View Full Version : Drag Racing
- Anyone have/seen pics of the new profwd sentra?
- How many people are running LOW 11's and 10's on a daily driver and how far can I push my setup with
- drag radials
- Vid of "not so civic" whipping up on a WRX! Vid help also needed!
- Any of you guys know how the Traction COntrol feature works on AEM or Motec Standalones?
- Check these wheel 4 sale!!!
- tilton hydralic release bearing kit
- Leevon's new pro fwd pics pt.3
- Bryan's (prodrag1's) new chassis work al'a tony
- is there a slick that will fit on some 5.5" wide 13's?
- slicks
- who and where is a great shop to get tuning done in socal
- Hot Rod Pump Gas Drags
- b f goodrich
- Drag launch
- what size slicks!
- What slick/wheel combo will work with my car...
- H22 Intake Manifolds? Venom one I got suxxors
- civic hx wheel weight???
- slicks help...fast
- SportFWD
- BBK Intake Manifold were can i find and how much?
- Kenny Train and his EG Civic Hatch
- hatches with swaps and turbo post ur launch rpm
- when car acclerates,it acts like you a bouncing off the rev limter
- john shepard in hotrod magazine(anyone else see this?)
- *Integra with semi-built Ls/Vtec and B16 tranny* Will stock differential hold up??
- Tony Pedregons Quaker State Funny car
- Free Subscription - Just for HT Members only.. look inside
- hasport h22 engine mounts for ef
- New 1/8th times
- OT: Dynopack v. Dynojet
- Southeast chassis builders?
- slicks @ track
- moroso dry sump oil pump/oiling system.
- Can someone identify this mani....
- Adding ballast???To much diet, now in need of wieght
- funny car cages
- Drag time estimater
- Best thing to use when cutting exhaust?
- Interesting FWD Drag car...
- 1/8th mile to 1/4 mile
- 1992 Civic Hatchback roller PRO 4 Cylinder chassis
- Street Tire cars?
- 13" lenzos??
- need a good clutch.
- launching rpms?
- Code 8 tdc on pr3
- best 1/4mile time for stock 99-00 si's
- Advice on slicks bigger than 28
- why do some people use 16v battery
- GSR 5th tooth count?
- Broken clutches ?
- 99 SI Fiberglass Front end/ Doors?
- POWER STEERING(yes or no)
- Does anyone know where i can find skinnies with tires for 92-95 EG???
- anyone know how much dyno spot racing in san jose dyno tune for?
- Is there a way to get less N2O in first gear and more for 2-5???
- Best 1/4 mile times for Ls motor?!?!?!
- SFWD - Pro-Am - Turbo4, Whats the excitement for next season? PART II
- HELP-Weight issues!!!!
- NORAD celica pt.2...
- For the mustangs guys on the board!
- i am looking for help on buying a motor disassembled
- --OT-- Quick Question!! Momo rails & sliders universal???
- New All-motor cars for 2004!
- 11.42 @ 119 mph Ford Turbo Diesel?
- are extended wheels studs necessary?????
- Do you think we will ever have 1000meter races?
- HOW DO U LIKE THE REX?
- avid racing h22 shifting rods
- 30 lbs heavy?
- Clutch Selection
- Auto for drag racing????
- Question to those that know
- What does a T25 D16 run?
- Chassis Builder
- do u have to notch the block?
- OT:So who else saw Dan Rayburn crash his 7 second Gremlin on ESPN?
- New Times for the Si
- headlights in 1peice frontend
- 1/4 time estimate: B16A2 Civic w/ gsr tranny
- Videos..Check out the new Media page of our web site
- Traction Probelms in my Type R
- Carlsbad Raceway on Saturday Dec. 13...
- How COme nobody is boostin a deckplate motor?
- Videos put together by Slowmotion in Columbus Ohio
- Proper backspacing for 15x10
- stiff rear end suspension without drag launch springs?
- for you Carbed All Motor guys....or anyone w/ info...
- New style rear diffuser-This time its a 2 piece version for split bumpers
- VAFC wiring diagram for OBD0 CRX?
- Peek of my sportfwd car
- can you use an ACT 6puck disc with a clutch master hd pres plate.
- balancing drag radials????
- Will 225-50-15 bfg street drag tires fit my SI wheels?
- BUYING A EG HATCH W?ABS. any problems removing for drag race car later on?
- ramping up boost?
- Sport Compact Drag Racing Forum
- COMING SOON!! ..B O N K ..
- can you go too stiff in the rear?
- post your 1/4 times
- Please help! I need a Crane Hi-6 and Lx-92!
- lexan
- Bullet Fabrications or Steen Chassis.. who should i go with for roll cage?
- Modified Class.......... Any new additions???
- Go get em boys...
- Super-T truck on ESPN2
- Roll Call for Pro 4 Cyl. (hot rod)
- PROFWD ROLL CALL (Built & in Construct)
- One axle to go please
- Slick size
- Laskey Video from ATL Race
- You guys are killing me on all these For Sale adds here
- To those with MoTeC (M48/M4)
- drag parts 4 sale
- Safety Q's,. (Firesuit and helmets)
- OT:How's John Lingenfelter doing?
- venom still racing in 04
- Traction Bar Adjustment? (jimfab's)
- cmi winter warm-up
- dragging with snow tires
- aluminum dash
- Launching an auto..
- L'Natural CRX for Sale Pt. 2 New Pics inside
- B16A2 w/ GSR tranny
- CTC gear set
- Calling it quits guys......=(
- Radius rod construction
- Help mike get rid of these parts.*
- Question for you b18c hatches!
- Are these holes legal ???
- 1/4 times from 1/8 time slips!
- I NEED HELP WITH MY CIVIC SI K20A
- Things to come from Mister Andy ( SEFlxCivic )
- 180WHP out of a B16a2
- nitrous gurus i need your help
- Sport FWD-Slick size
- project car forsale
- weight reduction on street car
- Analize my slip, tell me what is going on.
- Anything new and exciting from PRI show?
- Backspacing for Skinnies?
- record for quickest LS powered car?
- Still one more Drag car for sale
- kens kustom chassis rear axle swap
- Another Quality racecar for sale....
- Fellow GSR's, what do you launch at?
- My All-Motor LS first time at the track, what do you think???
- How much whp will 8an vs 10an feed support?
- no front or rear sway bars
- need some advice for a slow poke...
- hondata launch control
- Well lookie what i found
- 13X8 4X100 wheels, where to buy?
- All motor takes less HP for same et?
- Leevons new pro fwd pics pt.2
- How to raise your motor?
- Valve Seating Question.
- Tuning Seminars
- Falken Azenis Sports better than Continental ContiExtremeContact?
- Think circle track Racing tires could be used for drag tires?
- totally random 2:30am question about DR/slick times:
- rebuild?
- MSD 2 step module HELP!!!
- Ericks car now legal for nhra with only a 25lb penalty?
- DRAG politics>???
- Analyze my 10 sec pass
- Anyone use American Racer tires at the track?
- Quality of the Jegs brand AN fittings and hose?
- Building a DART b20 tall deck motor. Any suggestions would be appreciated.
- More roll cage Questions. ..going crazy
- my a/m drag crx
- full tube chassis
- need pointers on the 1/4 mile
- M.I.A
- Anyone know how Jerrold Rhodes, new car is coming??
- new pro fwd
- Ron what the hell are you doing
- HELP ! QUICK SWAPPING QUESTION
- alcohol with no intercooler
- rack and pinion question
- carbon clutch question for DRAG launching
- is a pcv needed
- pics of my SFWD/PRO AM car (56k no-no)
- New Pics of the race car up!!
- dave despain going off vid!!!!!!!funny!!!!!!!
- Fastest 1/4 mile time for a stock B16a?
- Marty Ladwig
- Happy Thanksgiving
- Leevons new pro fwd car. Keeping it alive.
- h22 -> crx
- clutchless shifting
- Special lug nuts needed when running slicks or drag radials?
- Ran my S2000 last night.
- IDRC PALMDALE VIDEOS NOW ONLINE
- L'Natural Race Cars for sale (both of them)... inquire within
- Possible to repair slicks? might be leaking air ...
- Street Classes: Fiberglass Fenders or Stock, Widened Fenders??
- how to get sound deadener up
- whats your 1/4 mile and for how much?
- Need Help, Building a PRO/AM Turbo Car
- any 88-91 drag 4 doors out there?
- 1/4 B16A1
- Window nets? NHRA
- Who was recently finishing/selling one peice front ends(rpm stlye)????cant find in search
- leevon's new pro fwd car....
- do staging brakes come with master cylinders?
- $100 for pair of 14" 555R's w/steelies, hardly used. Good deal or no?
- staging brake
- IDRC final Quick Class in Palmdale? Who won?
- Anyone with a kirk racing nhra drag racing cage......
- best looking drag rims
- Couple race vids from our local 'where hondas are rare' track
- New Magazine Coming out OverRever Magazine
- Need Launching Tips for b16a
- Finally hit 11's!!!!
- SDS EFI SYSTEM
- your best 60ft times on azenis or similar tires
- erick's racing neon green crx under weight
- post your nitrous 1/4 mile times here
- Local guy wants $60 for 15" drag radials w/ wheels
- Fluidamper???
- Rumors and what not.....its that time of the year guys.
- Break at any NHRA Event We will be Close By! H-tech Supporters
- nhra turbo compressor limit
- venom racing done?????
- building a 1/4 mile web site.......i need pictures, slips, specs, etc.......
- Its Official Bisi , Erick, JoJo 2004 Champions
- nitrous blow down tube question as per nhra regulations
- 9sec Pass Nor Cal
- Power needed to trap 125mph +???
- The legend continues....
- John at M&H
- Fucked up launch
- WHAT SHOULD I RUN?
- Car cutoff switch.. What do I cut off..
- Shaved door handles at track....
- civic fender flares
- Sincere thanks to IDRC, and H-T.
- 4.9 f.d. ?
- 409 f.d.
- 13x9" with 260 mm. rotors
- lsd's
- All-Motor Street Car Shootout: Sign-up.
- hot rod class car-Teg / eg/ ek
- skunk2 im question?
- LENCO Tranny... pics Curtessy of fabman!
