Honda CR-V & Element 2WD & 4WD Element & CR-V
Engine light is on, error code p0135 and p0141.
Old Sep 11, 2019 | 08:53 PM
Arturo Azcue's Avatar
Default 2005 CR-v EX 5 speed. Engine light is on, error code p0135 and p0141.
The car is a 2005 CR-V EX 5 speed. I tried to look it up but I'm not sure which O2 sensor needs to be replaced, with both codes do I need to replace both, or just one? Any help would be great. Thanks
Last edited by Arturo Azcue; Sep 13, 2019 at 07:53 PM. Reason: Adding model of car.
Old Sep 12, 2019 | 07:09 AM
canister's Avatar
5 Year Member
Default Re: Engine light is on, error code p0135 and p0141.
heated O2 is downsteam
upstream is A/F
Old Sep 12, 2019 | 07:37 AM
RyanTM3's Avatar
Upstream is also heated..... Did both codes appear at exactly the same time?
Old Sep 12, 2019 | 08:12 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
What year and model vehicle?
Old Sep 13, 2019 | 07:49 PM
I believe so, it was on for a couple of day before I was able to check the codes.
Old Sep 13, 2019 | 07:51 PM
@tech8 it's a 2005 CR-V EX
Old Sep 16, 2019 | 09:08 AM
canister's Avatar
5 Year Member
I would test the O2 sensor first, then if it is indeed a toast, replace it and re-visit. AF from my experience goes way after the O2.
lilcdawg5950
Jul 6, 2011 02:36 PM
EK9_GRL
Oct 8, 2007 12:03 PM
Mad Money
Sep 27, 2006 08:22 AM
vuthe32
Sep 23, 2004 06:10 PM
