Looking for performance Throttle body, 68mm+
Hey guys.
Looking for a throttle body around 68 to 70mm for a garret 3071 turbo'd 1.8l I'm using a B18c1 blox manifold if that is relevant at all. Looking for a decent unit, I want something preferably with no IAC or add on valves and a throttle screw only. Not a total killer but that's how I have it set up at current and I'm not ready to add in an IAC at this time, however I will in the future, so possibly a block off setup would work.
From what I researched any of the common b series, S2000, and a few others will fit. Sorry, I don't know a lot about honda stuff, but it should be rather self evident.
Re: Looking for performance Throttle body, 68mm+
FYI
The IACV is on the back of the intake manifold and the FITV is located on the bottom of OBD1 throttle bodies...so you will want a throttle body with no FITV aka OBD2 style!
Thank you very much for the info. I have welded the IAC ports shut on this manifold. I have a spare skunk2 I will eventually get the IACV hooked up, but not right now. So obd2 is what I'm looking for.
If anyone else has one pop up I'm just digging through the different types available, thanks all. I'm getting things figured out.
spaazm
06-25-2011 06:32 AM
