View Full Version : Drag Racing
- integra drag racing
- 60 ft?
- HELP! Car moving when on the 2 step!
- Best ecu for f23a1 for performance
- B20V est 1/4 Mile
- F23a1… 10 second. quarter. MILE!?!? 🤔
- tire shake w/magnus slipper
- Help I Have a problem with the machine b20 every 7000 rpm after the VTEC on the grap
- SF SCHA
- What do you think I should be running?
- Fuel strain guage for G force shifter
- How much does your integra weigh?
- K24 Eg Coupe Allmotor
- What options for sequential linkage for B dogbox ?
- Comparison of Popular Clutch Engagement Control Devices
- Need drag car setup advice
- VR to Hall converter do they work...?
- spherical bushings...
- Street tire/drag radial class name and specifications
- Top mount turbo head light intake for EG Civic
- Need Little help for all motor b serries drag eg
- 2003 Honda Civic Alternator (Single Wire) in a 1938 Hot Rod. Will it work ?
- Drag wheel. 9 inch on 9 inch tires?
- Del Sol - 3 Piece Front End - Group Buy
- 92-95 Civic Questions
- Launch control settings/help
- Head swap or upgrades
- Who's CRX is this? bottom 10s FWD from IFO finals
- DSS 2.9 outer Axle boot
- Transmission and final drive for for drag racing?
- 9 (8?) second Honda EG coupe build
- Motor mounts
- Harnesses
- H22/SBXM 5th Cuffs
- EP3 Alignment Specs
- Alignment specs for drag racing on a civic
- What wheels are you guys running for your 225s?
- M&H Racemaster Tires 235 60-15
- Rob Moore Joints
- Getting alignment today- what to ask for
- 2004 CR-V stalling at idle
- Tire size for slicks???
- Matt Hartford
- Been out of this scene for too long
- Ferrea rocker arms fit onto skunk2 camshafts
- looking for some test and tune insight
- What to bring drag racing
- Import Face Off 2019
- T1 M&W Pro 10
- I'm years too late for the Drag scene 3 piece Fronts?
- 1/4 mile vs. Supercharged Corvette C7 Z06
- Need help with turbo spool
- SFWD and Factory air bags
- My Integra GSR vs. 700+hp Dodge Hellcat
- Distributor Mods
- Need purchasing advice for a Civic I want to drag race.
- Radial for the Street - 750HP Integra
- First Drag track experience...
- Hey all
- EK SFWD Build from PR
- Nhra license
- Which supertech valve spring?
- What ecu to run
- Hub City Kit
- H22a AWD Bellhousing and 8 injectors intake manifold!!
- Type R swap times
- Racepak IQ3 worth the upgrade?
- Race spec/ Battery kill switch/wiring
- A Novice Attempt to Build a Track Ready Drag Turbo Civic
- Largest slick for stock fenders EG
- AWD Civic EF
- Thoughts on this trans setup?
- Dragstrip 101
- b series plug
- Darton Sleeves Question
- Is there a 5th gear cuff for f series trans?
- tps calibration on s300
- Help me pick a tire setup..
- Rear bumper vents?
- Strain gauge comparison: Flatshifter vs Hondata
- 92 eg drag shell front k member question
- S2000 live axle swap, what suspension
- Ultra Light Car with Solid Rear Suspension
- 2000 civic engine questions
- Blox Rear Suspension
- Fender hits my slicks
- Ignition cut issue
- 2step
- slick and rim size recommendations, eg 500hp+
- Drag racing without hood
- How To: One Way of Using OEM Fuel Pump Hanger Upgraded Pump 10 Gauge Wire/Relay
- EK9 rear bumper wind drag
- quick question
- Drag dot slick info
- 95 GSR vs $230,000 McLaren - 1/4 mile
- Turbo h22a best hp for standard wheels?
- Fastest 1/4 with 13x9's??
- WTB Thread 2019
- 900 HP e85 dual Grams 255 in tank and ID2000s
- CRX launch????
- Honda b18c type r turbo
- Drag slick beadlock question
- CRX Roll Bar Crossmember for Lateral "D" bars
- H/F Series transmission limit
- Doors blowing off?
- What is all needed interior wise for a 11.50 index drag car
- 2018 Honda Day
- FS Thread 2019
- EP3 23.5 x 9 15" Slick Wheels/ Fitment
- Homemade strain gauge
- Cuff or no cuff
- sinister racing 8.2@182mph integra
- C85 vs e100 some one do any kind of back to back.
- Tires for dyno....
- suspension de un eg mod 94
- To rim screw beadlocked wheels or not, that is the question.....
- P2w 1000whp+
- March WTB Thread 2018
- MARCH FS Thread 2018
- Surge Tank
- Building a custom wiring harness
- Slick size, FWD setup?
- How much would it cost to get 800hp?
- Street and track tires?
- Heat treating gears
- Alternator Out put?
- Crower stage 2 cams
- Building the 97
- IFO-Fontana Results(1/28/18)
- 1. FINAL DRIVE AND CLOSED GEARING URGENTLY NEEDED YOUR OPINION
- Englishtown Raceway Park - Sign the petition ( No More DRAG Racing )
- Jan-Feb 2018 FS Thread
- Jan-Feb 2018 WTB Thread
- Rywire cop t1 cam trigger harness
- Tie rod ends?
- all motor Pro K series 8.81sec
- 1995 Honda Civic EX Drag Racing Question
- How much noz can my ITR TAKE??
- Swirl pot confusion
- What 2018 Import events are good in TX,NM,LA,OK
- Lsv Missfire
- VIDEO: 2017 WCF Super Street Top 10...
- Traction
- SFWD Staging Brake Setup
- CO2 boost control
- How was WCF 2017??
- Hood exit shield
- my honda civic 2006 2 door dont star
- Mickey Thompson ET STREET R??
- tubed front ends
- Suppliers of SFWD/JoJo front ends?
- VTEC CAm ID
- Bosch 2200cc Feedback needed
- 12-Sec Drag Build
- Omni Power Rear Drag Coilovers
- Drag Week
- brake booster delete
- First time at the 1/8 with new setup
- Wheel and drag radial setup for the street?
- Clutch line Quick Release
- Magnus motorsports clutch release solenoid
- Sept 2017 WTB Thread
- Sept 2017 FS Thread
- Brakes setup for 13rim 5x114 setup
- B16 transmission killing 1/4 mile time?
- First Time Drag Racing
- brakes
- Virgin B16 head being prepped for boost. Who's the best in the biz?
- Headstuds 1000whp+
- Supercharged Civic SI running mid 11's
- Anyone know fastest/quickest times for stock drivetrain?
- Slicks for 13x9 Welds
- B18c1 making conservative 800hp
- Suggestions Needed: Drag Race Purpose Turbo GSR Tranmission Options
- New Drag Racing App
- I need help!!
- InlinePro T4 manifold
- First time drag racing
- 1000+ guys, TS or open?
- Tyre size for drag
- oem brake lines
- All Motor LSV Track issues
- Tracklite or Lenso vpd drag wheels?
- oil boost/pressure -pushing cam seals out...
- so i have a civic PH15A, what does it need to be drag racing worthy?
- Max power at Eagle rods
- Chassis question. Eg subframe/Ek chassis knuckles
- 15" slicks?
- BW S66 turbo Fastest ET and Trap speeds
- Transmission oil
- 2010 Accord V6 PCM minimum inputs
- Shops in houston
- 95 coupe drag car rebuild, going B series
- My da drag car build
- Burnout - tire temps
- 96 Honda Accord
- b16 stroked to b20
- NGK IRIDIUM Issues with Hondata CPR?
- Front weight
- ef and ks tuned brakes
- K series dogbox
- Rims for 26.0/8.5R15 Drag Radial
- drag radial question
- Max compression in turbo/high hp build?
- GRP auto racing front ends
- Axles
- drag racing suspension for an (EF)
- B16 boosted stroker help
- 400+hp bseries
- Blox drag preload question
- 8thgen all motor
- July FS Thread 2017
- Stock k24a2 in civic eg 1/4 milhe time
- Xenocron RWSS and AEM calibration
- Nitrous times for b18b integra
- Go-to trans fluid?
- Suggestions: super-light battery for EG-K
- IACV on Skunk2 Ultra Race manifold
- 2000 Honda Civic ex 2-door...front k-member rusted bad on pass. side.
- Honda Drag Car Build Help
- gsr final drive or ls final drive?
- 11 sec all motor B20v HB
- Tubes Or No Tubes For Skinnies?
- Fuel set up for 600whp pump gas turbo K20 (eg).
- Connecting Rod Bearings
- Myers Competition All Motor Integra
- Difference between strains and load cells
- Precision 6870 Quarter Mile Times
- Fuel rail bore?
- SPAL Fan Relay Wiring Help
- superstreet:The fastest 2nd gen integra DB2/DA!? digital feature
- Interested to see how everyone mounts there kirkey seats
- 92 Civic EG Hatch. Beginingto current
- Which Civic
- 10 sec 4door RHD Integra
- 12 sec supercharged Integra running the 1/4 mile
- Mechanical fuel pump setup?
- July WTB Thread 2017
- Feb/Mar 2017 FS thread
- Pre-made up pipes for turbo K w/sidewinder?
- Atomizer 500lb injectors with hondata ?
- surge tank question
- Seelback/Rich/V-Spec EK 62mm Build
- In the market for sequential transmission for k/rwd series
- Ek h22 torque damper
- Keep closed front end or open up for intercooler
- It's been a while. But this is my 11.50 Index street car.
- AEM COP Conversion
- Ks Tuned Rear Arm kit
