Honda CR-V & Element 2WD & 4WD Element & CR-V
ABS problem
Old Aug 24, 2019 | 07:54 AM
Tollfarm's Avatar
Default ABS problem
I have a 2002 CR-V. I have replaced all four wheel sensors and the abs light is still on the dash. When I plug the scanner in it tells me that all four wheel sensors have failed. Any ideas.
Old Aug 24, 2019 | 05:18 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: ABS problem
A scanner won’t tell you what part needs to be replaced. Following the appropriate diagnostics for a given DTC will tell you what needs to be replaced.
You probably need to look into wiring, electrical ****, ABS pump, module, etc. there might even be an ABS reset procedure you need to do after replacing the wheel speed sensors. Although I HIGHLY doubt all 4 went to **** at the same time...
Old Aug 26, 2019 | 05:49 AM
starchland's Avatar
Check abs fuse?
Old Aug 26, 2019 | 05:58 AM
canister's Avatar
5 Year Member
Read the battery and alternator voltages separately with the engine stopped and running. It is not unheard of to have ABS codes from the failing alternator and/or battery.
What specific codes are you reading (all of them!)?
bonstokLS
Oct 23, 2011 10:21 AM
thecrackerjack
Feb 15, 2008 11:54 AM
davenport517
Jul 24, 2007 01:08 AM
951dc5
Apr 9, 2006 03:21 PM
HOOKSH
Feb 11, 2005 05:55 AM
