Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headlight problem
Old Jan 6, 2015 | 07:25 PM
2004CIVICLX180K's Avatar
Default Headlight problem
Greetings,
I have a 2004 Honda Civic LX Sedan and I'm having a problem with my right headlights/running lights.
My right low beam is totally out. The right high beam will come only when the key is engaged in start II position (fans running), but the left low and high beams will come on even without the key in the ignition? The front right turn signal functions, but the running lights (same two bulbs as the right turn signal) don't come on as they do on the left side. Tonight, I went to replace the right low beam bulb and realized that both the low beam and high beam bulbs look fine (filament intact) and the fuse (#17 20A - Right Headlight/Brights) is intact?!?
I'm not good at troubleshooting electrical so any ideas and/or help would be much appreciated!
Thanks,
Will
Old Jan 6, 2015 | 07:36 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: low beams don't work but high beams do???
for one thing start your own thread, don't dig up a dead and buried one from 2005
Old Jan 6, 2015 | 08:02 PM
Former User's Avatar
Default Re: Headlight problem
Thread moved to 7th generation Civic forum.
Old Jan 12, 2015 | 05:38 PM
Sorry guys, I'm new to this forum and I looked all over the web page and couldn't find an obvious way to start a new thread so I piggy-backed on this old one... it's not where I would assume it would be under my login account or thread tools.
Will
Old Jan 14, 2015 | 08:47 PM
Might be a multiplex control unit problem.
Old Jan 15, 2015 | 08:55 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I agree there might be a multiplex control unit (MCU) problem. On 2004-05 Civics, the wiring circuit is a little different than 01-03. There may also be an issue with the ground wire going to ground G201, as the right low beam directly uses that ground; whereas, the right high beam use the ground coming from G401 via the light switch and not G201.
G201 is located behind the right side of the front bumper.
Old Jan 15, 2015 | 09:09 AM
Good info^
I only had access to the 01-03 Civic manuals.
unclematt
Sep 1, 2016 09:39 AM
ultima.maniac
May 18, 2008 05:06 AM
biscuitjones
Nov 6, 2006 09:43 PM
new2civic
Jul 6, 2006 11:50 PM
cr00klyn718
Apr 9, 2002 02:45 PM
