Honda Accord 2003 (Transmission Issue)
My Honda Accord 2003 (Auto transmission), When I put my A/C on the car jerks when I engage the gear and subsequently it raves rpm to as high as 4-5 as long as I accelarate unless I release the accelerator then it jerks and engages speed 2 subsequently it will only rave without changing speed, it will not change further unless I switch off the engine and start again, then it become normal but if I put on the A/C again same thing happens. What could be wrong?
Re: Honda Accord 2003 (Transmission Issue)
You should get it scanned for fault codes and go from there. After you have the codes, you should post them up.
