View Full Version : Want to Buy
- WTB: 96 acura integra FUSE BOX engine an under the driverside wheel~!
- WTB: obd1 engine harness
- wtb jdm integra dc2 left fender, rear bumper for 98 db8
- WTB: d series fuel injection setup
- WTB: H22A Competition Clutch Twin Disc
- Lower Timing Belt Cover for GSR
- WTB: H22A Adjustable cam gears
- wtb: eibach pro-kit springs for ek civic
- WTB b series stuff
- WTB- '96 Prelude usdm P13 ECU
- wtb: d15 turbo kit
- Want to buy b18b1/b20 shortblock
- wtb carving lover souls
- wtb parts from d16 head BAD!!!!!
- WTB JDM 4LUG 15"16" OFFSET WHEELS ASAP!!!
- WTB: 90-93 integra CV axles
- WTB: 15" 4x100 Volk 5/4s
- WTB 98-01 Integra front and rear bumpers
- WTB: Recaro Profi SPG
- 92-95 Civic B-Series motor mounts.
- 1991 Accord 2 door blue inside passenger door handle
- WTB: Blox 490 Shift Knob ( Neo + Gunmetal)
- WTB: D series auto trans EX/Si ASAP! (for my friend)
- WTB: Disc Hi Impedence 550cc injectors for d16z6
- WTB: Turbo Parts for D series Build
- wtb: 96-00 civic coupe headliner, ek arm rest delete
- WTB CIVIC 00 OEM REAR DRUM BRAKES
- gsr feul injectors
- WTB: 99-00 REAR T BRACKET AND FRONT DRIVER SIDE BRACKET FOR B SERIES
- WTB CTR HEADLIGHTS/CTR WING OEM PLEASE!
- WTB 89 crx body kit!
- WTB Hasport Motor Mounts ... D-Series EG
- WTB: 96-98 EX Harness | OBD2A | Uncut
- WTB Comp Clutch D Series
- WTB:Misc. del sol interior parts
- WTB: BLACK EG STEERING WHEEL W/ CRUISE CONTROL & AIRBAG
- WTB: 88-91 CRX si throttle cable and bracket
- Wtb D series head parts and tranny
- WTB: OEM 98+ DC or 99+ EK FUEL PUMP!!!
- WTB Integra 4 door parts TN
- {[WTB]} VSS hydro tranny
- WTB: B-series flywheel cover
- TN:WTB: 4x100 Wheels OEM or Aftermarket
- WTB GSR leathers F and B
- WTB: HX wheels
- WTB water gauge
- b18c b18 Crankshaft keyway
- WTB : EG6 HEADLIGHTS AND CORNERS
- lookin for a ek cluster
- WTB: 89 CRX HATCH HINGES
- CF intake (Whale Penis) for a 99-00 SI
- WTB: Tial 38mm Wastegate
- WTB: Moates Burn 1 or Burn 2
- WTB Hasport Motor Mounts ! D Series EG
- WTB: Honda B20/CRV Oil Dip Stick
- WTB: 98+ Integra Passenger Side Mirror in SILVER
- WTB: Stock or aftermarket cat back exhaust for 90-97 accord/ 1gen 2.3CL
- WTB- integra intermediate shaft + shift linkage
- WTB Del Sol manual swap
- WTB: CTR/ITR camshafts
- cdm itr seats
- WTB: 89-91 EF Civic Si lip
- WTB Stock 04 TSX exhaust
- wtb: crx top hats for struts
- WTB: Japanese Illuminated Light Up License Plates
- WTB: DSS STAGE 2.9 AXLES FOR DC2
- wtb 97-01 prelude driver side door
- WTB: CRX HF exhaust manifold
- WTB: OBD1 to OBD2a Jumper Harness ASAP
- WTB: 02-04 RSX rims
- WTB: D16Z6 Head
- WTB: D16z6 dizzy
- WTB Forged B series Pistons! 81.5-84mm
- NEED to buy - B16A - '00 Si
- WTB: Idler pulley
- WTB: OEM Accord Rims
- WTB gsr or b16 dizzy obd1 or 2, obd2b ONLY 98-01 engine harness for a teg
- WTB CTR HEADLIGHTS!!!!
- WTB: h22a Alternator/ Motor mount kit for DC/
- WTB ASAP: eg carbon duckbill, function 7 lca's, firewall block off, beaks, x bar
- WTB: EG ex/si OBD1 VTEC engine harness. UNCUT!
- looking for
- WTB YOUR SWAP
- WTB: 91 Civic Hatch Passenger Side Mirror
- WTB: OBD2A manual engine harness (EK), gauge cluster bezel
- 88-91 Civic Wagon RT4WD
- WTB: B series twin disc
- NEED OBD1 b16/b17 Distributor
- WTB: OBD2 GSR Engine Harness/ Ecu harness
- WTB: Stock Gsr Intake
- WTB:M22 Cams
- Wtb SOHC PARTS&b18a1 oem diff
- WTB: 2.5" Vibrant, flowmaster, magnaflow muffler
- d16y8 intake manifold
- WTB: EK Cluster w/Tach
- WTB: 92-95 Honda Civic 3DR Side Skirts
- WTB D16z6 stage 1 or Zec/Comp cam and tru time cam gear
- WTB Wideband and Hasport Mounts
- WTB: ctr cams, itr throttle body, slicks, valve springs, retainers, break rotors/pads
- WTB: SMSP catback system for 1998 ITR
- WTB: 1 or 2 Regamaster in Almighty Grey Rims
- WTB: 90-93 integra half shaft
- WTB: B series EG mounts all (3) no solid mounts!
- FS|FT| Fully Built PMR - Race Spec So.Cal **DEAL of a LIFETIME**
- wtb eg head light switch
- wtb s2000 injectors asap
- WTB: Open end lug nuts
- WTB:eg9 ferio wing and ferio exterior
- WTB Integra DC Suspension Parts
- WTB ASAP: B16A upper inner & outer timing cover!!
- WTB: GRound Control Top Hats
- WTB: eg/integra parts 15 inch slips
- AEM intake & Gold password JDM rear tow hook (Del Sol)
- WTB 98-01 NHBP PASS/FENDER
- WTB: ITR-DC2 Throttle Body
- wtb silver 96-96 civic coupe/hatch bumper
- SOCAL WTB: 88-91 EF d15/16 5 speed trans!
- wtb skunk2 pro 2 cams
- EK9 EK4 CTR power folding mirror relay and switch
- WTB: Mugen Blanket
- WTB ASAP - 94+ B-series thermostat housing + sensor
- WTB for 97 integra Floor harness and cluster harness
- wtb: oem integra rear endlinks
- WTB 99-00 Civic SI Oem Header and cat converter
- wtb b18b sleeved block for boost
- WTB: Parts for my k24a2 swap into my 04 ep3 SOCAL
- WTB: wide steel wheels *SERVICE*
- d15 88-91 civic engine
- ek hatch
- WTB BOV
- WTB eg RHD optional center console ashtray only *****
- WTB:: crx rear wing...
- *** 89 - 91 CRX SI SEATS in GOOD SHAPE ***
- WTT: Fullý adjustable MOMO seat with bracket for 2 del sol seats Central NJ
- wtb clock for 2000 crv
- WTB:96-00 civic drop springs
- WTB stage2 cams+gears for B18C1
- WTB:99-00 driver side fender and side mirror-Silver
- WTB: DC2 RHD conversion
- WTB: d16y8 exhaust manifold
- WTB: 94-95 R134A Civic Parts for conversion
- b18c head
- WTB 1991 CRX Traction Bar (PA) ASAP
- WTB ITR WING
- Ls block built for turbo
- WTB: 96-00 Civic Coupe/Hatch Manual Window Regulators
- wtb d16 block
- wtb inserts asap
- WTB 98-01 Accord D/S mirror 4 door
- WTB: Sprint Extreme Lowering Springs
- WTB: 1997 Honda Integra Type R DC2 Axles
- WTB: OBD-0 B18 Distributor
- WTB Manual 4wd Civic Wagon(rt) Parts
- WTB: wideband setup (everything) for b16 EG
- WTB: EG hatch LCA's
- wtb; twin disc clutch disc asap
- volk grc (rays cv pro) centercap
- wtb d series tranny
- wtb 99-00 front bumper and fenders
- 2.5 in/out muffler
- WTB in PHILA : 02-04 RSX type s rims and tires.
- WTB:manuel boost controller
- wtb K20Z3 Head
- WTB: Stock USDM ITR Cat or GSR (whatever will fit)
- WTB: EP3 Parts ( skunk 2 LCA, Progress Rear Sway)
- WTB: PTE/Precision 1600cc injectors
- WTB: EG6 front lip, Eg side trim moldings
- WTB: Buddy Club Spec 2 for EG hatch
- WANTED,,, 2001 CIVIC 2 DOOR HEADLIGHTS..
- wtb: AC compressor for 99 civic lx - SoCal area
- WTB: b16 edlebrock intake manifold
- WTB: Civic 91 Exhaust
- p28 CHIPPED ECU
- WTB: Tarooooboh!
- WTB NEW or Mint condition DC Sports DAC Intake for Integra Type R?
- WANTED: GSR LOWER POWER STEERING BREACKET GSR
- wtb 98+ Integra front & Rear bumpers
- wtb: ground control for koni
- wtb d16 engine
- WTB DEL SOL !!! ASAP
- WTB Type R Wheels
- Hardrace mounts
- wtb! 92-95 civic traction bar!!!
- wtb em1 night hawkblack front lip 99-00
- WTB: Complete Red CTR/ITR Recaro SRD w/ full EK Rails.
- WTB ASAP: B18C1 Timing belt!!!
- WTB Rota Slipstream..
- WTB/WTT 1600cc injectors and h22 Tubular Manifold
- WTB: B16 exhaust manifold with o2 or inexpensive header
- Rear Disc Conversion for an EK -NJ
- enkei rpf1, kosei k1, 6ul. etc
- WTB: JDM PT2 ECU
- WTB: BSERIES FLUIDAMPR Street Series B-SERIES B16 B18 !!!!!!
- wtb 96-00 d-series tranny
- WTB: CRX: Linkage/Fuel/Mounts/Fiberglass Etc..
- WTB/WTT:OEM Taffeta White Civic Si Ep3 Bumper in SoCal Area
- WTB: Msd Distributor Cap for B16
- WTB BRIDE GIAS SEATS
- WTB: 96-2000 civic power window housing
- **WTB: AEM CAI for ITR**
- WTB: 2 Rota Slipstreams, 4x100 (prefer gloss black but will entertain other colors)
- Wtb rennsport rc starks
- WTB: JDM OEM EG6/del sol VTEC intake arm, p/s bracket, spark plug cover
- WTB b16 rods!!
- WTB: H23 Intake Manifold
- WTB gsr aftermarket valves.
- air idle control vavle
- PTE 6262 BB, Tial Purple wg/bov, HKS suction funnel, FIC 900CC!
- NEED OBD1 B18B LS PARTS..!!!FAST
- :::: WTB:::: EM1/CTR Front Sway Bar Setup EM1/CTR :::: WTB ::::
- WTB: Mud flaps/ Splash Guards for 96 Civic Hatch
- WTB: 96-98 Civic Si-R headlights
- NEED CASH SALE ME UR car or truck 0$-15,000
- WTB:INTEGRA REAR BUMPER LIC. PLATE LIGHTS
- WTB 65mm throttle body!!! For b16a2
- WTB: GReddy turbo 92-95 civic CARB STICKER
- WTB BUDDY CLUB INTERMIDEATE CAM
- WTB H22a4 cam gears
- WTB: EG_Hatch Trunk/Lid
- WTB: OBD1 p28 ecu. virgin 5speed only
- WTB : Front & Rear HFP lips : 07 Sedan
- WTB:WTB: 2 stock honda/ integra rims
- WTB: 98+ integra turning signal and running light harnesses
- looking for roll bar/roll cage for 91 civic hatch
- Wtb: obd2a gsr ecu
- WTB Del Sol hood
- WTB: 84.5 BSERIES PISTON
- WTB: ATI Damper or Fluidampr B series STREET
- ITR 5 Lugs conversion w/ rims
- WTB: 99 civic inside car ac stuffs
- WTB b20 block, wtt gsr block
- WTB: Integra Parts GSR/ITR/LS parts
- WTB : 96-00 Civic AUTO TRANNY CABLE
- w2b-obd2 integra engine harness
- WTB: AEM EMS/S2000 OILPLAN/S2000 WALBRO
- wtb integra parts
- WTB:D16Z6 Short Block
- WTB: 95 Integra Front seats
- WTB: 97 Civic Midpipe oem ,NEPA
- wtb Ef roof rack
- ITR 5 Lug Conversion
- Wtb slicks
- WTB thread for HEY man
- H22 oil squirter assembly
- 96+ GSR/ITR lower timing belt cover
- WTB/ SSR Reverse Mesh
- wtb: all motor gsr parts
- WTB:B series adjustable fuel pressure regulator
- wtb: h22 crankshaft!
- WTB: b18a/b retainers non OEM pls
