Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cold Start issues
Old Jan 17, 2020 | 09:37 AM
Asusfang's Avatar
Default Cold Start issues
I have a 2001 Honda Civic Ex 2dr coupe D17A2 with 1500 on it since rebuild
Had oversized pistons installed by .020
I just recently had a fully rebuilt engine put into my car and while the temps were above 30-40 degrees it would start fine. But under that it will crank but wont start. I took to mechanic and was told that it was fuel pump, so i replaced it. But still having this issue, I need ideas of things to check.
Battery, ALternator and ground cables are all good
-A
Old Feb 12, 2020 | 06:11 AM
yossi's Avatar
Default Re: Cold Start issues
i had the exact issue and replacing the crank position sensor fixed it. not saying this is your problem, but something to look at, but its an expensive "test" because its a lot of labor to pay for unless you can do it yourself
Old Feb 12, 2020 | 05:30 PM
muellersfan's Avatar
What CEL codes are stored in the ECU?
Old Feb 13, 2020 | 11:57 AM
Asusfang's Avatar
The code is a P0420 Catalyst System Efficiency bank 1
i got it started today in 14f weather but i had to keep cranking it and pressing the gas pedal so i dont flood the engine
Old Feb 13, 2020 | 11:59 AM
Asusfang's Avatar
Could it be a wiring issue for the crank position sensor
A while back i had a code for crank position sensor intermittent but after the car starts it starts right up the next time as long as the engine doesn’t super cool
Old Feb 13, 2020 | 12:05 PM
I would recommend testing the engine coolant temperature sensor.
Old Feb 13, 2020 | 12:10 PM
Asusfang's Avatar
Ive watched it closely usually whatever the outside temp There is usually a variation of 4-8 degrees Up from outside temp and its the same for the intake air temp
Old Feb 13, 2020 | 12:13 PM
What are the cylinder compression numbers?
Old Feb 13, 2020 | 12:14 PM
Asusfang's Avatar
When i took it to the shop they did compression test and said that all 4 were 160 and above and had great compression
also thank you for responding i really appreciate it
Old Feb 13, 2020 | 12:19 PM
In very cold weather when you have the cold start issue, does the engine start up quickly after you have warmed up the engine?
Old Feb 13, 2020 | 03:56 PM
Asusfang's Avatar
After the engine has finally started and has heated up it starts great every time as long as i don't let it sit for more then 5 hours and let it cool completely
which is what bothers me. The first start is always the roughest and its a rebuilt engine with a little less then 3k miles on it.
Old Feb 13, 2020 | 04:01 PM
You may want to compression test the cylinders at low temps when the engine is difficult to start. The numbers may be informative.
You might also check whether adding a tablespoon of motor oil to each cylinder allows the engine to start at low temps.
Old Feb 14, 2020 | 03:40 PM
Asusfang's Avatar
I'll have to give that a shot Thank you
Old Feb 14, 2020 | 03:49 PM
Asusfang's Avatar
also it has oversisized cylinders .020 would that change anything?
Old Feb 14, 2020 | 04:16 PM
Depends on how well the piston rings were fit.
Old Feb 14, 2020 | 05:15 PM
Asusfang's Avatar
Today it was 7F outside and it made no attempt to start it just kept cranking but literally had nothing besides listening to the starter spin the motor. even tried to jump it.
Old Feb 21, 2020 | 06:47 AM
kaivorth's Avatar
Have you tested the crank position sensor like previously mentioned?
I had to replace this after my water pump was changed. Coolant spilled on the sensor I think.
It wouldn't start because that sensor controls the timing of the motor I think.
Do you hear the fuel pump running when you try to start it? Spark plugs look good?
Tsmall
Apr 23, 2015 08:08 AM
millionphil
Dec 28, 2012 12:34 PM
FLA$HY_5SiX2
Nov 8, 2011 02:57 AM
JDM Freakk
Jun 21, 2011 05:36 PM
teler86
Jan 27, 2005 11:16 AM
