View Full Version : Drag Racing
- Finally some seat time with slicks!
- July WTB thread
- July FS thread
- cosmo motors shootout $3k guaranteed!
- Hondata s300 for JUST boost controll?
- B Series COP T1 Cam Trigger Issues
- How necessary is a twin disc
- New ID 1300's
- Where to get turbo work done?
- EG>BYS wing how much 1/4 mile time will you loose????
- 220-240whp axles
- !!some pics of The green monster !!
- e85 id2000 tip in issue.
- made my first passes in 2 years, what do you think
- input on wheelie/traction bars
- SLICKS question..
- What spacers to use with v2 rims
- Shift light or monster tach?????
- who from washington state knows this car
- G-force Helmet Question
- My j series s2000 drag car build
- Warped head &/or Bent Head Studs.
- what are your thoughts about this PNP head all thoughts welcomed
- Camber/caster settings for the track
- Your quickest 60ft & 330ft on a M&H 23 x 8.5-15
- Any opinions on tuning ignition systems?
- What does it take to go 10.99 w/ NA B series?
- Suggestions on Bearing Clearance
- old school dc2 yellow drag shell previous rev hard build?
- Thank you!!!
- couple more engine building questions.
- Stock ls bottom end, gsr head turbo, 500 hp
- del sol swapped 1/4 mile times
- noobtastic
- Speedfactory 7.995@189.2!!!
- Huge CAR FIRE at MIR Last Night!
- New PB Allmotor Non vtec
- Aluminum Rods and Dowel Pin Holes
- video from cosmo motors shootout june 15th
- new twin disc metal on metal noise
- D17
- 3rd annual "Summer IREV" @ MIR on August 25, 2013
- Mech-Tech career opportunities
- Need to get in touch with Chris Miller
- Fcs fuel cell filler hose.
- This Saturday 6/22 Outlaw Tuner Shootout Eastside Speedway 1K to win!
- big fuel pump users (weldon 2035)
- Honda Day Florida
- lets talk valves.
- Anyone ever see a T1 kill switch stay on all the time?
- Ososik: Highlight Reel...
- Dragmania @ Orlando Orlando Speed World Dragway July 27 - 28
- FL2K13!! October 12th 2013
- BorgWarner 72mm SFWD Class Limit Turbo
- Whats considered fast for imports in the 1320?
- 500-600hp h22 build
- QUAIFE VS SPOOL HELP!!!
- Not a Honda
- Good Line lock instead of staging brakes.
- EG Hatch Carbon Fiber Front End
- H22 M&W Pro 10 - No Ignitor..tach signal?
- AEM ECU with K coil problems......
- AEM ECU+T1 Crank Trigger= no RPM signal?? HELP
- art morrison cage
- m factory gear set
- Dayton Ohio IFO Roll Call 6/23
- GSR Benson Sleeved Block - ARP Head Studs - Golden Eagel LSV Kit.
- How do i plumb and wire in dual MAC valves for boost control?
- quick roll cage question
- 18th annual Haltech World Cup Finals (Import vs Domestic) @ MIR on November 1-3, 2013
- Couple noob questions please help.
- NOPI NATIONALS Atlanta - Drag Program - 9/21-22
- New Record, outlaw 24,5 x 8 tire class in Brazil. 8,693@178MP/H
- Pac Performance reclaims Rotary World Record
- AEM Users help with an engine break in map
- IFO. Tulsa, OK. June 9th 2013
- Post Your Up-Pipe Setup's!
- Forum Fest 2013 at Pacific Raceways Kent, WA - June 22nd
- Kill Switch - What's everyone using?
- Integra on jack stands, no load, making horrible noise and shaking the motor/tranny.
- New Puerto Rico Street All Motor ET Record
- extended wheel stud required for 13" Lenso wheel?
- braking setup.
- NDIMA - Imports vs Domestics - Orlando Speedway
- civic shanghai motorsports world record drag radial
- Lets discuss "solid" front end bushings
- Valve adjustment specs for turbo.
- CNC 412 install without cutting lines?
- Low voltage while making pulls
- IFO: Pacific Raceways, Kent WA
- POST YOUR CLUTCH STOPS
- IFO QUESTIONS
- Harvey Crane Jr died
- June WTB Thread
- June FS Thread
- OEM 150 PSI Oil/Fuel Pressure Sensor PN?
- Twin disc-B Series
- he USA Sport Compact Association
- B-TUNE Performance @ BDRC Final Round "Video & lots of pic"
- no more pro rwd or quick 16 or 32 in OGS events
- c12 or 112Octane? How far can it go?
- our h22 honda civic at houston half mile
- all motor crankase venting q's
- Slowmotion/Paul Armstrong back at it
- Chris Miller to race in Brazil
- OsoCinco De IFO
- is there a thread with builds and trap times?
- Looking for pics of Fab C drag wing on crx?
- Dragmania last weekend Dynosaur Supra wins Street Class
- 800HP Setup ?
- D-BUILT's stock sleeve B20/V Morris Tuned
- Crank and Rod Combo for B:LS vs GSR
- Narrow Drag Racing Alloys??
- brake rotor and pad question...
- Woodburn IFO
- !!!!!Bent Dss pro series spool !!!!!
- s300 freezing up
- Question about c16?
- How to transfer power to the ground??
- Albins transmission users
- Who Is Running The Really Big Nitrous Set Up
- Titan Motorsports is coming to Texas Motorplex for Drag Mania this weekend
- !!!!Precision 4272 & comp triple bearing 7288!!!!
- 8sec. civic turbo
- Mr.johnsons 9.66 stock trans 62mm track passes.
- Temp gauge?
- Need help identifying cams
- h22a erl sleeves or darton sleeves
- Civic turbo buit by MD TUNING
- Crankshaft/ Eagle or Brian Crower
- tunerview rd1
- drag brake setup question
- June 13, import wars ( gld ) 62mm class updates
- video of QUEBECS FASTEST SINGLE CAM
- Blow off valve or not?
- Heat Treatments resets 4WD record
- 1988 Crx Si Ongoing project, rice to race
- Harmonic Damper Falling off
- Congrats to Mr.Johnson on his 62mm win
- 22x8x13 slicks tube question
- *Video* Honda Day and Spring Nationals ERacer Round by Round Coverage
- e85 stored in vp 5 gallon jug??
- Manual rack bushings???
- Dealer with 8.5/26-13 MH in stock?
- h22 new build advice
- King of the Imports @ Orlando Speedworld
- K-phonix Stock Stroke K20 10.7 @ 124 MPH Pass
- Press Release : FTW Racing Fuels is the official fuel of SpeedFactory Racing
- 4" full exhaust on eg
- godfather racing 9.6 vid enjoy!!!!
- Spark Plug Replacements - Turbo Set Ups
- Wichita KS IFO 5-19-13 Who is going?
- which throttle body?
- ifo ned vid
- tampa bay tuned fuel tech new video enjoy
- TAMPA BAY TUNED FUELTECH CIVIC VIDEO TEST AND TUNE NIGHT
- WHAT SLICKS!!!!
- My First 1/4 pass
- 1gn dodge neon srt swap 11.4@120
- lets talk gforce gear ratios
- West Coast Nationals Summer Warm Up **Sacramento Raceway**
- 5th Annual West Coast Nationals Presented By 1320Fuel.com
- PROJECT9 Somethin' (Midwest SFWD Build)
- Help me pick my slick size
- adding pins to rywire harness for AEM EMS
- godfather racing sfwd ek coupe
- The 62mm B16 that could 10.07 @149mph vid and pics
- anyone know the et record on a t3 frame??
- Wheelie Bars for my EG Hatch
- Tubes required for M&H 24.5x9.5-13?
- Has anyone had a valve guide chip, or break off?
- Exedy clutches
- Lucimar K Series RWD Civic 7.12@196
- Help h22 sh catch can block location????
- Don't read this
- quest for 10's stock gsr true street car
- Your civic hatch weight
- Stock b20-v on 22-24psi LemboMods!!
- SFWD Integra Build
- ON-DA-EDGE Darnell P. 9.75 with css(cylindersupportsystem)stock tranny....
- Project One
- will a jdm itr 4.7 fd final drive fit in a b16
- Video: Spring Nationals 2013
- little motor power
- Video: Dynamic Performance 8.73@172 SFWD Pass Winning at Spring Nationals
- needing some measurements from the wide front guys
- IREV - 2nd annual Spring Import Revolution at MIR on June 9, 2013
- Bad (non-OEM) axle causing wheel hop in burnout box only??
- Ososik: SpeedFactory SFWD CIVIC 8Sec Pass
- IFO Las Vegas 2013 Pictures by:DCSProPhoto
- Integra drag weight. How light are you?
- Traction Bar Preload
- New PB on street tires and pump gas. 10.74 at 130
- godfather civic took home the win in fwd ifo ned
- Congrats to Dynamic Performance Racing for the big SFWD win at Spring Nationals!
- Bittersweet New P/B at Cosmo-Motors Shootout
- godfather civic goes 9.6@153 t3 frame
- New All Motor H series record holder
- Braille Battery
- B20/LSV ALL MOTOR (Street Car)
- New toy: my 67mm 93 civic hatch
- biggest drag tire in eg ?
- TD Autowerkes/Belak Industries Civic runs 8.93@176MPH!!!
- A/M Drag Car F20B Opinions/Suggestions
- MAY FS Thread
- May WTB Thread
- Oil pan choice.
- World Record 7 Sec Pass!!! - Ososik
- installing my last head gasket before throwing in the towel tomorrow..tips/tricks?
- tubular front k members
- 3 piece front end question...
- water connection in comp turbo
- Aem 5bar map sensor question.... HELP
- h-series 95х89 vs 88х89?
- Cinco de Mayo IFO Las Vegas
- C.O.P. Issues
- vibrant intercoolers
- Faster responding IAT (intake air temp) sensor for OEM based managements?
- MY 67MM INTEGRA
- rockwell hardness of oem honda crankshaft
- IREV & WCF 2013 rules?
- IFO West Palm Videos
- 11.13 @ 119 Stock Block N/A H2B
- need some recomindations for rear skinnys
- TrackvsStreet
- GLD 62mm class prepaid list ( may 19 Import wars )
- Wheel/Tire setup on 9sec car?
- some of my history, made by a friend.
- Lets discuss transmissions and fluid choices
- Davila's 67mm H2B Midwest killer build
- After 2 1/2 Years - Finally.
- Some questions regarding my friends car (gsr swapped eg sedan inside)
- finally went 10s with my street car tuned drag car
- Honda Day Photo Coverage, courtesy of Fuel Injector Clinic
- 2013 TPR SFWD Preview!
- (Video) Round by Round Coverage of the EATSLEEPRACE SFWD Class at Honda Day
- Will this pass Tech????
- Nyce1's, where is my DVD ?
- Nothing but great word about locash racing
- Dragmania 2013 - May 25th-26th - Texas Motorplex
- CSS Block Users Unite !!
- Syncing ignition timings on aem ems v2
- Cosmo Motors Shootout Brutal elite pts standings
- Rear Diffuser **SHOW OFF**
- (Photo Coverage) EAT SLEEP RACE SFWD Class at Honda Day Atco 2013
- cpr/t1 cam trigger
- 85mm Copper O-ring Head Gasket
- 2 step
- a few of our cars
- Import Drag Racing event at Sacramento Raceway May 19th
