View Full Version : Drag Racing
- Big Thanks to SPEC Clutch!
- MAPerformance 2nd Annual Sport Compact Proving Grounds June 26-27 BIR Brainerd, MN
- How much fuel do you go down the track with?
- Places to get 235/60/15 M&H on the east coast?
- Private Track Rental Fontana Autoclub Speedway
- CRX B16A Front Motor Mount
- SPRING NATIONALS COVERAGE (VIDS & PICS)
- Has anybody had any expirience using a ICS Titan head gasket for b series ?
- suggestions about my setup
- what did ya think about floyd mayweather and mosley battle
- Quesiton about oil return line
- Street/Strip coilover setup?
- InsideImport.com Does Spring Nationals @ Etown 2010 Qualifying Coverage
- FWD Radial: IFO Baton Rouge
- need the answer once and for all!!!
- May FS Sticky
- May WTB Sticky
- recomendations for heat coating
- 14th Annual Sport Compact Spring Nationals Coverage by: GRS Motorsports
- need help with my b20 set up
- Source for Parts
- M&W ignition
- New Hotrod CRX finally done
- Does ceramic coating make a big difference?
- GRS Motorsports Video Mix for NSCRA Round 3: The Saga Continues
- m&w ignition
- Life Expectancy of Aftermarket Valvetrain?
- Back on the Road...
- Need help locating a S2000 Oil Pump
- Suspension Setup
- Type R LSD in a GSR Trans?
- All motor canadian record
- 4in aluminum downpipe???????
- Need a supertech retainer for B-Series
- Titan Motorsports Video of 3 second run
- Best drag radial tire size for around 550-600whp
- Stock sleeve ls/v
- Fastest H2b Turbo??
- ILL GARAGE's Project JUNK
- torque specs for little bolts on weld magnums?
- Thoughts on turbo rebuild?? or other problem...
- 205-50-15 FWD Outlaw: Run what you brung on so little.
- NEW RULES FOR VENDORS
- backspacing question to buy wheels
- Wild rides & Crashes from ADRL Radford Big End..
- 1000 HP Air to Air IC, who's using who's? Let's see your set up...
- NFP all motor buggy (video inside)
- 1620 weight what mph to run 9.99
- s366 won't clear hood with topmount, will a hp6262/6765? anyone got some measurements
- Need help!! d16z6 IACV!
- some sick technology
- Prayoonto Racing Announces Title Sponsor Partnership with Brian Crower (BC).
- pics inside ,need your opinions
- Drag alighnment specs '00 civic Ex
- Michigan IMPORT FACE-OFF: 6/6/10
- Considering an Air to Water setup, I have some questions...
- Win FREE NSCRA event tickets
- M&H 24.5x9.5 On a Crx?
- Sacramento Raceway CMI Spring Jam 2010 Video
- CMI Spring Jam Pics 4-25-10
- sawaddee krab my garage Fasthunter Thailand
- Congrats to Justin Nassey (Bubsboostedeg), first 9 sec pass.. 9.70@157.45 T4/T67
- Nyce1s.com - Chris A.'s A.K.A. Killacoupe VW Golf All Motor 24v VR6 Street Car!!
- CMI Spring Jam 2010 Results
- Post: Nitrous set ups
- H22 DC2 Turbo at Pacific Raceways Video
- Epping, NH IMPORT FACE-OFF May 23...
- does my lost motion assambly look ok?
- getting to track on drag radials.
- 635hp/396 on e85 and 1000cc injectors
- Name That LSD
- InsideImport.com Brings You Honda Day 2010 Atco, Nj
- Team titan makes history 3.99 at 182
- 450hp 15lbs pump gas dyno video.
- What would be your dream match race be?
- 400 hp 11 sec em1 si
- Do these times sound about right?
- Nyce1s.com - 14th Annual Sport Compact Spring Nationals @ E-Town May 1st & 2nd, 2010!
- What is the best way to get rubber off paint?!
- 12.87@106 All Motor Civic SI Sedan!!!!!!
- Civic 08 Sedan All Motor 12.87@106
- h2b cam issue.
- Post up Your Brake Setups
- looking for someone to grind down a set of roller cams
- Skunk 2 extended studs
- 2010 IFO Noble, OK Rescheduled for JUNE 13
- NRG TECH DYNO SHOOT OUT COVERAGE
- Montgomery IMPORT FACE-OFF: May 16th...
- DSR Motorsports press release: 2010 sponsor list
- Fastest 4 cyl in the standing mile
- Import Only Nights - 1 time a Month - Atco Raceway!!
- CMI APRIL 25TH
- How is everyone mounting their Gforce Shifters?
- Possibly adding 11.50 & 10.50 index classes to WCF on Nov 6-7?
- Top Dog In Upper-Midwest?
- InsideImport.com Brings You NYCE1s.com Dyno Shootout @ NRG-tech Racing 04-03-10
- **Quick question! Need help asap! ARP HEAD STUD QUESTION!
- Integra Tube Chassis Drag Car
- NRG Tech's Honda Day @ Atco Coverage!
- wanting to build an high hp auto trans B series
- HAVideos Vol Deux DVD Available NOW
- ferrea cam help!!
- cmi on sunday ?????????????
- 2010 Indy Street Car Shootout
- manley rod bolts
- Turbo oil line return concern..
- NEW PB at Import Wars 1 - vid inside
- my 67mm sfwd vw build
- Dzus Fastener and Window net question
- anyone with a dog box using stock shift linkage
- All Motor B-Series Civic, US 10.94s. 122mph
- 2010 Nopi Schedule Release.......
- 2010 HondaDay Pics
- Congrats to Rick Everly (nonvtecallmotor) 9.37 @ 156 SFWD!
- Body Blow-out!
- Import events @ MIR this season?
- Congrats to Jeff (TEAM XENOCRON) on the 11.50 index Win!!
- lug nut help
- Almost ready to make it's track appearance!
- B-ROD RACING OUTLAW PROJECT
- Battle of the import- part-2 orlando! Thanks rain.
- 22" vs 23" slick?
- IFO May 2nd Kansas City Roll Call!
- n/a h23vtec accord 1/8th mile street tires
- DC Integra: Let's talk motor mounts.
- NRG BILLET BELLHOUSING pics
- Tial MVR-44mm and MV-S V2.0(pics w/precision 40mm)
- Import Wars 1 April 18th 2010
- First trip to the strip with new set-up
- TSADYNO.COM Presents... The Spring Rotary Dyno Battle!! Sunday April 25th, 2010!!
- my quest for 10s... fail
- HPC True Street video mix
- Nyce1s.com - Akafella & HI-Boost Visit JR Racing!!!!
- B series Kinsler Intake manifold
- big up's to PCS & TURBODANO!
- BARONA DRAGS SPORT COMPACT SHOOTOUT APRIL 17
- which to go with FD or LSD?
- Nyce1sClips - Certified Racing Testing For Honda Day Atco, 2010!!
- IDRC in fontana ??
- NSCRA Spring Bash.
- jdm dc2 race front?
- Omni Drag Differences?
- Enn1 Presents-Test and Tune 4-14-10
- How to remove and install copper o-rings
- LSD = worth it?
- Anyone have luck with street tires on the track
- What are the best drag radials?
- Import Face-Off print magazine coverage...
- Need to replace one Weld Magnum skinny
- All active racers/teams please list yourselves here.
- Traction issues
- Join the MIR fan page on facebook!
- 3 Wire coils for C.O.P.
- civic si drag
- Stock Block All Motor H2B 11.74@115
- Boti 2k10 > Who's coming to east coast?
- Radiator support for outlaw/street comp question?
- Nitrous Refills in Los Angeles
- What bias-ply/radial for 6-700hp+ on the street?
- TD Autowerkes at NSCRA Spring Bash
- lug nuts
- roll cage question
- have a question about one slick bigger than the othr
- Video - Isaac's JR Racing Turbo Civic Gets Ready for 11.50 Index @ Honda Day 2010...
- My NSCRA "Spring Bash" pics
- HPC #1 Qualifier True Street again
- What ever happend to mr David Buschar RS street car?
- ryan 10.06@153 pass
- Up and coming events for the Turbo Chassis School.
- tire burning
- Kukitin's new PB 9.33@162mph
- Turbo civic finally broke in the 11's.
- Head lifted AGAIN! What head studs for 35-35psi????
- Test and Tune Sacramento Raceway Pics 4-10-10
- Safe or not
- Racing Action Continues at NSCRA Spring Bash!
- drag wheel size
- NSCRA Round 2: Spring Bash LIVE STREAMING and Gallery
- KSP/J&R Auto Sports Stock Sleeve 67mm Build
- Enny1 presents:import survival 3/28 and Boost gsp meet
- jojo callos front ends?
- WENT TO THE 1/8 MILE TODAY
- cmi has been cancelled new date april 25th
- CrX EE8 Vtec Eudm
- Pueblo, Co Import Face Off
- traction control set up
- Jdm ITR tranny for boost????
- NSCRA Round 2: Spring Bash Gallery and Videos
- NSCRA Spring Bash Event Coverage By: GRS Motorsport
- Fuel pressure gauge on a F23a1 motor
- DFW IFO ROLL CALL
- So there might finally be an IFO in the NORTHWEST (Washington)...
- Nos51's New Eg For NSCRA True Street
- FASTEST TIMES ON STOCK PORTS??
- 14th annual Sport Compact Spring Nationals May 1st&2nd @E-Town!
- Outlaw Coupe Build
- 2010 Honda Day, Atco | Race Class Poll
- Pics of my new Albins Dog Gearset..
- Suspension ????? 25" slicks fitment
- Roll cage recommendations in NoVa
- So there might finally be an IFO in California, BUT...
- you can put injectors anywhere
- 2010 nscra true street build, so mich damn pics hope u like
- cmi sacramento sunday april 11th
- Nyce1s Grudge - Ndacut Grudge Wars @ Fayetteville Motorsports Park March 2010!!
- Guys, I think I may have gone a little overkill with my fuel pump....need advice.
- Who's coming to the NSCRA this weekend?
- Competition Stage 5 with upgraded pressure plate TQ rating?
- short track times?
- TGR gets ready 4 Honda Day w/SSR Outlaw Header
- DSR Motorsports new suspension sponsor!
- broken quaife
- Inline fuel pump setup question
- Will a blox fuel pressure regulator fit on a AEM fuel rail?
- Ticking skunk2 valvetrain. please help
- TURBO B20VTEC CHIME IN,, HAS ANYONE PUSHED THE LIMITS OF THIS MOTOR
- Bogart wheel fitment
- skunk tuner 2s
- (PIC) Request eg
- Accuracy Automotive 67mm EK Coupe
- rollcage help
- Liberty Bellhousing
- NSCRA Round 2: Outlaw Street Preview! April 11th Live Streaming
- Can a catch can mess with your tune??
- DSS 5.9 axle nut
- Roll Cage Accessories
- Race Gas Question..??
- Drag cartel stage 5
- looking to buy ferrea/crane roller h22 cams
- Who has that new Miller/NRG Bellhousing? Lets see it!
- where to buy racepak
- HPC getting ready for NSCRA April 10th/11th
- lisa kubo passtime video
- NA B18C
- ring gear question
- Sporty Motorsports New 13B World Record 6.900 @ 198.40 MPH
- Van Natten Picks Up New Sponsorship For 2010 For The Neon
- Yesterdays drag strip results
- ** April FS Sticky **
- **April WTB Sticky **
- Good times for D16's??
- preloading benefits
- AEM Modification with Cam Tirgger
- 60 ft problem
- pass time + lisa kubo
- b16 boost build
- Video from Scion Racing of Titan 2009
