Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission HELP
Old Jun 1, 2013 | 11:18 AM
MySiIsRed's Avatar
Default Transmission HELP
Okay I have a b16a2 civic si, I have a gsr transmission in it now and I bought a new Trans for it. The one I got is a itr tranny. My speed sensor out of the gsr wouldn't fit for some reason. Also do I need to have a obd2 sensor? And will the Itr tranny even work with my obd2 civic?
MySiIsRed's Avatar
Default Re: Transmission HELP
I swapped the differentials out of my gsr into the itr and it wont spin. Its like locked up
Old Jun 1, 2013 | 11:25 AM
MySiIsRed's Avatar
The old sensor never worked that's why I bought a new one, and then the sensor wouldn't fit down into the itr tranny but fit in the gsr tranny. I don't understand
Old Jun 1, 2013 | 01:09 PM
94EG8's Avatar
Seagull Management
It should have. They're both the same, unless it's an OBD1 VSS in the GS-R tranny, but even then it fits and works the same.
No, OBD1 works just fine.
Yes.
Why did you swap the diff? The ITR has a much better LSD diff. Did you swap the ring gear as well? Did you shim the diff or at least check the clearance?
Old Jun 5, 2013 | 08:00 PM
MySiIsRed's Avatar
Idk man the guy said the old diff wouldn't work the new speedo so we swapped it. will it be much faster with the itr diff?
Old Jun 6, 2013 | 01:45 PM
94EG8's Avatar
Seagull Management
No difference in speed. The gearing is the same (unless it's a '98+ JDM ITR), but the ITR diff is a helical LSD, GS-R is just an open diff (or viscous LSD for some JDM versions)
In any case they use the same speedo and same speedo gear. Unless it was an aftermarket LSD that uses a proprietary VSS gear (some do, Wavetrac I think? Is like that)
Make sure he kept the original ring gear on the new diff or it's going to whine.
mstauffer67
Feb 26, 2018 08:32 PM
Civiclx
Apr 2, 2006 08:06 PM
turismo128
Sep 15, 2005 05:27 PM
swaytec360
Mar 9, 2005 06:21 PM
CivicEx95
Oct 22, 2002 02:58 PM
