Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Another Overheating Thread
Old Jan 24, 2020 | 01:48 PM
Josh H's Avatar
Default Another Overheating Thread
So i recently did a motor swap to my 03 LX n everything was good to go with no issues. It sat for about 2 months after n never driven or started . My main issue is my cluster doesn't work so im not even entirely sure just how hot the motor is getting n how fast. When i start it n just let it idle it takes roughly 5 to 7 mins n then it slowly starts to smell hot n at about 10 mins it slowly behings to steam out the radiator cap. I figured out the fans wasn't turning on so i hard wired them for the time being to see if that was the issue or the temp sensor but still seems to be getting hotter faster then normal. I did test the thermostat in the boiling water n it opened accordingly. Any suggestions or advice on what i should try next before i put the wrong money into it...thx in advance
Old Jan 25, 2020 | 04:54 AM
benchwarmer's Avatar
5 Year Member
Default Re: Another Overheating Thread
It's usually best to run things as they were designed , the car is run by a computer and the lack of a signal can throw things off . check the main fuse and there's a main relay too , those cars do not like over heating so you need dash and gauges working to know what's going on .
Andrew Jensen
Dec 28, 2017 01:30 PM
jlude90
Jul 13, 2008 04:46 PM
verseone
Apr 17, 2004 08:52 AM
MugenB16A2
Feb 29, 2004 10:49 PM
Bs
17
Aug 9, 2002 11:51 AM
