View Full Version : Drag Racing
- anyone know the manufacturer of this valve??
- Midwest Racers?
- Launching
- Crewmember???
- New times on DR's and DOT's
- B-Series transmission help...
- 2005 RSX sand rail.....
- *Video of my EG on the track*
- 2step rev limiter or no?
- 14.7 b20 Vtec........
- does anyone have a blown up tranny....
- m/t 24.5x8x13 slicks? on stock axles
- New times! I can taste the 11's
- how to get 60 foot times down...what does my timeslip mean?...first time at track!
- Pro Stock Qualifying in Columbus-Import Driver spotted
- Finally ran the new car.
- Post your k20 swapped times
- wiring question
- Who will be the first to drive a fwd Honda to a 7.99
- Stage 6 Power Street car dyno. FINALLY!!!
- look what i found this morning.....
- AEM wide band
- Took H22A Accord to the track, I'm having issues. (Video)
- racing fuel mixing... pls help
- b18c5 ef 1/4 mile times?
- import day at capitol raceway
- GOT 8.5-26-13 M&H's?
- wich tire pressure gauge is better, more accurate?
- new all motor car
- Who is the face on Sport Compact? Excellent article!!!
- NYCE1S Presents.....Turbo VR6 A.K.A. Da Torque Monster!!!!
- put together a little video.
- Battery cable routing
- My New 1/4mile Time
- sohc obx/quaife lsd, need help
- Anyone else going to be at IAS in Atlantic City this weekend?!
- Friend and I are having a dissagreement, with axles....
- --Colorado--Bandimere June 11-12...Who's going?
- too much power for the streets? wheres the line?
- cage help
- 604whp Accord....honest opinions from the fast guys please.
- OBX LSD -- Axles stuck? Quick Fix?
- Speed World May 21st.
- NHRA Street Stock at Atco Feedback
- drag raced my car for the first time
- Project Duration...(for all who've had project cars)
- Need some help picking slick size
- Pin SIze hole in One Slick?
- BlackTrax K24 hybrid turbo
- Whos going to RSD Thurs? (Great Lakes Dragaway in Wi)
- Colorado RAcers? Where U at ?
- clutchmasters stage5 clutch fx500
- can i do better on street tires at 104.9 mph?
- great idea for anyone with the resourses to do it
- Going to build a Drag car "need some info/advice From the experts Please"
- 1.5 60's
- ? About sunroof plugs in NDRA COMP4
- VHT Squirters
- Honda civic D SOCH engine
- how far downstream does a wideband need be?
- v-tec vs. non v-tec
- New England Dragway Import Wars
- stock motor with turbo 1/8th mile track times........
- Launching set up
- NHRA Atco Videos - Qualifying Runs for Pro and Sportsman Classes
- Launching on 24x8x13 slicks
- Took my JRSC GSR to Fontana
- Zex Direct Port Kit
- DC Area - College Park, MD
- gear ratio's
- OBD1 Style - Race Car Engine Harness
- EASY WAY TO CUT WEIGHT....
- What seats do you guys have in your race cars
- NHRA SportFWD Tire Drama....
- G-Force Longshifter
- NHRA@ ATCO Raceway Pics 05/15/2005
- congrats to marty and the gm team
- What does 154hp/118tq on DR's get you in the 1/4? Find out here. **Video**
- NOPI/IDRC/BOTI- Allmotor street class question, help? -Sunroof and trunk lid
- Special CONGRATULATIONS to Stacy and Tracy Hyche!!!!
- 11's are near (new 1/4 times):thumbup:
- I am confused... AWD's in Power Street?
- 10's are so close!!!!!
- Direct Port Nitrous on Stock Internals
- 91 Teg's First time at the track(results and Video Inside)
- 1/4 mile for first time!!!
- Gear ratios for drag racing??
- 1/8th mile times for first time at strip
- Need advice from other Racers
- D16z6 straight T3 12psi....110mph
- Electric Water Pump, Radiator, Staging Brake, etc
- 11.9's Stock D16Z6
- What drag wheels clear EX calipers?
- NHRA SONY Xplod
- Alabama Results??
- Question on Bogart wheels
- NHRA has announced a new sport compact organization
- what back inch space recommeded for weld import drag wheels
- 1000+whp dyno chart?
- What is the fast's sohc with stock sleeves?
- 10's at only a mere 17psi of boost
- Question for the racers.... Drag wheels development
- NHRA Atco Results Thread
- what nuts for extended studs.
- Slicks without tubes?
- Stage 6 Racing??
- T4---whats the lowest 9 second MPH?
- countering aerodynamic lift on light cars
- Turbo 4 class and RWD
- ran pretty good at the track with homemade turbo sohc
- 93 mr2 w/ 3SGTE Vs. 00' is300 w/ stage 2 turbo kit
- So I go to UTI, a teacher hates hondas, I need some vids
- TeamDC5/HRI dyno day & car meet
- First time at the track
- Bisimoto no longer has ties to Rage Performance
- fuel cell assistance?
- BGF tire pressure ??
- what size slicks/rim combo do you suggest for my setup?
- finally we can host uor own vids!
- Lisa Kubo/Nelson Hoyos not running?
- My 12.5@115 video from last week
- proform shiftlight
- JAVIER NHRA?
- Proper Back Spacing???????
- MS1 drag hood.
- new track time
- Why Bisimoto uses a d series tranny?
- 1/4 mile times question...
- anyone have pics of gardella's OTHER cobalt
- Couple of drag racing questions
- cryo treating in the bay area?
- Does my car seem slow to you guys?
- Weld Magnum 15x8
- Power Street roll call...
- turbo z6, what size bfg drag radials?
- Spools in T4
- FULL-RACE/Sav Leone Racing ????
- machine work
- To much hp and crashed
- IDRC East Coast Nationals - May 29 - At Maryland International Raceway - Mechanicsville, MD
- Goin to the track!!!!
- I have a question about the Gardella Drag Civic...
- where can i get this front end from?
- Benzo's Turbo CRX Dyno Videos
- Racing with an Automatic transmission
- high compression b20
- sp class rules for cmi's on june 24th and 25th Roll Call
- getting my first set of slicks...how do you tell if they have alot of meat left?
- anybody used XTD clutch?
- Ls turbo times (b18b1)
- how to get rid of wheel hop
- porting head
- Nopi Alabama (Sportsman) Roll Call
- Ran the car yesterday
- What front wheel studs are you pro fwd/sfwd using on your drag car?
- project Bluebomber
- need help suspison for my daily drive 600hp + turbo car need better 60ft
- Drag Radial diamater?
- new times ls hatch
- Fastest SOHC?
- WTF is up with my car?
- HELP tuning tips for locked rockers.
- cage
- Sunoco Race Fuel
- Not a Honda but figured id share :)
- whats the max hp of a all motor b seris
- Race seat and harness?
- Question about staging brake
- Finally member of the 11 sec club !!! (pics inside)
- OIL PUMP info and wtb
- WEBMASTER i can only search 1 time every session nomatter what computer im on
- So what is Gary Gardella doing with his honda?
- what ET to expect?
- 8.08 @ 85.87mph 1/8 mile
- finally ran the turbo'd del sol
- 15.5 eg/ls?
- Newest Meber of the 11 sec. club!!!!!
- What is a good spring rate???
- Launch Control
- 11.99 stock gsr turbo
- What pressure with CO2?
- Drag Car
- what is the highest LS HP? with proof...
- importcrew, a new place for drag news
- Predictions for NHRA ATCO Race
- ANyone using or have any experiece with DYNOCOM Dynos?
- How to get air to ITB's- Hood scoop, Cowl induction ???
- my launching technique and 60ft
- Ran at the local 1/8 mile track last night. Tell me how good this is. I'm a noob to drag racing...
- Need help on 98 h22 swap into a 99 civic coupe
- RSX@10psi 12.1@114mph 12.9@117mph
- First Run of 05' 11.487 @ 120.21 All Motor B16
- Got three runs in last night
- i know you guys are probably tired of this question but....
- crx times please look
- Are the 60FT times KILLING me?
- Engine diapers
- NDRA, Power Street?? Legal tires?
- 1320Lounge presents Start to Finish NHRA @ ETown Videos!!
- Brian Ballards 9.97@150 Video Plus More.....
- slick sizing question
- Small tip for removing sound deadning: DRY ICE!!
- 255 fuel pump not cutting it. T4 car....options?
- WORLDS FASTEST STREET RSX
- James Innes Racing // GSC Motorsports = GT Ride of the Month
- What kind of tire pressure you run on racing compound street tires ? ( Toyo RA1, Hankook Z211 etc...
- which tires should I use?
- Slick selection...
- what size slick/wheel?
- NHRA Sport Compact World Finals Oct. 22-23! ROLL CALL!
- Track times from before and after....
- E-town SFWD Video
- wheres the rb power??
- new here, what roll bar?
- Scatter shield??
- ANYONE RECOMMEND GOOD SUSPENSION FOR AN RSX PUTTING DOWN 450 +?
- TONIGHT 5/3/05- Steph Papadakis & ABel Ibarra on Speedscene
- Favorite EMS
- What DOT skinny is everyone using ...
- Back from "the dead" haven't been around in quite some time
- How much does your street car weigh????????????????????????????????????????
- Any turbo guys switch from a light flywheel back to stock ?
- cd full of bins for honda ecus.....
- Moroso June 4th & 5th
- BOTI - STREET-CAR SHOOTOUT AT ROUTE 66 - JUNE 4, 2005
- Dragging with Azenis
- NHRA@ E-Town Pics 05-01-2005....Yes, they have been resized already
- NHRA Atco Roll Call
- Rear solid axle for hatch
- New 1/4 times
- 24.5x9.5x13 Slicks for Honda CRX?
- Stephan Papadakis & Abel Ibarra Live on The Speed Scene!
- NHRA Spring Nationals | Englishtown, NJ
- *Mr. Fast-Turbo*stan's car and interview on TunerZine.com!!!
- I just need a harness clarification....
- Anyone think Turbo 4 deserves higher payouts?
- wheelie bars
- So where do you guys work on your race cars?
- East Coast Weather report Race or No Race?
- Englishtown May 1st results?
- EIBACH drag springs good for 60ft?? also what shocks to use
- lowering 60ft
- noobie
- Happy Birthday Mr. M&H
- launching
- SOHC 97MPH.. in the 1/8
- ran my turbo ls last night
- Ken's Kustom Master Cylinder or others?
- ITR's on 15 inch wheels, running slicks question
- '''AEM C2DI box acting up please help.....
