Feb/Mar 2017 FS thread
Old Feb 1, 2017 | 11:41 AM
crazes's Avatar
Moderator
Default Feb/Mar 2017 FS thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Feb 1, 2017 | 06:43 PM
santeg1992's Avatar
10 Year Member
Default Re: Feb 2017 FS thread
Sold
Old Feb 2, 2017 | 04:20 AM
hondatech8798's Avatar
Bmc racing intake fits all b-series cylinder heads it's 6.5lt 4 injector setup but can be easily swapped out for a 8 injector head flange as its a bolted together intake and the flange is still available from bmc, it's been reinforced welded inside the plenum to keep from cracking and was anodized black with polished runners uses a 76mm honda tb which I also have brand new a billet 76mm tb is included..... 900
Also have new m&w pro14 with t1 sub harness.... 650
Old Feb 3, 2017 | 11:01 AM
mh's Avatar
mh
I´ve got a moroso Honda B-series dry sump kit that I got when moroso sold these. Never got around to using it.
will not part out.
looking to get around 1800 USD + shipping. the kit is in Norway.
Old Feb 3, 2017 | 02:26 PM
98B18C1's Avatar
Venom FPR in great condition with gauge/fittings - 110 shipped priority
Blox Purple aluminum 4" Vstack with clamps and coupler - 40 shipped priority OBO
5 gallons of ERC A8D (same as C16) - 60 picked up OBO
Old Feb 3, 2017 | 03:36 PM
NWDyno's Avatar
Located in Washington
All prices are OBO
I have paypal
Motec M130 $2300
Motec PDM15 $1900
connector kits for m130 and pdm15 $75 each
Motec ltc/lsu 4.9 $650
m&w pro-drag4 ign 250mj $800
Southbay injectors 1000cc $400
Southbay injectors 1200cc $450
Golden Eagle block oil squirter plugs $10
Miller battery receptacles $20
MSD 8232 ignition coils (4) $200
Misc T1 sensors
Misc Motec pressure sensors
Misc MilSpec amphenol connectors
Old Feb 4, 2017 | 08:08 AM
king06's Avatar
Sold
Old Feb 4, 2017 | 09:16 AM
EF'n Sedan's Avatar
Default Brand New Pro-Level K-Series Differential
Brand New Driveshaftshop K-Series Pro-Level LSD with Bearings and Speedo gear.
Was installed but never ran, gearset was parted out.
** Cone/Stub shaft not Included **
$1100 Shipped
Old Feb 5, 2017 | 01:00 AM
Steeve_Civic's Avatar
Brand new Magnum Weld rims
4x100
13x10
$550 plus shipping
Old Feb 5, 2017 | 12:21 PM
SPOOLINmatt's Avatar
sold
Old Feb 10, 2017 | 07:23 AM
Reyes's Avatar
BRAND NEW Dart B-series head.
The head was used to display valve springs years ago but that's it. I was keeping for a build that is probably never going to happen.
I do not have detailed specs of the head. From what I know there were a few versions. These are machined from a brand new GSR casting. Comes as seen in the pics. Rockers arms, and shaft are NOT included. $1,000
Asking $1000 obo. More pics can be provided if needed.
Old Feb 13, 2017 | 08:26 PM
crxmanror's Avatar
AEM Series 2 ECU
Like new AEM 30-6030 ECU for K Series vehicles and vehicles that been K Swapped. Has been updated with the latest 02v02 firmware. Will include Xenocron Tuning ECU mounting brackets, cables, instructions and original box. ECUhas less then 4 hours of total use. $1000 Shipped plus PayPal Fee
Injector Dynamics ID1300cc Injectors
Like new Injector Dynamics ID1300cc fuel injectors with less then 5 miles on them. Includes connectors, pins, original box and spec sheet. Will fit all models of Honda and Acura engines and may fit others engines as well. Retail price for injectors new is $900. $700 Shipped Plus PayPal Fee
More Specs:
The ID1300 was designed with alternative fuels in mind and is made with all stainless internals. It is compatible with all known fuels, and will stand up to the corrosive nature of alcohol better than any injector on the market.
While the ID1300 was designed with an eye towards ethanol fueled engines, they have accounted for the occasional need to convert back to gasoline. The ID1300 has a minimum fuel mass compatible with gasoline use, and will provide exceptional idle and cruise behavior under these conditions.
Specs:
Nominal Flow Rate: 1340cc/min @ 3.0 Bar (43.5 psi)
Maximum Fuel Pressure: 6.0 Bar (87.0 psi)
Fuel Compatibility: Compatible With All Known Fuels - (Designed Specifically for Alternative Fuels)
K Series Hall Effect TPS Sensor
Like new Hall effect TPS sensor for K Series engines. Used only for one 1/4 mile pass. $80 SHIPPED
- Contactless Hall-Effect technology provides increased precision and reliability over wiper-style designs
- Integral o-ring seal replaces the low-quality OEM style paper gasket
- Extended calibration range ensures each sensor can be calibrated exactly within the OEM range
- Fiber-reinforced composite housing is more durable than OEM sensors
- Durable, rolled connector pins will not become damaged during installation like many aftermarket alternatives
AEM 0-100 PSI Pressure Sensor
Like new AEM pressure sensor in excellent condition. 100 PSIg Stainless Steel Sensor. 1/8" NPT Male Thread. $100 SHIPPED
Sensor Performance Specifications:
Accuracy: +/- 0.5% Full Scale over -40C to 105C includes Repeatability, Hysteresis and Linearity
Operating Temp: -40C to 105C / -40F to 221F
Burst Pressure: 1000PSI
Response Time: < 1mS
Wetted Materials: 304L & 316L Stainless Steel
Vibration: 100 to 2000Hz, 20g Sinusoidal, 3 Axes
Weight: <85g
Supply Current: <6mA at 5 Vdc
Output: .5 to 4.5Vdc Linear
Transfer Function: PSI = (25*(Voltage))-12.5
(Supply Voltage 5Vdc +/- .5, Ground, Output)
AEM 2 BAR/30 PSIa MAP Sensor
Like new AEM 2 BAR / 30 PSIa MAP Stainless Steel Sensor in excellent condition. 1/8" NPT Male Thread. $100 SHIPPED
Accuracy: +/- 1% Full Scale over -40C to 105C includes Repeatability, Hysteresis and Linearity
Burst Pressure: 300PSI
Weight: <85g
Transfer Function: PSI = (7.5*(Voltage))-18.75
IPG Vacuum Block
IPG Parts black anodized aluminum 5 port vacuum block. 1/8 inch NPT ports. Also come with some brass barb hose fittings. $40 SHIPPED
ARP K Series Main Stud Kit
Complete used ARP main stud kit in excellent condition. Only torqued one time. Fits K20 and K24 $100 SHIPPED
RSX Type S shift Box
Used shifter box in excellent condition $60 SHIPPED
Box already trimmed and ready for install in a K Swapped car or great spare parts to have
Brand NEW Steel OEM Honda K Series oil pan
Oil pan was only used to cover bottom end while assembling engine $100 SHIPPED
Old Feb 16, 2017 | 05:17 AM
Bentley454's Avatar
Manley Turbo Tuff rods for GSR.
$500obo
JE 302411 84mm 10:1 pistons with upgraded pins.
$250obo
RacePak AEM Interface Cable
$300 or trade.
Buyer pays shipping
Old Feb 26, 2017 | 12:44 PM
EF'n Sedan's Avatar
Default ESM Spherical Rear Lower Control Arms
Brand New 96-00 Civic ESM Spherical Lower Control Arms.
$300!!!!
Old Feb 27, 2017 | 07:07 AM
leroy12's Avatar
I'm parting out my turbo B series build and have the following parts to sell. EVERYTHING listed here is in good/great condition with NO issues.
I will ship once your payment clears my Paypal. keep in mind shipping cost may be steep depending on your location. I'll be shipping from Hampton Va.
B series t3/t4 38mm FULL RACE Ramhorn turbo manifold (Can provide addition pictures with exhaust wrap removed) $470 OBO + SHIPPING COST.
FULL RACE 3" 4 bolt Downpipe $160 OBO + SHIPPING COST
FULL RACE Dumppipe $80 OBO + SHIPPING COST
GSR/B16 NGK Sparkplug wires literally used for 40miles lol $45 OBO + SHIPPING COST
DSS 3.9 B SERIES AXLES and stock half shaft. Axles were used for around 900 miles before sitting in storage. ONE boot was rubbing my brake line and tore( pics show) I've spoken with DSS and was told a replacement boot through them would be $30. The axles are being sold for the BEST OFFER!
I CAN PROVIDE BETTER PICTURES IF THERE IS A STRONG INTEREST IN THE PART!
Better deals offered the more items you purchase!!!
TIAL 38mm wastegate(Believe the installed spring is 8lbs though I do have like 5 other random springs I can include) $150 OBO + SHIPPING COST
Catch can setup with filter, hoses, and fittings $90 OBO + SHIPPING COST
BRAND NEW VIBRANT 3" Resonator $30 OBO + SHIPPING COST
Old Mar 2, 2017 | 07:43 AM
crx2nr822's Avatar
gone
Old Mar 6, 2017 | 06:21 AM
AZ_CIVIC's Avatar
SOLD
Old Mar 6, 2017 | 11:10 PM
imjustakid's Avatar
FS: MoTeC M400 serial# 2473 with following unlocks: Gear Ignition Cut, Hi/Lo Injection, 512k Logging, Overrun Boost and Traction Control. ECU is in perfect wiring order. Looking to get $2500. Call or text me at 714-334-9264 Milo
Old Mar 7, 2017 | 07:59 AM
AZ_CIVIC's Avatar
SOLD
Old Mar 11, 2017 | 09:08 AM
drvfast's Avatar
I have for sale is a B Series Hydro Competition Clutch Twin Disc with 20 - 25 hits max. Asking 750 shipped also willing to accept offers.
Old Mar 12, 2017 | 03:30 PM
Saypatyper's Avatar
hello
shipping usps tu Russia ???
Old Mar 14, 2017 | 04:29 AM
ssmrico's Avatar
came off ef sedan. conversion to be able to run a hydro trans 80 plus shipping and pp fee new wires don't need them since I got a cop kit now 40+shipping or the spark plug cover 55 shipped , 4.5 turbo elements backdoor intercooler 280 +shipping has a dent nothing else wrong was on car and being used no issue just cant use it with my new ffm set up. black works rad used but working just selling cuz changing my whole set up. 65 + shipping If interested MESSAGE ME
Old Mar 24, 2017 | 06:02 PM
santeg1992's Avatar
10 Year Member
Default BME GSR Spec Rods BNIB
Going a different route with my motor build so I decided to part ways with my BME Rods these are brand new GSR spec 21mm pin $725 shipped 775-412-2701
Old Mar 27, 2017 | 09:44 AM
St0ckEg's Avatar
Default Re: Feb/Mar 2017 FS thread
For sale brand new in box never used .MagnaFuel ProTuner 750 Series In-Line Fuel Pump MP-4303
$450 plus shipping . paid 483
​​​​​​​message me or text me at 310 802-9936
Clayton
Oct 25, 2017 12:43 AM
crazes
Nov 18, 2016 05:52 AM
crazes
Oct 30, 2016 03:57 PM
crazes
Oct 3, 2016 01:58 PM
crazes
Sep 5, 2016 02:16 PM
