5-speed swap
Sanji
I don't know what kind of sites you're looking for, because no single site deals with D17 transmission swaps.
Maybe http://www.car-part.com would best suite you?
Either way, there are plenty of threads about this subject, so search around.
Re: 5-speed swap (mattwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattwl »</TD></TR><TR><TD CLASS="quote">05 civic d17a1 i have an automatic civic, planning on swapin out with a 5-speed need help lookin for some good sites </TD></TR></TABLE>
not worth it
not worth it
Re: (Curiouz_G)
well i bought tsi turbo kit, it was about 3 grand, came with gerrett t25 turbo, i bought a greddy spec II boost control but im only running about 8 psi right now cause i havent had it tuned yet and i dont want all that money goin down the drain
Re: (Kongo69)
i dont know but apparently it does matter, here is the link for the kpro
http://www.hondata.com/kpro_d17.html
Re: (Curiouz_G)
thats the whole point, i guarentee that i can get all the parts i need for about 800 there are plenty of recked d17s with a 5-speed that i can yank everything off, my brother works on everything and he said that its very possible, i was just on here seeing if anyone knew any site so that we wouldnt have to search around metro atlanta for recked civics
Sanji
Re: (mattwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattwl »</TD></TR><TR><TD CLASS="quote">thats the whole point, i guarentee that i can get all the parts i need for about 800 there are plenty of recked d17s with a 5-speed that i can yank everything off, my brother works on everything and he said that its very possible, i was just on here seeing if anyone knew any site so that we wouldnt have to search around metro atlanta for recked civics</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">Maybe http://www.car-part.com would best suite you?</TD></TR></TABLE>
Re:
you can do the swap but it will take a lot of work..
IMO sale your auto car then buy a manual car then start the turbo and the other power option. In that way i think you can save money, time and effort.
Anyhow these are the items came to my mind for the swapping.
Manual tranny must include flywheel, clutch disk assy.
Cable shifter
pedals(clutch and brake assy)
Clutch reservior, mastercylinder, slave cylinder(might be included in the tranny)
Clutch lines
Shifter assy, ****, shift boot and center console(right terminology IDK)
instrument panel(in case you dont want to see the shift indicator at all )
And the most time consuming part is the firewall which need to be rip off to install your new clutch pedal....wheew you need a very good faricator here to have a perfect install.
this is my contribution, hope you like it
Good luck.
EDIT: there's no site doing this swapping and to my info. NOBODY tried it yet, so maybe you'e the first one to do it. Let us know the progress if you manage the swapping.
Cable shifter
Clutch lines
Good luck.
I could see something from the 70s that you might find ONE of in good condition, deciding to do an ATX->MTX conversion on... But something so new and common? Just buy one with a manual transmission and save yourself the inevitable headaches and pain.
i did the swap here is parts list - 5spd starter youl need thatclutch pedal assembly
clutch starter switch
clutch master cylinder/resivior
clutch hard line
clutch soft line
slave cylinder
clutch/pressure plate
manual flywheel
hasport auto to manual trans mount
shift linkage/shifter
manual computer
and here is a bit off help for the swap posted on d-series .org by yours truly lol
Yes, the swap is the same for any 01-05. I've just finished mine, but I had a hard time with the ecu. I'm going to give a few pointers of what I ran into for folks because it was fairly easy. However, to my knowledge and that of both Honda dealers around, I was the first one to do this.
The parts list was all OK except the auto starter will not work on the manual transmission. Don't ask me why, it just doesn't fit. After the swap, take the manual ecu to a Honda dealer and get your ecu program downloaded from you auto into the manual ecu. You will have to leave the auto ecu in the car before you get it reflashed. Don't worry if the car runs like **** or gets relly crappy mileage, this is normal with the auto ecu. Also, don't try to go more than 140kph, even though the drive will seem to take forever.
When you are all done there will be about 6 wire clips on the auto harness that won't need to be plugged in. Watch out because there is one that is hidden behind your shift linkage which hooks into the Vehicle Speed Sensor which drives your speedometer.
Once it is all done, you start her up, and then try to shut it off you are going to notice that when you go to take the key out, it won't because your ecu thinks it's still in Drive on an auto tranny. Take the black plastic cover off the ignition, and to your left hand side there is a green plug in. Unplug it and voila! Problem solved! Oh and FYI, the 6 extra wire clips are on the passenger side of the car.
PS
I had a hard time with the dealers for the ecu cause most of them are idiots. Just ask them to do what I wrote in here and you should be OK. As you can see, it's an easy swap with just a few setbacks. Oh, and the best way to do it is to drop the whole k-member.
clutch hard line
clutch soft line
slave cylinder
manual flywheel
manual computer
PS
Re: (elto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">NOBODY tried it yet, so maybe you'e the first one to do it.
Actually alot of people have done it. You can probably find a DIY on 7thgencivic.
I did the AT to MT swap when i did the K20a swap in 2004.
Re: (ballinboosi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballinboosi »</TD></TR><TR><TD CLASS="quote">Hey 1llmatic, not to change the subject or anything but your car is sick! Hopefully I will be gettin a k-20 soon enough
thanks bud for the props. kswap FTW!
bla1ne
32
02-23-2004 04:19 PM
