2002 honda civic sedan with 1.7 vtec engine
I am having a problem with my car losing acceleration power while driving . after the car had sat for a while . i will go to take off and have the gas pedal press a little bit and the power will die the car will not stall out imediatly ,i can press the pedal to the floor and gane excelleration again,and after driving it for a bit the problem stops no sure what it could be.please help
Re: 2002 honda civic sedan with 1.7 vtec engine
Check for codes first.
How many miles?
When was the last time you had the valves adjusted?
When was the last time the oil, spark plugs and filters (air and oil) were changed?
How many miles?
I had the codes checked and it read P0132 02 sensor S1 , B1
can anyone help understand if this info can help fix my acceleration problems.
Do you have live data feed (reads sensor data) on your code reader? If so, with the engine at operating temp and no load (in Park or Neutral) check to see if the sensor output voltage is 0.9V or more. The data feed you want will say something like "primary O2 sensor".
01 Honda Civic
Honda Civic (2001 - 2005)
06-08-2012 07:09 PM
