Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
difference between d17a2 VTEC and d17a6 VTEC-E?
Old Jan 28, 2008 | 03:36 PM
dingusjt's Avatar
Default difference between d17a2 VTEC and d17a6 VTEC-E?
Maybe I just suck at searching...but what is the difference between these engines aside from HP and MPG? Basically I have an HX with the d17a6 right now and need to replace the engine. I'm wondering if I can drop in the d17a2 and then just move some parts over to make it work?
thanks
Old Jan 28, 2008 | 03:48 PM
jimmypol's Avatar
Default Re: difference between d17a2 VTEC and d17a6 VTEC-E? (dingusjt)
Some people say that the VTEC mechanism is identical in both cars and that what gives you more power in the EX is the higher compression, different exhaust manifold, different cam maybe? I'm not 100% sure about this. Maybe someone else can confirm.
Old Jan 28, 2008 | 05:49 PM
Boilermaker1's Avatar
I think a lot of the differences have to do with the computer running the show. The heads are the same. I dont know about the bottom ends, but the major difference seems to be the tuning.
Old Jan 29, 2008 | 07:08 AM
dingusjt's Avatar
Default Re: (Boilermaker1)
got it SO as the question goes...yes I can use a d16a2 block and head, i'll probably just keep my manifold and ecu of course and then do some tuning...yes?
Old Jan 30, 2008 | 02:29 AM
toyomatt84's Avatar
Sanji
Default Re: (dingusjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">got it SO as the question goes...yes I can use a d16a2 block and head, i'll probably just keep my manifold and ecu of course and then do some tuning...yes?</TD></TR></TABLE>
Do you mean D17a2 block and head?
Old Jan 30, 2008 | 06:18 AM
D17alltheway's Avatar
Default Re: (toyomatt84)
Is this something you have a budget on??... if not slap a K in it?
Old Jan 30, 2008 | 07:18 AM
dingusjt's Avatar
Default Re: (D17alltheway)
hey thanks for the input guys..i was able to locate a complete d17a6 to just swap in so no worries.
Corruption
Sep 6, 2006 12:51 PM
VVTLEC
Dec 1, 2004 11:12 PM
iphatcrxi
Nov 25, 2004 08:32 PM
iphatcrxi
Nov 25, 2004 05:45 PM
Gennady
Aug 19, 2002 10:01 AM
