View Full Version : Drag Racing
- Slicks Question for EG Hatch
- Inspirational message for the real Drag Racing Enthusiasts..
- IFO Baytown Tx
- Knowledgable drag guys chime in..question about slicks
- Ifo Pittsburgh Raceway Park June 30th
- Dedicated Fuel Cell DPI Nitrous, Q16 vs C16 vs NO2
- Nyce1s Grudge - 28s Gone Wild G-Body Style February 16th, 2013 @ SGMP....
- E85 vs Q16
- Corner balancing
- Nyce1s Video - Humble Performance 9 Second All Motor Street Honda Civic!!!
- Any QSD dealer or a way to get in toch with them!!!!!
- Feb FS Thread
- Feb WTB Thread
- comparing turbos for my setup (a little help)
- Nyce1s Video - Full Time Fab Race Ready 2K13....
- Small tire gear ratios (yes i did a search)
- Spark plugs
- weight reduction without losing function
- Nyce1s Grudge - Da White Boyz Coming to the G-Body Shootout @ SGMP Feb. 16th, 2013...
- 8.044sec pass Street Tire Turbo Integra 1/8mile
- 62mm turbo cars post up your times!
- Press Release: Group-A Autosports & SpeedFactory Racing
- PRESS RELEASE: NDIMA announces it's official home track!
- Nyce1s Grudge Video - Mike Stavrinos VS Mr. 5 Speed this weekend Feruary 2nd, 2013!!
- Best/reliable stroker crank shaft on the market ??
- Irwindale Drag Strip Photographer
- Bolisbuilt Racing: EM1 Build
- B-Series/N20 car what size tire?
- Can I barrow your Race car
- Could I get about 600 whp with s259?
- Leaky Moroso Oil Pan
- need to order stroud super comp parachute
- Ososik: IFO Arizona Video
- chute mounts/chutes/pull levers.
- AFI Topmount, Tial 44 mvr, t3/t67 HO Turbo having boost creep issue
- Opinions on my drag plan? Plz
- What size slicks?
- FUELTECH ECU?
- Weldon pump mounting (flood hole down)?
- Looking to purchase a chassis dyno. Anyone know of any used units available?
- Some battery info
- What diameter slick for a 180-300 whp gsr eh2?
- True street interior question
- Which Skinnies?
- Type R Cams vs. Skunk2 PRO 1's - Highest HP Made on Type R's?
- B18C1 Water pipe (between pump and stat) same as other b series??
- Which PLM Header?
- Parachutes & Funny Wings
- FCS 5 Gallon Fuel Tank
- h2b options
- Member - Boosted-Hybrid!!
- La Gallina Industries / Humble Performance SFWD Turbo K Project
- Import Face Off Phoenix 1/27/2013
- Water cooled center section...garrett gtx
- What to expect from a Tilton Single Disk?
- SFLAuto Ek Em1 SFWD rebuild
- Kings Performance Silver Bullet Dyno Video 942whp
- Arias vs Wiseco vs JE vs CP vs Supertech Pistons
- Calling all ppl with Forward Facgin Turbo Manifolds to chime in
- IPGParts.com Tuesday Ten: Norris Prayoonto
- So Cal Alignment Spots
- 2013 GLD schedule is up
- EG Coupe Vs. Hatch
- how do we stack up against other makes and models
- What slick would you run on my turbo EG?
- Del sol slick question?
- Saftey Equipment
- Aftermarket Girdle Users
- Fastest 62mm in IFO FIS class?
- HOW TO PROPERLY LAUNCH
- AR-AFFF based fire suppressions systems for the ethanol guys?
- what's the best 24.5 inch slick
- Looking for pics of forward facing turbo/air to air setups
- AWD K20 turbo EG
- Brent's SFWD TERROR Brought to you by: TD Autowerkes
- k20/k24 swapped S2000
- Input and suggestions from high HP racers!
- Comp Turbo Feedback?
- Fuel cell stock style pump?
- Titan Motorsports Supra - First to 200mph!!!!
- Front lower control arm bushings for the EF chassis.
- Solid NHRA safety rules
- M&W pro 10 vs hondata CPR
- 2012-2013 crx build
- GP1 Racing 2012 Recap/Thank You
- Almost finished with our first billet block
- Ballistic batteries
- El Fredy RWD Civic For Sale?
- Parachute mount and location
- Drag cars around Indianapolis
- 2013/ EK Drag Build
- Light drag car pics?
- exospeed EK wide rim/Tire size ?
- Slick size for Nitrous car.
- 9.3@163mph "BW67mm" @ BDRC Round 3 Video & Pictures
- my complete crx build
- IFO Bradenton, FL 1/20/13
- Blox Pro REAR Drag coil overs
- Do you consider mileage on the chassis before building a SFWD?
- info on rwd lutz civic
- LUTZ RWD Civic
- Something a little different. 62mm del Sol build for 2013
- Need some Kpro Help
- 5 lug drag wheels?
- Drag car or not to drag car
- Cosmo Motors Shootout official flyer 3/23
- South florida roll racing
- #TBT NDRA Atco 2004 - Turbo 4 Class (ERacer)
- DT Racing's Integra 67mm 991hp 2 year Build
- true street/sfwd door panel predicament
- Lets see your car wraps!!!
- Last year of Firebird Dragstrip
- Safety harness mounting
- One of the baddest Intake Plenum Manifold is back on the market for the K Series.
- IPGParts.com Tuesday Ten: Chris Miller
- Cracked Piston ??
- 2013 62mm Drag/street build lots of pics inside
- *Video* CLM Motorsports Ricky Silva: Road to WCF 2012
- Jan FS Thread
- Jan WTB Thread
- CCC Racing 2012 Season VIDEO!! Happy new Year
- First time at track 10s
- Nyce1s DVD Available... DOTNETBOYZ Grudge Day Massacre 2K12 @ Atco Raceway!!!
- Fastest 62mm ET?
- AR Performance EG Coupe working towards 9's
- AN Hose Size For Cooling System
- D3PE presents "The Clique"
- Roll Bars
- *Video* CLM Motorsports Ricky Silva Road To WCF Teaser
- Hondata Traction Control (video)
- IFO Import Face Off Bakersfield 2/10/2013
- Ososik Life in 2012.
- Gearbox for D16 DRAG CAR
- Quickest Imports / Compact´s Listed
- charms city tuning
- 2013 Import Face-Off points regions and 2012 winners!
- #TBT NDRA Comp 4 - Atco 2004 Video (ERacer)
- 044 filter question...
- D3PE How To Not Die Drifting Over 165MPH On The 1320
- 14.9 ET down to 13.1 with NO POWER ADDERS
- 10.92 @ 130 on a stock 200k mile ls/vtec
- custom da integra drag bumper
- Kings Performance Yelloow Bullet S2000 8.7 @158mph video
- Web Camshafts All Motor ?
- OneMotion Auto Test and Tune
- fuel cell questions
- AARON LOPEZ - 2012 Import Face-Off National Points Champion!
- high compression d series with bisi 2.4 "turbo" cam, all motor...
- burnout issue at drag strip
- Help choose skunk2 pro series or supertech valvetrain???
- benson sleeved blocks
- Titans old Celica goes 6.26
- world cup second chance footage?
- My DA Drag Build Hopin For 10s In Denver!
- Exospeed Front End shipped in less than a week!
- First 10 Second ALL Motor SE-R....History has been made!
- Allmotor Nonvtec B20 11.75
- Gangsta Lean Designs
- head bolts? arp or eagle
- Feedback wanted, Import wars at GLD 2013
- Coolant Line Configuration
- 15'' or 13'' wheels and why?
- Port and polish b series head
- Methanol fuel pump
- strange drag suspension
- Which Wide band?
- CARBON FIBER STRUCTURAL ROOF
- Rippin on a new 2000 si
- Import Showdown 2013
- Eliminating Vtec Solenoid?
- Flatout head gaskets to 1000HP
- Cosmo Motors Shootout Farmington Dragway
- Traction Bar/Lower Rad Support Question
- Dog box whitch one the best /witch one the worst
- 2013 MIR Schedule
- 2012 Build and season recap
- T1 Battery Disconnect
- Traction bar settings - h22 eg.
- Map sensor?
- !!!!!Cc triple disk on a h2b!!!!!!
- best tranny hand cuff?
- 2013 Dates for IREV & WCF
- boost controls
- 400hp turbo gsr
- Drag Radial Discussion lets get something going TIRES ONLY
- Casting Call
- (ESR Video) SFWD Shootout at the Fall Nationals Round by Round Coverage
- what water pump for air/water intercooler?
- Fulltime-fab/Hiboost 9sec license final pass
- IFO PALM BEACH FLORIDA ROLL CALL
- Need help with Hondata CPR coils
- spindles for dss axles
- Boost Films SFL - NDIMA Honda Fest 2012 @ Lakeland Drag Strip
- copper headgaskets?
- San Antonio IFO. 12-9-12. Who's going!?
- WtOL-S pt2: Ifo Vegas 12/12
- Jays ALL-MOTOR B-Series 10.7 pass..
- Team Bahrain/Drag Cartel K series all motor 9.681@137mph (221km)
- 2013 Import Face-Off Schedule!!!
- Battery location and kill switch?
- E. Kanoo Racing / Titan Motorsports goes 7.20 to set new Supra record
- Analysis This timeslip!!
- drag suspension question.
- Need Help picking a car quick!
- 2014 race schedules
- LowBudget finally made it to the 10's
- Mounting a 1 piece front end for maximum functionality + serviceability?
- Twin Disc of choice High WHP
- What's best 60ft on 24.5 tire Sfwd?
- Competition Clutch Super Single- Pics inside, thoughts?
- Skunk2 cam gear markings
- 2013 Rules
- Visit the 2012 PRI Tradeshow with D3PE (vid)
- Dec FS thread
- Dec WTB Thread
- no reverse
- Car sitting on slicks for a while
- Quick intercooler pipe size question
- Noob needs help
- what trans for next season?
- s300 seems to be shutting off the injectors, datalog inside...
- Building a motor, opinions welcome
- New PB 11.92 All motor Non Vtec civic
- Custom line lock, using Mac Solenoid?
- Best place for Vibrant pipe
- Dampner/oil pump question for 500whp
- Video MIR WCF 2012 by sab
- My 1989 EF Hatchback, 10.17 @ 129mph all motor
- What type trans for strain gauge shifting?
- New SI (2011-2012) civics, what type of wheels/slick combo are you using?
- D3PE "How To Make Your Neighbors Hate You" ft Jimenez Racing
- 2 port brake master cylinder to run w/out booster
- full blown dual pump fuel gauge problem help!!!!
- Exospeed
- Looking for 13x8 rims 5x114.3 drag racing.
- Vegas IYFO the night before IFO...
- H22 Type S accord (NA) - want to run 13's help
- who makes integra sun roof caps and tips to shaving weight on integra
- 5th annual west coast nationals 2013 ? Bakersfield ca.
- Fuel Cell Question - Minimum Volume?
- Baton Rouge - IFO Vid
- Nyce1s Video - The Hurricane Sandy Aftermath & An Inside Look at My Home....
- 5 of the fastest honda's on the planet
- IHRA Classes
- Snake & Mongoose Official Movie Trailer
- Prayoonto Racing at World Cup Finals 2012
- Ososik: Humble Performance MIR!
- Chris Miller goes 8.009 @ 188.62
- The World's Quickest and Fastest S2000 - The S2King - New World Record
- Hondata S300 VSS reading problem
