Itr transmission problem need help!
Ok so I recently broke my passenger side half shaft . So my nightmare began as soon as I replaced it with a reman half shaft . But now I keep getting a leak from the passenger side . Now I have replaced the trans seal multiple times thinking that I had maybe a defect . But now after swapping my axle for another axle but it still keeps leaking . I'm out of ideas do Jdm b18c trans take a different axle seal size ? Or is there something else I forgot .? Any help appreciated
Re: Itr transmission problem need help!
You problem is less likely to be your passenger side seal and more likely to be the new halfshaft. Ive had tons of problems with reman CV axles. Try a factory shaft, even if its used. hope this helps.
Oscar
Oscar
xXxHOLYMANxXx
10-17-2011 10:07 AM
