View Full Version : Drag Racing
- Fj dist. B series rods . One damaged
- Built H22 Quest for potential across the board, ITB's?
- HDay at ETown 2015 Videos
- Well wheels lmao
- S300 engine overheating
- BW 92mm turbine
- 2015 SFWD Build
- HDay Sport FWD 170mph Crash Reynolds vs Sweeten Video | ERacer
- Parachute and tether mounting locations
- What size slicks? I searched but need a definite answer asap plz!
- Limitations of stock valves
- How do slicks relate to trap speed at 1/4?
- Front Crx Bumper
- No prep racing
- August WTB
- August FS
- J30A1 upgrade
- Summer Slam and HDay ZMAX Video Coverage | ERacer
- FIRST DRAG BUILD!!! ADVISE!!
- what rear wheel speed sensor works well with aem series 2 ?
- Turbo H2B Project
- Show me your DZUS or QUIK-LATCH for 3pcs front end
- First project car, which one?
- Drag coilovers, PIC vs BLOX
- DSS 5.9 power limit?
- Facebook smack talking
- Interview with Cobb and Autonerdz by Reid Lunde
- Del Sol Cage Options
- J2 front lcas with spherical bearings ??
- Interview with HP Academy and 1320 Video by Reid Lunde
- NHRA Leaves ESPN and moves to Fox Sports
- pgm-fi fuse has no power
- Interview with Modern Automotive Performance and Arce Racing Engines by Reid Lunde
- Ls vtec 800hp build.
- Skinnies on the rear
- Cracked block
- what to expect from different swaps?
- Interview with TPG Tuning and Kazien tuning
- July WTB Thread
- July FS Thread
- EG H2B drag build questions
- -20an fittings?
- quick 23' to 24.5 Q
- Hickam's RWD Civic
- how to get better first 1/8
- Gringotegra goes 190.03 mph in the 1/2 mile. IN COLORADO!
- Forum Fest 2015 @ Pacific Raceways
- Garrett GTW series turboes
- Battery Cutoff Switch... 2 or 4-post?
- Electric Water pump
- World First 4 Wide Sport Compact Race | 4 Angles | HDay ZMAX
- s300 bbg help
- Eg H22 first time drag slips
- Any real world experience with Skunk2 Alpha rods? B18C
- Honda Day ZMAX Drag Strip Videos
- Awd K series civic Vs 9 sec CRX ...LdL speedshop
- b20 turbo stock motor
- Do these times add up?
- New SFWD & All Motor Classes for the 2015 Pan American Nationals, July 17-18-19
- multi pass rad setup with intercooler core
- Interview with Mainline Dynolog and Dyno Dynamics by Reid Lunde
- Quaife LSD car pulling left question
- CMI summer nats 2015 sacramento raceway
- June WTB Thread
- June FS Thread
- 9.48@161.8 in my Ratchet Neon
- Anyone setup rolling antilag on s300?
- U.K. FWD Drag Series Round 2
- Pegasus Clamps OK?
- harness bar on roll cage?
- Homemade VHT/Traction compound
- Civic (DelSol) line lock question
- Hondata antilag not working.
- Finally! 10's
- Gringo Finally goes 9's! lol 9.86@158!
- tranny guru need input
- test and tune days
- Best current crop of 72mms?
- Problems installation M&W pro 10
- skunk2 90mm ultra tb and fuelab pressure regulator help
- Spring Nationals at ETown Video Coverage
- Pro 14, cbr coils, t1 cam trigger wiring
- DSS Driveshaftshop Axles 5.9 High Quality 850 WHP shit after 500 miles low boost
- adding abs sensors for traction control
- OEM or ARP main studs on high HP motor?
- p2w clearance for high comp k24
- dwell settings
- Summer Import Nationals, May 23-24 Orlando Speedworld
- Interview with David Hsu from Skunk 2 (Complete)
- 8 Second EK
- English Racing's 1,000+ HP DC2
- Valve seat corrosion with C16?
- honda day zmax
- Fuel Pressure S300
- aem 1040 series 1 jumpers.
- Where in northern-central Cali to get corne balance?
- Bay Area machine shops that O-Ring and do beryllium valve seats?
- Interview with D3 Performance and Haltech
- post your fire suppression systems!!!
- Need a hand setting up nitrous for a manal trans
- How wide can you go?
- May WTB thread
- May FS Thread
- Need a Bigger Pump
- Road legal B16 Civic Ek goes 10.56 @ 129mph Santa Pod UK
- Vegas IFO live feed
- spring nationals updates
- Gringo goes 188.28mph Standing 1/2 mile. Still slower than Bisi tho :(.
- Anyone use Holley wideband?
- Interview with Adaptronic and EmTron Australia by Reid Lunde
- Strange Suspension Ride Height Questions etc.
- Sheepey built goes 9.0@164 on a slick track
- SFWD Fuel (OGS)
- Fire Suit
- CMI Sacramento racing action
- CO RaceFab sfwd EF
- Tire Pressure
- Interview AMS Peformance and ProEFI by Reid Lunde
- anybody using iPAD and hondata instead of factory/aftermarket guages?
- Lexan Windows, Carbon Fiber/Fiberglass Doors?
- HDay Atco 2015 Videos by ERacer
- MH drag slicks 8.5/23.0-15
- Slicks for 285whp B21-series "drag Ek"
- roll call for IFO national trails this weekend
- race spec switch panel.
- aftermarket sleeves
- Interview with Real Street and Forced Performance Turbos By Reid Lunde
- Which staging brake do you prefer?
- Mid 9 seconds car
- Updates Honda day atco
- Help please - Custom Race Car wiring with ARC 8000
- Double beadlock drag wheels
- Gforce or PPG dogbox
- Interview with Shane T tuner of Ekanoo race team By Reid Lunde
- Water/Meth Fail Safe Transducer Hook Up need help :)
- UK FWD Drag Series 2015 Round 1
- irwindale speedway being demolished
- renegade raceway 3/28/15 stock internal h2b
- 8s on Turbo, 9s on Motor
- another b series quest for 9's with stock gear set
- Tire recommendations
- WORLD’S FASTEST Lotus Elise K20 Turbo
- Kings Performance / Amer's S2000 - Game Changer Record pass Video 7.84 @ 175mph
- Interview with Xenocron and RaceSpec by Reid Lunde
- April FS Thread
- April WTB thread
- Battery options with 170amp alternator....
- Spring Import Nationals April 25&26 OSW
- Pro1 Cams w/GE cam gears QUESTION???
- Anyone here used ERL for a drag car???
- Help me!!! Slick and wheel setup
- jdm itr transmssion and bad 60 foot.
- New Weekly Interviews by Reid Lunde
- Rated R / ImportDPS SFWD "Blue Magic" 8.46@175 MIR
- mounting racepak/aim digital dashes
- TX2K15 Gringo runs an 11.327@147.83 on 225/50/16 R888 lolz
- hi boost and low boost
- 16 Volt Batteries
- Anyone replace just the cage floor plates?
- NHRA Rollcage
- IFO Wichita 3/22/2015 ROLL CALL
- Tilton twin disc flywheel
- VP M5 Methanol vs VP C85 On Mild N/A Motor.
- video- Dynosaur Performance Civic Belle Rose IFO 2015
- Golden Eagle scatter shield
- none vtec head v vtec head
- b16/gsr Victor X differences
- Gas Prices and Traveling
- Goal: Low 9's SFWD trim, what to buy next
- Cole Marmon 8.12 @ 189mph
- FRANKS 3 PIECE FRONT END WITH WELD WHEELS (PICS)
- what fuel and why
- Borg Warner SFWD 72mm compressor map
- Flat bottom and Aero gain?
- Import Door Slammer History
- Lucimar Racing World Fastest 4cyl Honda
- Fuel Pump Wiring Double Checking having issue
- Flying my Quadcopter and multiple videos at Cmi March mayhem
- March WTB thread
- Mar FS thread
- Fuel Sending Unit Blk/White wire Fried! Need help asap :)
- remote water pump
- Looking for 25.5 cage builder
- The All Motor B series Quest for 9's
- traction bar with rad foot/turbo support provsions.(tegg) Q's
- Aerial drone view over IFO Bakersfield 2015
- Backwards fwd launch IFO Bakersfield 2015
- English Racing FIS Hatch, 9.31@162mph takes 1st at IFO Bakersfield.
- Clutch Release Controller ?
- Jnicks K-series Eg hatch build/ Restoration
- Battery Switch Help
- Web Cams and Seating Pressure
- Twin GT55rs 3000GT in the works...
- b16 intake manifold HELP !
- New SGMP owner ... Awesome
- KING Amer's "Game Changer" Stock Chassis Honda S2000 1st 1/4 mile passes
- Should I block Heat Hoses?
- Weld 13x10 with M&H 24.5 9.5 x 13 slicks
- JE Pro Seal Head Gaskets
- Are skinnies supposed to be sketchy?...
- Feb WTB Thread
- Feb FS Thread
- Help to buy drag intake manifold
- AEM Pro RWD Relisted/Sold..Again
- FIS and 10.5 index car 92 hatch
- DC2 Integra from New Zealand
- PRESS RELEASE: 4 Piston Racing Teams up with Ramey Built for 2015
- 2015 race schedules
- drag set up ek3
- Front brakes
- should i change tire size?
- Ccc Racing Banned From Ogs1320 Events
- Another 2015 SFWD build thread. Yawn.
- Gutting and Cutting?
- Myers competition
- camber kit or extendid lower ball joint?
- Awd Civic 9.1@145 noprep 2015 Sacramento
- After degreeing your cams?
- Gangsta lean for f20 fwd setup
- ARC 8000 Switch Panel
- FOR IMMEDIATE RELEASE: Darton Sleeves joins forces with SpeedFactory Racing for 2015!
- EF turbo wagon at cmi Sacramento
- Starting off 2015 race season Sacramento CMI
- b16 build. will it touch 9's?
- 76 mm throttle body gasket problems
- exospeed - source racing - franks - strada ----HELPPPP
- 1g fuel cell enough for 1 pass @ 900hp?
- TD AUTOWERKES REVENEGE OF THE CARROT RATED XXX
- Start of a New Year WTOLS - Ososik
- Crank good or no?
- Car changing timing by itself?
- Jan WTB Thread
- Jan Fs Thread
- Skunk2 pro 2 coilover experience??
- drag chassis on ebay
- I'll Be Back....
- A comparison of Billet 5731 vs Billet 3076
- BFG G Force drag radials or M/ T et Street radial radios
- AEM ProRWD Honda Auction up for grabs.
- 9.15@167 with cylinder support system(CSS)
- Integra Gsr vs Honda Del Sol Vtec
- 13inch wheels fit over the 5lug ITR 5x114.3
- Honda Day 2015, Canadian location?
- Orlando Speedworld SFWD Championship Series 2015
- Best contact patch?
- 2015 WCF Purse uppped to $65,000!!!
- Mission critical performance or 4piston ???
- PFC hatch runs 8's... FINALLY!!!
- All Motor Sport
