Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
cold start problem..........!!!!!
Old Apr 4, 2015 | 01:46 PM
mlee19841's Avatar
Default cold start problem..........!!!!!
hey guys/girls i have a white honda 02 civic ex with 94,833 miles currently. Ive changed the spark plugs with the stock plugs with call for the ngk platinum ones that are in the owners manual. Soon after i did that I have been having hard starts. Everything was fine until doing that. So i changed them to the ngk iridium ones. The same problem exist. So for the final and last time i changed them to the denso ones from the dealership. Still the same damn problem exist. I checked the gap on the ngk iridium ones and it was at .40. That's what it called for in the owner manual. But people online said to try a gap size of .44-.45 so i did that with the ngk iridums and the ngk platinum ones and its still doing the hard starting. The ones i currently have in there are the denso ones from the dealership. It also does something weird with the idle when i start it it goes from the normal idle 800-900 up to 1500rpm and then back down to the normal idle. That only happens when its first started and doesn't do it after that through out the time im driving it. The starter was replaced, the throttle body cleaned, fuel pump relay and the efi main relay, coolant replaced, atf fluid replaced, oil replaced. If anyone has and idea on what could be the issue which seem to pop up right after i changed the old plugs out. thanks for all the help thus far guys/girls
Old Apr 4, 2015 | 03:18 PM
Rick hybrid's Avatar
Default Re: cold start problem..........!!!!!
No, set the gap back, the wider the gap the harder is it for the coils.
Old Apr 9, 2015 | 02:49 PM
mlee19841's Avatar
I started to think back around the time the rough start, started to happen. Around the time of the plug change I started putting higher grade gas in like 93. Ive read that the honda ex 2002 is made to run on 87. Could that be the issue I switched back today.
Old Apr 23, 2015 | 08:18 PM
Former User's Avatar
Definitely run 87 octane. Also test the ECT sensor.
magicwidget
Apr 20, 2008 12:00 PM
wwwbret
Nov 22, 2006 04:35 PM
Touge Tuning
Jun 27, 2005 06:42 AM
bennyhonda7
Jun 21, 2005 12:49 PM
Gee3
Oct 31, 2004 09:05 PM
