Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Compression Test
Old Aug 20, 2011 | 03:28 PM
Whatislove's Avatar
Default Compression Test
What do I need to unplug fuel related when I do a compression test? So the fuel doesn't spray.
My car is burning about 2 quarts of oil every 3.5k miles. Going to do a compression test. Eitherway, would this be head gasket or piston rings?
Old Aug 20, 2011 | 04:07 PM
mathewb20's Avatar
Default Re: Compression Test
Pull all the wires, and pull each plug one at a time, Hold the throttle down when you are doing it. If your burning oil chances are its the piston rings or valve seals. A head gasket you would see milky oil, and or oil in your coolant.
Old Aug 21, 2011 | 09:18 AM
AutoXer's Avatar
There's plenty of youtube vids and DIY's if you do a quick search.
As stated, a compression test won't necessarily reveal your problem. Your compression rings could be good and still burn oil.
Old Sep 3, 2011 | 07:52 PM
Whatislove's Avatar
Will the compression test tell me if its valve seals if I dont see burning coolant?
Old Sep 3, 2011 | 11:39 PM
theineffable's Avatar
Remove the fuel pump fuse so you don't end up dumping a ton of unburned fuel into the exhaust.
Old Sep 5, 2011 | 10:56 AM
AutoXer's Avatar
It will tell you if you have a bad exhaust valve, because it won't seal to build pressure on the compression stroke:
http://autos.yahoo.com/maintain/repa...ques056_1.html
Old Sep 5, 2011 | 07:29 PM
Lol WTF. You have another problem with your car? Didn't we suggest you get rid of that thing long ago?
Old Sep 6, 2011 | 02:30 PM
Whatislove's Avatar
the last problem I had was O2 sensor issues which I solved. Now its burning oil. but I've been driving my conquest most of the time now, the civic is my winter car now. I plan on driving the thing into the ground. cant sell it for more than $3k or so might as well keep it till its GG'd.
I have not had a chance to do a comp test on it yet, might do so this weekend.
ewilliams1990
Jun 28, 2014 03:44 AM
Cheez-It
Oct 2, 2007 07:27 PM
J Rob
Sep 1, 2007 07:47 PM
vinuneuro
Apr 25, 2007 10:13 AM
iBrandon
Jul 31, 2006 08:03 AM
