Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine Light on dash
Old Sep 11, 2008 | 02:42 PM
rcmanuputy's Avatar
Default Engine Light on dash
My engine light on my 2004 Honda Civic came on (the pict of the outline of an engine on the dash). My mechanic told me I had a bad Throttle Position Sensor. In CA costs $420 bucks to fix. Does any one know if this can be done easily or is it a major job? The Honda dealer told me I need to replace the entire throttle body when all I need is the sensor.
Old Sep 11, 2008 | 08:27 PM
toyomatt84's Avatar
Sanji
Default Re: Engine Light on dash (rcmanuputy)
The TPS is riveted to the throttle body, so unless you have a means to which you can mount and adjust an aftermarket TPS, you'll want a replacement throttle body.
Old Sep 11, 2008 | 08:31 PM
phootbag's Avatar
The emissions warranty for that part on your vehicle assuming it's not a GX or HX is 3 year 50k. The entire throttle body needs to be replaced. The sensor is not available seperately and is not adjustable after factory installation. If you were able to get one and install it, you would need to watch the feedback signal and try to achieve about .49 volts with the throttle plate closed and engine idling.
AD_NAPCO
Honda CR-V & Element
Nov 8, 2015 08:17 PM
2005del*6*
Feb 11, 2013 04:10 PM
HubbyLovesHonda
May 9, 2011 04:54 AM
scanner737
May 15, 2010 08:13 AM
assassinroon
19
Jan 25, 2009 12:53 PM
