View Full Version : Drag Racing
- Buying Drag Wheels
- Master cut off switch cable
- where to test in sol cal this weekend?
- ? how important is the snap ring on the counter shaft balance????
- T1 2pc. catch pan
- Finally broke into the 12s
- Bench Drag Racing...point out my errors please about NA vs. Boost
- what should i set my tire pressure at?
- Local Exposure From IDRC Utah
- NHRASC Vegas Prediction Thread
- CC twin disk help please...
- My family puts on an anual drag race at an airstrip...need some help w/track prep and sensor mountin
- First time on slicks, why does the car bog down?
- What is the cleanest FWD Racecar you've ever seen?
- Quick qustion guys
- finally built my catch pan(pics)
- Twin Bosch 044 Plan...
- Recommended drag slick size
- HOW much psi do u put in slicks. NEED HELP
- me drag racing a go cart?
- how to set suspension for the track
- transmission problem Help!
- Newbie Question
- 24.5x8x15 slicks tubes or no tubes?
- sacramento CMI roll call july 22nd
- One race waiver for tuner cars July 8th for IMSM Race at Byron Please read
- when is the D2B kit coming out? or it is
- 500whp... EG, with 24.5x9.5x13
- Honda Day Dyno Special in New Jersey
- ALL YOU 9SEC GUYS OUT THERE!!
- CSCS Event #2 Grand Bend Ontario CANADA!!.. roll call.
- Nos spark plugs
- im trying to put rear seats to mu crx that didnt come with seats? can i do that?
- Is there anyway i can put rear seats on a standard 1991 crx?
- spool or lsd diff??????
- My del sol into the twelves!!
- REVISED NHRA LAS VEGAS SCHEDULE AND ENTRY INFO
- NHRA Urbanracer.com Sportsman Alley T-shirt give away.
- Ebay Aluminum Radiators...your experiences please...
- What is the best 60' you have ever seen on a FWD Honda with BFG drag radials?
- TURBO Civics/ 03 Cobra VIDEO
- longshifter wont go into reverse
- limiter straps
- which flywheel bolts can i use?
- Finally
- CMI Summer Nationals July 22
- Any results from IDRC in Utah
- what is anti-lag?
- Roll cage install
- ran at the track today for first time
- pics of the computer
- Roll cage
- trade hondata comp
- SFI approved flywheel?
- mid 13's in crx
- what do you use to log knock?
- Help can't get racecar to start.(wirring gurus help)
- SpeedLoungeTV.com presents, The Intel: Jeremy Lookofsky
- DRAG SLICKS?
- Timing and valve adjustment....
- What's camshaft the best for B20+b16 head
- Slick Size.
- whats your opinion about Brian Crower produsts?
- SpeedFed Drag Nationals - August 18
- BOTI @ MIR (BUDDS CREEK, MD) - JULY 15TH, 2007
- AIM MXL dash for drag racing - anyone have any input
- Burnout Q.
- Drag Radial Size Help Please
- centerforce clutch
- Where to purchase slicks Online..?
- racing windshield
- The Turbo By Garrett Sport FWD Vegas Jackpot
- Minimum weights in BOTI events
- can I not use longshank lug nuts on bogart wheels?
- king rod bearings?
- Finally made my first passes with my new build (345whp 230 tq. hatchback)
- not a honda but a very fast car!
- Piston Prep Resources
- 2 step launch control question
- 2006 NHRA Xplod Sport Compact Sportsman Champions ad
- Which setup would you do?
- K-Series Turbo EK Hatch Built by Team Clutch Masters
- repairable?
- hondata s300 qustion:why cant give more ignition???
- MT 205 & 225?
- vacum for itbs
- mazwoxs chassis civic forsale
- Anyone running w/o torque mounts?
- KensKustomChassis rear axle problem
- Edelbrock Victo X or BBK SSI intake manifold?
- spfwd fuel sample valves
- Summer Sport Compact Slam at Etown June30/July1 Roll Call
- Moroso tubular tie rods
- *HOW A 140+ PASS FEELS*
- 14inch Slicks?
- Chris Rado WORLD Racing video
- Limit of 22x8x15 m/t slicks?
- slick/drag radial 13" wheel
- Warm like a Sauna?!?!
- Another Porsche for the drag race circuit?
- I have oil on top of my pistons...help???
- Battery Kill Switch
- D-bar mod gets me a sticker!
- suspension setup
- NDRA Turbo Street Sponsor Decals?
- made my first 10 second pass today then blew my tranny haha
- Made some progress on my B16 CRX drag car
- Tilton flow control valve?
- Important info regarding the IDRC event at RMR Utah June 30th. No quick class??
- Which tranny should I use?
- What's the minimum mild steel tubing thickness for an 11 second car via NHRA / SFI standards?
- richmond spool problems?
- Will JR Todd be racing for Force racing by next season?
- 225/45R14 BFG drag radial too small for DC2?
- Twin disc clutches pedal stops.
- F4i 1/8th mile time...good or not so good?
- bottom end bearings
- 91 ef hatch w/b20z2 with mods
- cali bay area folks need your chassis certified!
- LSD ID please...
- New Drag Car Build....
- went to the track last night... should i be mad?
- For Those Who Have Removed Heat, Fitting Size??
- 1/8th mile n/a b18c5 track times in dc2
- where can i buy intake horn??
- whose going to moroso tomorrow?
- STREET RACING crack down?
- Looks who is back but in Pro Stock....
- My revamped, overhauled, bulletproof front end
- hitting up the track again, this time i actually want to run
- Need a drag radial tire recommendation for 16" wheels!! (similar to 235/60/15)
- Where is john from M&H??
- gsr tranny with cuff top speed?
- weighed my car
- F/S Innovative cable to hydro conversion
- SpeedLoungeTV.com presents The Gardella – Chambliss Project: Air & Asphalt
- California crushes cars for street racing (The sight of this may make you cry)
- Video... Gary Gardella's 1400 HP Pro FWD Cobalt VS Kirby Chambliss' Edge540 Plane
- How do you SFWD civics make weight?
- Drag Radials: How many miles can I put on them without considering wear from the dragstrip?
- Import Dynamic and CFT EVO 8 vs Hayabusa Video....
- California crushes more street racing cars
- dirct fire
- Honday Odyssy gen.3 (2005)
- hot rod modification ask!
- IMSM Race #5 at Cordova Dragway Cordova Illinois June 30th
- New turbo from Garett for K series cars SFWD class
- Urban Racer.com dyno challenge
- IFO September 23, 07 Tulsa Raceway Park
- ask staging brake
- ATTN; SALT LAKE CITY, UTAH RACERS! CAR STOLEN!
- STREET GUYS! Drag Radial Input
- usdm type r tranny w/ 4.75 final drive?
- save LACR again this is the LAST STAND!!!!
- I need an engine damper for a K Swap'd car
- Thunderbolt Raceway...
- ERL 5 Main ??
- intake man... ?
- What size spacers?
- How to launch
- ne1 else need a license before Vegas!
- Power Street Rules
- GSR dyno 185hp ? what et time
- harness mounting
- Non-LSD transmission using only a single drag slick instead of two?????????
- broke 4th on dyno?
- >>>>~~~~The official Roll Call for Las Vegas july 13th and 14th~~~~<<<<
- competition engineering traction bars? any binding problems?
- new job, new username
- Hotrod dyno + thanks
- got a question
- Hey Francisco
- 2007 Mid Season Race Report: Updates, Rumors, Thoughts, Opinions
- CRX wheel/tyre combo for drag racing?
- Event Coverage NHRA Atco,SpeedLounge.com
- New shop in central florida
- parachutes?
- skunk2/hondata
- RREV Motorsports Supra 8.28 @ 166....LOOK....
- Tragedy strikes in Tennessee....involving drag car
- Help on improving my times gsr turbo hatch (times and setup inside)
- IDRC June 30th - anyone from Cali rolling up ?
- Brakes
- A reminder for those of you racing NHRA Las Vegas!
- Early Reminder for NHRA TV Coverage starts in July
- Rear Diffuser
- rota92's single cam video's
- Summer Slam
- Does anybody knows what motor is jeff evans running in the crx
- 12's Possible ???
- problem with an all -4 clutch line? will there be?
- bad 1/4 mile time
- Garrett GT
- gtk850 car at nopi.... on the brakes before the 1000'
- h22 what could i expect
- K-series parts
- anybody know where exospeed has been?
- New Record Pica Motor Rx-7
- someone made it to the track........
- Update: Tempest Racing New SFWD Civic
- 26in Slicks Yay or Nay?
- advice on slick/wheel size
- New Titan Car...
- act xtss question
- First dragstrip experience...
- small hole in slick....tube only option?
- Going to the Track, drag strip..
- lets talk parachutes
- snell ratings on helmets
- 11.6 @ 122 in a 6th Gen coupe EJ8
- CFT NHRA ATCO Coverage!
- Radials/Slicks for 14" Steelies, recommendations?!
- Nyce1s.com.... Felix Medina, Aggressive Racing 9 Sec Turbo Civic!!
- NHRA Atco Qualifying Videos!
- whats the best tranny
- Epsturbos.com/ Phantasm Motorsports pro 4 integra, St louis vid
- NOPI - Milan.. where are you staying???
- Liberty Gear Set Reverse problem
- ****Roll Call**** IDRC Rocky Mountain Raceway June 30th 2007
- LOVE MY NEW ROLL CAGE
- 96-00 suspension on a 92?
- Your choice H22 vs B18c???
- wtb need all 4 weld or bogarts 13x8 and 15x3.5
- Lower Control Arms help 60ft times
- e85 and stainless braided fuel lines.
- Stock RHD EG6 Slips
- What brand built electrical oil pumps for Honda?
- Look what I found. From one of the muscle car clubs
- Dyno Question..
- Tempest Racing brings you NHRA ATCO COVERAGE
- The Fastest
- simple suspension question
- Double Coverage - NHRA Atco on TUNERZINE.com, Gardella vs. Chambliss!
- Jeremy Lookofsky & The #1 Qualifier Interviews
- Getting the new T4 car
- Anyone involved with BOTI race series on here?
- Long runner vs short runner turbo manifolds?
- Autorush.com NHRA ATCO coverage
- what do you guys think of my time at the track
- Coverage of the CSCS Season Opener - TUNERZINE.com!
- Legal issues with removing sunroof (NHRA)
- Traction Bars
- CHECK OUT CFT'S Run
- Rim screw template for 13's?
- My Prelude's First Track Day
- What clutch should i get for a ls/vtec turbo?
- pro-am sport fwd guys!!!
- What companys make the fiberglass 1 piece front ends?
- Anyone know where I can buy this rear diffuser ?
- what class?
