b16 lsd no worky worky!!! need help asap
ok so my car has a b16 lsd trans in it however the other day when I had the front end lifted off the ground I noticed something that I am not sure about.
So both tires off the ground.
Transmission IN NEUTRAL: (spinning one tire at a time)
D/S tire spins freely
P/S tire spins freely
Transmission IN GEAR:
D/S tire does NOT spin
When I stomp on the gas I notice that only my D/S tire actually spins and the car pulls EXTREMELY hard to the P/S.
My P/S axle does not look broken in any way. I ordered outter tie rod ends that will be put on the car this weekend.
Any other ideas/suggestions on what could be happening? I hope my trans is not shot.
Re: b16 lsd no worky worky!!! need help asap
I am not sure what diff is in it. I just know its got the b16 trans in it and its stamped (not ink printed) LSD on it. I am gonna pull the axles this weekend and verify its lsd using the "look thru the hole" method lol. If it is a hollow hole like the lsd should be, could it possible that its my axle?
update: So I changed out my tie rod ends to try and help with the hard steering pull problem. Helped a little but still doing it under high acceleration shifts. when trying to accel out in front of traffic, only my DS is spinning still.
I think I am just gonna try and find another trans for right now and pull the other one completely apart and see whats going on....
