls rods
- I need a p7j ac bracket for ek swap
- da, obd1 b series
- Wtb: gsr or ls crankshaft
- B-series shift fork
- Skunk 2 Pro 3 cams
- Wtb: h22a fitv and servo pump + brackets
- WANTED: 99-00 CIVIC SI EM1 B16A2 ENGINE WIRING HARNESS
- WTB: EK 96-00 COUPE POWER DOOR PANELS AND 99-00 CIVIC CENTER DASH BEZEL
- WTB: Integra Type R Complete exhaust system, ITR
- WTB: EG/DC Drag Suspension
- b18c obd1 distributor
- wtb mint or new type r valve cover and checkered driver side floor mat
- wtb: jdm crx bumper lights (mo)
- WTB GSR Oil Pan
- wtb bare b16 head
- WTB: 94 Accord Parts,Couple Interior and Exterior
- WTB: B16 LSD + cable case
- WTB CRX/EF K PARTS
- WTB: BDL 3" clamps
- WTB: Autometer Sport Comp 30 psi boost gauge
- wtb: obd1 ls p75 ecu manual
- clear dc 2dr tail lights
- WTB: ek oem top hats
- Wtb: integra power antenna
- WTB: AEM EMS 1052
- EG CLUSTER
- WTB: Integra Tan Interior Parts (Glv box lock/leather seat/mats))
- **WTB 84-87 civic LIGHTSPEED header** old school
- wtb: ap1 or 04-05 ap2 cluster
- rear bumper
- WTB: 99-00 Civic si proportion valve
- Wtb: 92-95 hood and fenders
- wtb eg shift linkage
- B18/B20 Spark Plug Cover
- WTB: 99-00 si wheels!
- Motec m84 used
- need CTR piston ASAP
- OEM TEAL EG HATCH BUMPER
- wtb fresh air vent piece (metal lip that keeps water out) 94-01 Integra
- WTB: Civic Wagon Passenger Fender & Rear Mudguards
- WTB: EK HASPORT,AVID,INNOVATIVE BILLET B SERIES MOUNTS
- b16 or gsr tranny guts
- WTB RHD CRX SIR CHASSIS HARNESS
- Skunk 2 Pro 1 Cams
- WTB: GSR T-Body Pulley or OBD2 GSR Throttle Body
- WTB: 99-00 EM1 OEM PARTS
- WTB: Desmond Regamaster Evo Brites
- WTB D series performance parts
- Wtb Lhd manual folding power adjust ek mirrors
- WTB: CRX Center Dash Vent w/ or w/o clock
- WTB : Aluminum rad 92-00 civic
- wtb 2007 civic si sedan exhaust
- H22 valves, cam gears, fpr, etc
- 94-01 integra ac lowside suction line 80321-ST7-A02
- WTB:Autopower race roll bar for 92-95 civic hatchback! *Orlando,fl*
- WTB: b series intermediate shaft
- WTB : VOLK LUGS NUTS
- WTB: EF8 CRX front bumper support
- WTB: DC Integra Rear Trailing arms
- Wtb: Fairly clean GSR oil pan (P72)
- WTB OEM type r or ctr LSD working or possibly damagrd
- WTB: D15b2 manual transmission for 89 CRX
- WTB: Integra RS 40/40 prop valve
- WTB - Built K24
- WTB: 92-95 Civic Hatchback Door Pillar Moudlings (R&L)
- WTB; Stock ITR spring, Supertech spring or any aftermarket spring
- WTB: Honda Civic 1989 Hatch parts
- WTB : Vtec distributor for a dc2
- Wtb: coil overs for gsr
- Koni race shocks
- Bride RO seat rail + center console - DC2
- H22 fuel rail
- WTB: 98-01 Integra 3DR Hatchback Driver Side Lining Panel
- WTB: VTC Oil Control Valve
- JDM ZXi Integra 4.43 final drive assem
- WTB: B Series VTEC, H22 or K motor
- WTB: Honda CRZ
- WTB: 1988-1991 Honda CRX
- WTB 99-00 civic Si lip (Texas DFW area)
- WTD- Jimfab Tractiuon Bar for my CRX
- WTB 3Pc Carbon Fiber Front End for 00 EK
- WTB: K20z3 Shifter box Hybrid or K-tuned
- EF9 WINDOW VISORS
- WTB: Bottom Mount low seat rails for Recaro SR3/4 SRD's
- WTB 99-00 Civic Front Bumper Cover
- Wtb: nrg short hub srk-110H for civic/integra
- arp head stud and nut d16
- SINGLE eagle 5394AHO rod d16z6
- WTB B18C1 Full Swap
- WTB; Skunk2 Tuner Series Stage1 Cams B-Series
- wtb: s300 v3 with boost option
- WTB: JDM EF9 front filler piece.
- WTB: B Series Knock Sensor
- Bb6 mugen
- Wtb bb6 side skirts
- Wtb oem b vtec dizzy obd 2 only
- WTB Hondata S300 chip or ECU
- WTB: B series header, GSR BLOX, Skunk2 intake manifold, EK hatch spoiler
- WTB ITR tranny brace distributor starter
- WTB : Competition Clutch Stage 5 94-01 Integra
- WTB:b18 2 bolt post mount
- WTB SKUNK 2 STAGE 2 CAM !!!
- 94 accord wiring harness and ECU
- d2b kit
- WTB: GSR UPPER Timing Belt Covers
- WTB: Si Spoiler (EM1)
- WTB: EG BYS
- WTB: USDM Integra 3 Piece front end...
- WTB: Ignition coil plug
- WTB: EP3 2002 Front Bumper Side Lights
- WTB 1991 civic hatch Suspension
- WTB : EG/DC Front traction bar
- WTB: 85 Honda CRX Si Ballade JDM parts
- WTB EF Hatchback headliner w/moonroof provision
- Exhaust valves and valve springs
- WTB: b series manual trans starter 96 integra and up
- WTB: 2 piece rear bumper diffuser golden eagle look alike
- WTB OEM window visors
- WTB: 96-98 civic sir front lip
- wtb 91 civic hatch base engine wiring harness
- wtb: skunk2 or blox cams
- WTB: Work Meister S1 2Pc 15x8 and 15x9
- Wtb ef front upper camber kit
- WTB: 208-4303 (GSR) ARP studs
- WTB c's driving position shifter or HKS cam gears
- Wtb swapped del sol or eg Maryland
- looking for full 3" exhaust for 95 civic hatch
- B SERIES COIL ON PLUG CONVERSION KIT
- 98-01 Integra mud flaps 2-door
- WTB: Virgin P28 ECU
- WTB: Golden Eagle Fuel Rail
- WTB: ITR REAR SEAT
- B20 p8r head
- WTB: Bride / Sparco / Recaro seats
- WTB H2B KIT AND H23 PARTS!!
- wtb wide band gauge and oxygen sensor
- Northen California - WTB good running D16Y7 Short block
- Jdm integra dc2 type rx yellow recaros
- WTB: D series 4.43 final Drive
- WTB: Kosei K1 16" 4x100 -43mm Wheel
- WTB: B series LSD
- spoon sw388
- Wtb inline fuel pump
- wtb.b16 s1 4th gear set
- Civic EK H22 Swap Parts
- WTB: Walbro 190lph fuel pump
- WTB : GSR Cams
- WTB : Integra 90 LS transmission parts
- WTB: STOCK OBD1 P72 ECU
- wtb 96-00 ctr srs steering wheel
- wtb em1 ps pump
- WTB: Carbon Fiber Fenders *pair* 91 crx
- WTB: Mugen NR10-R
- EK9 Type R B16b connecting rod 142.30mm
- Who has extra hazard or rear defroster switch? And clutch pedal pad
- WTB: D-Series 5th gear
- Wtb Hardrace camber kits for 95 civic
- WTB A1000 FUEL PUMP
- Wtb ef civic 90/91 hatchback passenger door molding
- WTB: Aftermarket Rods for B18/B20 block
- Acura Integra RS brake booster
- WTB: ep3/rsx steering wheel plastic piece
- WTB: D16y8 Crankshaft
- wtb ek pedals
- WTB: CRX Clutch Pedal Assembly
- WTB: EK Power window Door Panels!
- wtb d16y8
- WTB B Series hydro transmission
- WTB 2002 EP3 Mud Flaps/Splash Guards
- WTB OEM hood bra for 95 civic sedan
- wtb: 1: p72 rod
- WTB: 5th gen 97-01 Prelude Parts
- wtb - eg hatch parts for rebuild
- WTB: 99-00 honda civic si wheel(only need one)
- D16Z6 ARP head studs ?
- WTB Weld Magnum skinnies ASAP
- WTB: Anything and Everything ARC (Abbey Road Company)
- WTB: 00-01 USDM Type R ECU- 37820-P73-A04
- wtb core block
- WTB: genuwine spoon sports p13 ecu h22a
- WTB-db8 integra window rain visors 4 door 94-01 integra
- WTB: CRX driver fender (R72-P) torino red, front mud flaps, corner light
- Wtb used or new eg coilovers
- WTB: 98 Civic Sedan, Stock shocks with springs mounted
- (WTB) H22,H23 sleeved block (55mm mains)
- WTB: Aerocatch Eye-Bolt Pin Replacement
- WTB: itr type r metal hood and 3rd brake light
- WTB- Nickelz 92 DX EG part list thread !
- WTB obd1 5spd b18 engine harness
- wtb - eg hatch rear glass hardware
- rota slipstream 15x7 4x114.3
- WTB: B16/18 block - B16 Head
- WTB: B-Series Clutch Alignment Tool
- LTB msd digital 6al
- wtb k20 tranny and eg2k mounts and axles
- wtb 92-95 denji headlights
- 21396-P80-000 94/95 GS,RS,LS, GS-R OR Del Sol VTEC MT Breather Cap
- WTB: AEBS Manifold for B16, Rods for B20/B18
- WTB: DC integra 2 door, cf trunk+lexan/FAL
- Buying 1999 civic si OEM window visors!
- WTB: 99-00 D16y7 Engine Harness NH
- Wtb: oem mudflaps, drivers side window switch,
- ***WTB OEM B-Series spark plug cover and JDM Type R Oil cap***
- WTB: OEM GSR Power Steering Parts
- WTB Haltech Platinum Sport 1000
- WTB: 93-95 del Sol Front Bumper (Shaved Preferred)
- WTB: 92-95 civic hatch tail gate
- WTB- H22 ITBs or All Motor Intake Manifold Setup
- Wtb: rear window latch for 98 crv
- WTB: JDM ITR SRS Steering Wheel
- WTB: B series MAP and TPS
- WTB GSR LSD DIFFERENTIAL
- WTB 93 Honda Accord LX Heater Blower Motor
- WTB EG6 Sir muffler oem
- WTB: OEM GSR or ITR axles
- [IN] WTB k20a2 starter and harness
- Rear 92-95 civic hatch tail light harness
- Wtb: stock axle back for ek coupe
- Wtb fuel presser regulator
- B16a2 distributor, vtec soleniod, power steering pump
