Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine swap
Old Mar 15, 2011 | 03:36 PM
bosko24's Avatar
Default Engine swap
I'm putting a k24a2 in my 03 civic lx, should I put a new trans in it as well or will stock line up?
Old Mar 15, 2011 | 04:02 PM
01_civic's Avatar
Default Re: Engine swap
i'm not sure if you should do a swap if your'e asking this question...
Old Mar 15, 2011 | 04:29 PM
toyomatt84's Avatar
Sanji
K-Series engines are reverse rotation, when compared to D-Series engines. This means a few things:
1. The engine sits on the opposite side of the engine bay (meaning a D-Series transmission will be unable to sit in it's current location).
2. The transmission is rotating the wrong direction (so you'll have 5 reverse gears, and 1 forward gear).
3. There is no aftermarket support for adapter plates that allow you to bolt any Honda OEM transmission up to a K-Series engine.
As 01_civic stated, you're beyond under-prepared for this swap if this question was serious in any way.
Old Mar 15, 2011 | 04:36 PM
jmvtec05's Avatar
if you're serious about wanting to swap....use this link..very helpful
http://www.xproductionz.com/k20swap/k20swap.html
Old Mar 21, 2011 | 02:16 PM
bosko24's Avatar
Thanks, just learning whatever I can.
Old Mar 21, 2011 | 08:08 PM
It Wasn't Me's Avatar
Just to clarify, that link is from the FAQ's, which you're supposed to read before making a new thread.
https://honda-tech.com/forums/showthread.php?t=2101211
muchakuya
Jun 28, 2018 09:05 AM
Derick Dacasin
Jul 21, 2017 02:47 AM
blkonblkhatch
Mar 8, 2006 07:15 AM
exCiViCex
Feb 18, 2004 06:45 PM
