B18c1 making conservative 800hp
I have a b18c1 block bored 83mm with cp 10:1pistons aeb sleeves Carrillo rods with carr bolts 1000 hp wrist pins Ls crank type r oil pump arp mains and head studs and acl race bearings. just curious what head I should go with to have a very reliable build this car will be on turbo application no nitrous
Re: B18c1 making conservative 800hp
Any VTEC head (GSR or B16). Even if you don't intend on using VTEC, which I'm sure you won't, they still flow better than LS heads.
Also agree, however if you plan to lock vtec as mentioned above, do not use LMA's at all. Speedfactory recommends against using LMAs with their locking pins because they push the rocker pads against the cams which can cause the oil film to be wiped away by the base circle which can cause wear issues.
I was looking into those just wasn't sure if they would be good since I'm not running vtec speedfactory has there own vtec eliminator kit I was thinking about going with that also
Don't need to lock vtec at all and if you are on a budget skunk2 pro 1's are pretty good. I ran 8's with those and if you have a good budget and your heart is set on locking vtec I would get web cam pro's and be done. That kit eliminates LMA's and you no longer will have vtec, they are truly a really nice cam set.
The G2 Racer
12-03-2008 05:11 PM
tavius44
29
10-20-2006 11:39 AM
