I need help!!
Old Jul 17, 2017 | 04:57 AM
boostedblue23's Avatar
Default I need help!!
so I've been posting in the other forums but we're getting no answer and I feel like this ones popular. I went to the track and went to burnout to prep and the car hopped and stopped. I went to put the car in gear and goes nowhere. If I put it in gear and let the clutch put it just sits there and when I rev it the speedometer moves. I looked at the axles and didn't see much but that was from the top of the car. I have not yet looked underneath. What can this be?
Old Jul 17, 2017 | 05:19 AM
drmix's Avatar
Default Re: I need help!!
Axles. Jack up the car and investigate it more
Old Jul 17, 2017 | 06:49 AM
DumpdEJ6's Avatar
I like the tuna here
+1 on axles.
Old Jul 17, 2017 | 09:21 AM
2x0's Avatar
2x0
10 Year Member
You need to get under the car and investigate. It could be any number of things, and nobody on here can help you. You have the car and will have to take it apart anyway to fix whatever damage was done.
It's pretty easy to jack up the front and spin each wheel and axle by hand to figure this out. In fact this could have been done in the amount of time you spent posting this on 4 different forums.
Old Jul 17, 2017 | 09:32 AM
EJ1_Ex's Avatar
diff?
Old Jul 17, 2017 | 01:52 PM
Well I got under the car and looked. The axle have slight play nothing crazy at all. But however the p/s axle boot is all crinkled up. Don't remember if it was always like that
Old Jul 17, 2017 | 02:14 PM
also I have a lsd and if I spin the passenger wheel the other wheel doesn't move and I hear a clanking metal like sound....
Old Jul 17, 2017 | 02:48 PM
2x0's Avatar
2x0
10 Year Member
Probably the diff if the axle joints aren't obviously busted. Pull the axles and see.
Sounds exactly like mine did when the diff broke.
Old Jul 17, 2017 | 03:02 PM
When the axles are out how would I tell?
Old Jul 17, 2017 | 03:09 PM
2x0's Avatar
2x0
10 Year Member
If the car won't move due to a broken joint, then that joint would have tons of rotational play and basically spin freely.... you would know.
Old Jul 17, 2017 | 03:38 PM
What do you mean by joint? Where the axle meets in the trans?
Old Jul 18, 2017 | 02:28 PM
Popped axle out looked inside diff and trans everything looks solid. Can it be a clutch issue? Maybe pressure plate or something inside?
Old Jul 18, 2017 | 09:38 PM
boosted94gsr's Avatar
You probably broke all the teeth off the main shaft in the transmission. If your speedo is going up while you are just sitting there it means your diff is spinning but your gears are not. Wheel hop can cause serious damage is not time at all.
Old Jul 19, 2017 | 03:02 AM
So basically I should pull the trans an go from there.. Should I pull the driver side axle and halfshaft first and see if the splines are good on that?
Old Jul 19, 2017 | 07:26 AM
You have to pull those to remove the transmission anyways. Good luck. Post pics of the broken parts when you find them.
Old Jul 19, 2017 | 08:04 AM
Will do. Hopefully I'll get around to it this weekend
Old Jul 19, 2017 | 02:46 PM
Ok so I went and removed both sides axles and inside where the axles sit looks fine. However, I remembered my launch control only activates while clutch is in and stops at 6k. When I put the clutch in my car does hold launch control it just revs out. Could I have broken something in the clutch.
Old Jul 19, 2017 | 03:02 PM
Your launch control is probably mph based. Typically they are setup to activate under 6mph or something similar. I doubt it's your clutch because you had wheel hop then it broke. Either way you need to pull the transmission, then you can inspect the clutch too. You probably won't be able to see any problems until you split the transmission case.
SSBlueDC2
Oct 3, 2003 08:54 PM
one pnt 6 hatch
Jan 23, 2003 03:38 PM
Halive
Mar 6, 2002 10:23 AM
