View Full Version : Drag Racing
- went to local 1/8th mile track......8.3@92
- GSR, or SI?
- 14.7 at 94.86 mph
- Deist scatter sheild
- trying my slicks out for the first time
- Went to the track with my new setup!
- long wheel studs
- Who's Going To Rockingham This Weekend 4/18/04
- B16a2 (automatic)
- what do you think? All motor or turbo?
- Fuel Pressure Regulator before the rail??
- I'll try again...anyone lookin for 28" slicks
- How low do your revs drop when you shift?>
- More pics of Deepstage Motorsports' civic
- Anyone try running bone stock b20/vtec (bottom end)?
- Drag Racing at Quaker City Raceway ON SUNDAY!!!!
- Roadrace slicks for drag?......
- runing with open header
- i heard....
- Base RSX vs Gsr???
- Is there a difference in headwork depending on application?
- What is the max hp a stock LS crank can handle ?
- M&h or mickey thomas slicks?
- Bad Camber = Bad Launches? [Newbie here]
- NDRA Power Street Class
- removing anti roll bar good or bad for drag?
- tilton throw out bearing
- what slick and wheel size for ITR 5 lug brakes?
- m/t 22x8x15s what tire pressure should i go with?
- Comfortable race seat for daily driving?
- Did anyone went to Rock Fall April 3 & 4 2004?
- Need Help with slicks?
- Finally ran the new setup!!!
- Where to buy Tilton clutch??
- HELP 9sec People
- went 2 the track
- Drag Tires
- For the guys that ran 11's at some point a question for yall??
- Timeslip Opinions?
- Best Site to buy M&H slicks from?
- Going for low 13s. Please advice
- 13X8 wheels that clear 90 integra brakes???
- L'NATURAL Racing's DVS Drag Civic Sports New Scheme For 2004
- major tranny and hp problem
- Drive Shaft Shop Stage III or Prodrive Shafts?
- PSI PRoformance/ Hot Rod civic coupe
- all you track techs check out my times! PLEASE
- race seat solid or movable??
- spark plugs, which ones are people using for 8+ heat range?
- Where to get rear coilover struts for drag CRX....Strange, Progress...Opinions?
- Are these good drag tyre Hoosiers
- Limiting straps..illegal??
- Stock seat with Rollcage?
- two-step?
- question about the rear suspension set up and the pedal set up for a real DRAG RACE CAR
- B18c5 Shifting?(when are you shifting?)
- B20z times
- What slicks would be best for my car?????
- what suspension set up tricks will help me hook at the track.
- Need weld import magnum wheels, 15 x 3.5 for skinnies
- good tire pressure for drag radials at track?
- Spring Rates
- Which day is better to go to at NOPI Nationals in VA??? The 24th or 25th?
- M&H versus Mickey Thompson slicks
- 25" slick and B16 tranny... questions
- help with slick sizing.
- Another slick size question
- Nossle Placement
- snap on tq wrench
- launching at 3,000 RPM's??
- 205-50-15 drag radials
- lenso wheels and 4.78 final drive
- 26x6x15 M&H DOT tires fit under ITR fenders with stock suspension?
- LAUNCHING ON SLICKS?
- 4.73 final drive and boost ???
- help me pick out some slicks!!!
- went to the track... 13.1@100mph
- Lenso Drag Wheels
- X-Cross Suspension VS Drag Suspension : Differences Similarities : Share your wealth of knowledge
- Ed Bergenholtz
- will they let me race with a football helmet at Carlsbad?
- Leaky Prelude Sunroof
- who been to a nhra powerade race
- biggest tire size on slipstream
- will HX rims fit 215/60/14 ??
- Dam I really need to finish my car, its been sitting for 2years, what to do ...LOL
- Is there a decent way to launch a puck clutch on street tires??? (should I just buy a disc?)
- Tyler H in National Dragster
- 1/8 mile track times (2nd trip)
- whats in your hatch?
- what wheels for dragracing with falken alzenis?
- Roll cage and daily driven safety?
- Drag Racers, what is the best head gasket for high boost apps?
- ctr vs. itr
- Moroso or Virginia??
- 156hp and 123 tourque on dyno jet good??
- Pics of my Sport FWD/Turbo 4/Pro-AM FWD car... it lives again
- best rpm to launch with setup? street tires
- wheel hop & burnouts questions
- Some pics of our Sport FWD car
- So Cal...better track: Carlsbad or Palmdale?
- New times with Bunk motor
- Jello wrestling? LOL
- launching with a h22 eg.
- Import Drag Racing Talking Room
- patching floorpan
- Allmotor Nitrous Question
- Ignition Timing Question??
- 16" rims for drag?
- old guy? ? on NHRA rules and roll cages and/or roll bars? 10.99 and faster and speeds 135mph above??
- How much methanol does it take to run a 1/4 mile..( turbo 1.8 )(8 injectors)
- Just got back from track times for my swapped hatch
- Help!!! look at my times how do i stop the wheel spin????
- new street times tonight.. 13.2 falken azenis
- Project: "self-funded race car"
- First times with swap
- How did you guys mount your harnesses?
- yes, another "what should this car run" thread. ...but with REAL info:
- Street Racers Profiles
- New NDRA Class ????????
- Falken Azenis Psi
- here are some 1/4 times, what could i run??
- HAPPY HOLIADAY
- Saturn With a new SPORT FWD
- is it possible to break 13.00 with this.....?
- Kennedale last night 4-8
- Moroso NHRA Florida Predictions
- BIG BLOCK H22 INTO FIRST GEN CRX
- CRX launch
- got some runs in tonight on my new motor!need input?
- does rim size matter when selecting slick size ?
- Is this time the quickess time possible???
- WHERE THE CRAZY CMI PICS AT?
- Dedicated track rims...
- Motec m4 and harness
- GTech Pro Comp
- Intereting article about the NHRA...
- Anyone gone to Cecil County
- why is drag racing a 1/4 mile?
- Need to improve 60' times.HELP
- 60' times
- nor cali vs. so cal? june 12 bakersfield IDRA
- one peice front end
- Battle of the Imports, May 23, Rockingham dragway
- Two car teams...
- help me analyze my time slip 13.41 @ 81 mph.
- What are some websites for drag parts for a 89 D16A1 integra motor?
- first time at the track (1/8 mile) -- critique my times
- In Car Footage of Titan vs Viper in final @ TX2k4
- h22a hatch quarter mile predictions (1/8 mile times inside)
- Does anyone have any pics of fuel cell, pump, lines on a drag car?
- 2004 NCRA Drag Racing Series Sched....
- 12's posible on street tires?
- Help with R/T and 60' times.
- Cant hook........Help me with avc-r tuning.....
- 93civhb/b18b1 vs integra gsr
- Drag Racing - NOT COOL?
- lsd worth the money??
- my civichb/b18c1 vs civichb/b18c1w/b16tranny
- Skunk2 Stage 3 victim.....
- beam me up on the fastest street cars list please!
- advance/retard? on a set of ctr's?
- **Video** Comptech Supercharged S2K VS Modifed WRX
- MONEY RACE @ No Problem Raceway (Baton Rouge, LA) - 4/18/04
- Spring rates for h22 hatch?
- What to expect out of setup? Quarter Mile times
- need 8x15 inch rims ASAP, what brand
- Slow track times whats the problem.
- Ran my h22 Ek... e/t times and need some help getting faster.
- Drag app. suspension
- has anyone ran there car in las vegas or wendover??
- Leevon's new Pro fwd pt...lost track hehe so 1
- tiburon with i/h/e spare tire removed runs 9.4 in 1/8
- Shaun C.'s new tranny setup...
- Question about what my 1/4 mile time should be?
- Any Results from e-town yesterday
- toda spec a cams
- Deal of the year?
- advice on quarter mile time
- horsepower vs quarter mile times
- skinnies ??
- Looking for feature cars on the east coast
- VACUAM PUMP
- Carlsbad: VW vs. Imports event
- I met bisimoto today at CMI in sacramento
- JG ??????????
- leakdown on k20a2
- What would this set up hit?
- 13.1 COMPRESSION ON PUMP GAS?
- 4Piston Racing Racecar pics
- making ss brake line ?
- dry sump question?????????????????
- Backspacing question
- Any info on this weekends CMI event - times etc
- Alabama International Dragway has a new message board
- what axles are you high hp guys using
- Test fit my new street tires today
- Friends Track Results from CMI *video inside*
- Congrats to NOR CAL MEMBERS ... CMI Thanks For all the help
- Drag Radial
- Does chriping 2nd and 3rd gear slow you down?
- Norcal CMI event.......
- track times gsr--->si hatch
- Went To The Track Lastnite (H22 4 Door 1/8 miles Times!)
- First time at track with new car, Questions
- EG22 1/4 times
- Best DOT approved tyre in a 16in for 250whp {turbo}?
- DO you belive this o-60ft time?????????
- E Town Survival 2
- Do springs effect your launch?
- New Racer
- new 1/4 mile times and setup info (jdm b18c turbo)
- New 1/8th mile times since tune
- why is my car so slow?
- LOOKING FOR FEEDBACK
- NITTO 1320 HELP!!!!!!!!!!!!
- Does urethane motor mount inserts really help???
- Get custom cut carbon fiber gauge panels by RacePlates-Special Promotion
- Get My Car Faster???
- Z10 Introduces Build Your Own Traction Bars $199 SHIPPED
- what's the usually 1/4 mile time for an 83 mph et?
- hey i just seen danny tran on tv.
- ls/vtec launch
- Norad Rims
- slipping clutch with 2 step??
- NEED street slicks 225/50/16 any shops carry them?
- full throttle shift
- slick question?
- Tires for best 1/4
- drag car owners I need your help!!!!
- Noobie needs advice on launching GSR
- H23VTEC Who's Coming to MOROSO April 17th?
- nhra.com...
- Does any1 here know what I'd need to do to make my Civic or Integra engine handle a turbo and a 150
- 7.3 1/8th is Approx. What in the 1/4 mile?
- Hyundai 2004
- New best for the Sedan
- Hoyos runs 7 sec ET in testing?
- 1/4 mile zc
- .............ALL MOTOR PORT WORK...............
- A couple cars at the shop, Deepstage and a sandrail...
- M&H New Drag Radial Sizes?
- Needed of a little help?
- Burnout pic right before a 9.0 pass at 157 mph !!!
- GUYS PLEASE HELP ME WITH THIS, IF INTERESTED!
- Nascar and drag racing?
- wheelie bars
- Smaller tires for better gearing?
- Anyone running BFG drag radials?
- Need Help with Slick/Radial Help!!!!!!!!
