Honda CR-V & Element 2WD & 4WD Element & CR-V
Cassette player problem
Old Jun 22, 2019 | 05:29 PM
Laden Knight's Avatar
Default Cassette player problem
2000 honda crv se double din 2tm0
When i play a cassete tape it will play for a few seconds then stop, make a few short mechanical sounds then continue playing , it will repeat stoping and playing. It is not the tape it does this to all tapes. It is not flipping. What could be wrong with it, what can i do? I tried cleaning with isopropyl alchohol and a cotton swab. Im prepared to take it out for inspection.
Old Jun 25, 2019 | 05:57 AM
canister's Avatar
5 Year Member
Default Re: Cassette player problem
The reason #1 would be a tired and stretched belt or worn tire on a pulley.
Old Jun 25, 2019 | 08:23 AM
Another thing is it will work normaly but only about 5 % of the time i put it in. And thanks for the reply.
Old Jun 25, 2019 | 08:58 AM
canister's Avatar
5 Year Member
Are you planning to tackle the repair yourself?
Old Jun 25, 2019 | 10:12 AM
Yes
Old Jun 26, 2019 | 10:38 AM
canister's Avatar
5 Year Member
Then extract the unit from the car and take it apart carefully, then rig it to a 12V source (mind the fuse!) and try to play a tape. See what is happening and if you have a slipping belt/tire, let me know. I sell electronic parts and can help you with a replacement if I have the correct size. If I do not, we can further look into the symptoms. If the problem is in a tire, it can be turned inside out or sanded slightly or both. Also you can put some tape under the tire to expand it slightly. Belts just stretch and have to be replaced. I have tons of them, so if you end up needing a belt, I'll need to know the size. Then just PM me your address and I'll mail you one if I have it.
Old Jul 6, 2019 | 06:39 PM
It was indeed the single belt! Fixed the issue. Thanks alot.
Old Jul 7, 2019 | 04:49 AM
canister's Avatar
5 Year Member
Glad I was able to help! Was the old belt just stretched, or did it "melt" into gummy state like some cheaper ones do?
Old Jul 7, 2019 | 11:55 AM
stin1's Avatar
Loved
Community Favorite
That is really cool you were able to help out!
Old Jul 7, 2019 | 05:12 PM
It was streched and slipping for sure.19 years old but im sure i was the only one to put any real use into it.
