H22a AWD Bellhousing and 8 injectors intake manifold!!
Helllo there guys,
I found this company its located in Malaysia
There name is alfateh_probillet
They made great bullet parts
Talked with the guy just told hem what i need,
Man i need a bullet bellhousing for h22 transmission it
has an awd !!
Instead of buying honda crv b-series awd transmission
Since h22a transmission and crv awd b tranny both had same
Gears inside the only difference is the outer bellhousing and case shape and both run cable linkages , so good news is he have both tranny in house!!
And to making things happen we need to purchase 8 sets
So he can proceed the work and do a one sample to test it.
For a starter to make it happens,
I need to know how's in with me?
we need to buy minimum 8 units so he can
start the process, and me or a volunteer
Will test it, the cost will be for each bellhousing $1,400 plus shipping, will Its worth since if want to make your car awd equipped you will save a lot of money like buying h2b kit fab work engine mounts clutch lot of things and you know this
bellhousing will save you a lot if your in.
Even make your accord or a prelude awd with these bellhousing
Will that's the advantage for h guys out there.
And for the intake manifold its a fully bullet comes with fuel rail to run 8 injectors 90m throttle buddy and bullet v clamp to that we need 8 units to proceed with this intake manifold to and the cost is $1,450 plus shipping.
Serious buyers only please
Here is there pages in Instagram and Facebook .
Instagram page
And
Facebook
And here are some pictures of their work
has an awd !!
Instagram page
And
Re: H22a AWD Bellhousing and 8 injectors intake manifold!!
Yeah brother your correct and h22 gears set and h22 bullet bellhousing to run awd that's the plan, the only thing we can use from crv gears is diff for awd teeth ring and the awd adapter that coms with crv transmission, you can even run crv gear set the h bellhousing.
We will be able to bolt this directly to h bellhousing, now that will so cool. That's the whole idea
I'm interested. Also interested in knowing the rest of the plan/parts list for this in a Prelude chassis.
If you are going to help get the Intake Manifolds Made... for gawds sake raise the plenum in the back and not a straight runner intake manifold. It looks way stupid when the unit is way low in the back and cause a Rear Headache on T Bracket..... So have the Plenum Up Higher Like an H.... This would look better and also sale more. This is why current options are meh on selling...
I’m definitely in on this one. I already have a b series awd trans horded up. Working on the trailing arms and rear end now. This bell housing will work perfect, I can keep my tilton carbon carbon clutch.
Also, I don't understand how a CRV transfer case is going to bolt up to an H bellhousing...
Not to mention the H differential (and gearset) needs machine work to fit in a CRV housing, as described here... https://honda-tech.com/forums/honda-...d-crv-3249871/
Their Facebook post from Jan 16 says they're charging $2,050 each with minimum 8 units ordered....where did you get the $1400 price?
allmotorfreak
07-07-2011 03:13 PM
Vtecboy2002
09-04-2002 01:05 AM
